Question about Panasonic Televison & Video
I have a Panasonic 47-PTWX42F. The TV Turns it self off and the on/off button will blink 3-4 times periodically. The TV will not turn back on unless I unplug the TV from the power outlet. Once I plug the TV back into the power outlet the TV will turn back on but in about 5 seconds will turn off again.
  • 3 Answers
Your tv must have a timer set on it with code need to crack code maybe a kid did it by a mistake,need to find the code
Posted on Dec 17, 2008
SOURCE:
Red light flashing, tv wont turn on
need the model number of the panasonic and also how many times it is blinking. The blinking is an error code.
Aug 03, 2012 | Panasonic Televison & Video
What is the remote code for panasonic TC-L32C3 for the time warner control?
turn tv on
on remote
1. hit tv
2. hold down setup till it blinks twice(tv button light)
3.then press 991 wait till it blinks (tv button light)
4.press channel up slowly until tv turns off
5. once it turns off hit setup again
6. press the tv then power button and then see if tv turns on if not then you just missed the code(repeat)
Aug 28, 2011 | Panasonic TCL32C3 TV
What are the error codes for a Panasonic PT-47WX 42 TV
3 times LED blinks in Panasonic PT-47WX42 shows problem with convergence out chips failure as this tv has two big black ICs STK392-110 as convergence output, replace them to fix tv problem.
Click Part Store to see an image of required chip and price info.
Local tv tech is recommended if you have no experience of working in tv circuit boards.
Thanks.
Apr 18, 2010 | Panasonic PT-47WX53 47" Rear Projection...
No picture
The blinking power light is a self diagnosis featre. How many times is the light blinking?
Apr 16, 2010 | Panasonic PT-47WX53 47" Rear Projection...
Since power surge. tv turns on then clicks and turns off. red power light blinks 3 times.
The convergence has failed thats what the three blink error code is. The PT53WX53 convergence repair kit from www.tvrepairworld.com should fix that issue for you. The kit also contains the Cd with instructions.
Mar 15, 2010 | Panasonic PT-47WX53 47" Rear Projection...
TV turns off
One blink error shows problem of +140 volt missing in TV
Please check if any connector is not plugged correctly while you put back things.
Jul 12, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Power problem
Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
Jan 30, 2009 | Panasonic PT-47WX42 47" Rear Projection...
TV turns off
That sounds like a power board problem if im not mistaken where your power cord plugs into the tv there is a board it connects to often times if u plug the tv in and it starts itself or turns its self off its the power board that needs to be replaced which btw is not cheap at all
Mar 20, 2007 | Panasonic PT-47WX42 47" Rear Projection...
Televison & Video Logo
73 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
