Question about Cozy Enclosed Front Console Heater 20,000 btuh Natural Gas
Cozy natural gas heater Mod # CLV 335A
Every time the thermostat tries to turn on the heater, the pilot light goes out. Thermostat and thermopile/coupler are brand new
  • oakjim Mar 15, 2009
    I have a similar problem with the same heater. My main burner actually comes on and stays on until the thermostat turns it off at the proper set point. However, the main burner comes on with such force that the pilot light is blown out. The main burner flame keeps the thermocouple generating adequate voltage until the thermostat shuts it off. At that point the pilot has to relit for another cycle to take place.
    A cozy tech hinted that the control valve has been redesigned to meet a new pollution standard and this is a recurring problem. The only solution appears to be replacing the control valve, which costs about one-half the price of a new heater.
    If this describes your problem, I would look for another brand of heater.
I have a dayton lp heater model 3e243 the pilot goes out when i turn the thermostat on
Posted on Feb 12, 2009
    Sergeant:
  • 359 Answers
Get someone to check the gas pressure that is poss problem gas company if nat and the lp supplier can do it
Posted on Dec 17, 2008
Cozy gas wall heater won't ignite, pilot light is on
There are two types of igniters, spark-type or glow heater. The glow heaters wear out and crack or break and the spark-type spark gap gets fouled or dirty. Both could have electronics problems that drive the glow heater or spark systems. The Filtrete thermostat is not the issue. While rapping the unit makes the glow igniter come back together to glow again.
Jan 14, 2014 | Cozy Heating & Cooling
When I turn on the heater, sometimes it comes on and sometimes it doesn't. The pilot remains lit. The repair person ruled out gas problems. Then he said it was the Thermostat but ruled that out and...
It sounds like your problem is delayed ignition.
This can be caused by low pilot flame height (Clean the pilot orifice or increase the pilot gas flow if necessary, by adjusting at combination control valve). Or the burner ports near the pilot flame are clogged and need cleaning. But, don't enlarge the holes. Low gas pressure can also cause this, but your repair person already ruled this out. If you have a wall thermostat, the Thermopile or Pilot Generator (it's the same thing) may be weak and failing. It's not generating enough millivolts of electricity to open the gas valve, when the thermostat is turned up. Or the Pilot Flame is not always touching it. If it is the Pilot Generator, the Cozy Part # is 70098 and cost around $40.00. A talented service man can install it easily.
Generally, these are the first things that you troubleshoot for delayed ignition.
Hope this helped to get you started.
Mar 23, 2011 | Cozy Enclosed Front Console Heater 70,000...
I have a Cozy gas heater is there any way of changing the mechanical nob thermostat to a regular wall mount one
need to change the gas valve and add a pilot generator and stat wire and a wall stat. If your unit is natural gas part numbers are gas valve 84085// pilot gen. 70098.
Nov 07, 2010 | Cozy (W352E) Heater
I have had the gas off for two years. I got the pilot light to work but when I turn the thermostat up to get some heat it got the heater going about three times in over twenty-five tries over a couple
you need to clean the burner assembly. Over time dust and settled inside the unit and it is possibly restricting the flow of gas through the burners. This is a dangerous situation. get it cleaned before you try again.
Apr 29, 2009 | Heating & Cooling
New Cozy Enclosed Front Console 70,000. Pilote goes out, gas stay
its not the valve you have a problem with the heat exchanger a baffle issue have to change.
Feb 13, 2009 | Cozy Enclosed Front Console Heater 70,000...
Every time the thermostat tries to switch the heater on, the pilot light goes out. Cozy natural gas mod # CDV 335A
remove the thermostat wires from the gas valve and put a wire accross the outer terminals if unit starts up the stat or stat wire is bad.
Dec 17, 2008 | Cozy Enclosed Front Console Heater 20,000...
Cozy Heater will not turn on from thermostat in the morning
no more than 20 feet of statr wire allowed and make sure the stat you have is for a millivolt system.
Dec 03, 2008 | Cozy Enclosed Front Console Heater 70,000...
Pilot Light Goes Out
The VC701 has a safety switch located on the back of he heater that may be tripping after the call for heat is satisfied. Check that there is a good draft by testing with a match. Make sure the flame is drawn toward the vent system when the unit is off and cooling down. Check it at the draft diverter located below where the vent pipe is attached. It is a box with an open bottom. If the draft is not pulling air toward the vent system, the heat from the cooling heater will trigger the safety switch and shut off the pilot. You may have to raise the vent pipe to establish a draft.
Nov 08, 2006 | Cozy Enclosed Front Console Heater 70,000...
Heating & Cooling Logo
264 people viewed this question
Top Cozy Heating & Cooling Experts
Paul Carew
vance jones
Mack Baxter
Are you a Cozy Heating and Cooling Expert? Answer questions, earn points and help others
