Question about Panasonic SA-XR15 Receiver
Static in audio
I have static im my audio and I think it has to do with the settings and programming of the audio functions on the receiver. I tried hooking up new speakers wires and alos new speakers and the static remains in all audio when using the TV, DVD and Tuner. I did spend some time fidling around with the settings on the receiver under the TV input such as (speaker dB, filter, d r compression, distance etc. and there is alwats a range from 70 to 0. but since i dont have a manual, im not sure what that means regarding the audio settings. I did manage to get rid of teh static a few times,m but as soon as i turn off the Tv and turn it back on the static comes back. But its definitely a matter regarding the receiver functions when it comes to the audio components regarding the dB range between 0 and 70. thank you
  • 97 Answers
SOURCE: no video
Is the video cable composite or s-video? the output from the receiver to the sets line input (1,2,3,s-video) must be the same on most receivers. If the game console uses composite (yellow rca connector) to the receiver, the same cable must be the same from receiver to TV. Some receivers do "up convert" to s-video or to Progressive scan (red,green,blue rca connectors) and do not follow this rule. Yor set needs to be switched to the correct input as well. None of the receivers I have services thus far hve the 75ohm cable lug for RF. Check all the cableing and repost if you find something new or different.
Posted on Jun 09, 2007
  • 192 Answers
SOURCE: Component Video inputs do not work
I started back in the day of tubes. A family would have one set and it would be a 19" black and white. There are different resolutions now. The components probably do work, but, they don't pass the 480i signal. The satelite converter's analog signal needs to be set to 480p and the DVD needs to be set to progressive if it does have that setting. If the DVD is not a progressive scan DVD, then, the only inputs that it will show on is the analog signal. Some of the dish converters have a switch on the face for changing the resolution. If yours doesn't then put it in an analog source and go to the menu and change it there. Then move it to the component input. Hope this helps.
Posted on Jun 24, 2007
SOURCE: loses audio in tv mode
I had the same problem (CD mode) but today all audio is gone. I opened it up and found no visual problems. There are 3 main boards inside, one where all audio inputs go to. I think that board is bad. Not much help I know. Good luck finding the answer. I'm doing a search on know problems now, If I find anything, I'll post back.
Posted on Jun 28, 2007
SOURCE: DVD optical/TOSLINK input no longer working
If it's only the DVD input, and you had tested it systematically, like you'd stated, then the input connector could be loose or defective.
iTritek Solutions
www.itritek.com
Posted on Mar 24, 2008
sparky1500
  • 1066 Answers
SOURCE: Panasonic legacy connection
s-video is a legacy connection. legacy means obsolete and this will impare your image.
what you should do is connect the cable box and blue ray directly to tv with hdmi cable, then run audio cables back to the reciever from these devices. the vcr and regular dvd player would be routed through the reciever the conventional way. you would have to change the inputs on the tv between the cable box, and blue ray if u have one, and a seperate single tv imput for components running thru the stereo. you would have to use the reciever to select between audio sources, and the video sources between the vcr and dvd only.
Posted on Nov 28, 2008
Please help! New icecam2, new mac mini, newest skype software. Mike and camera do function. Skype test call fails. No audio is received back. I've tried everything I can think of including turning...
To use Skype, follow the instructions below to setup the Audio & Video.
Web Camera's have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype
http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/
set it up as follows:
Go to Tools, then Options, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
Then click on the Video Settings.
The camera, if Installed Properly, it will come up and show a video picture.
Then, on the bottom of the page click save.
The camera and audio should function properly. Your friends and Family will now be able to see and hear you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger
http://www.soft32.com/download_30.HTML
Go to Messenger at the top left and click on it.
Next go down to Preferences and click on it.
Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
Next go to the Test Audio section and (in blue writing) click on "Open the call setup assistant" and follow the instructions on the left window.
C. Windows Live Messenger:
http://download.live.com/Messenger
After you start Windows Live Messenger, expand the view by clicking on the square on top left next to the red X.
Then on the Windows Live messenger window on the right side, click on " "Show Menus." And then click on "Show the Menu Bar".
Next go to the Menu Bar on right side, click on " "Action."
Go to "TOOLS" and click "Audio and Video Setting" and follow the instructions.
NOTE: Your audio and video should work. Enjoy.
When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
D. AIM (AOL) Messenger:
http://dashboard.aim.com/aim
On the VIM sign-in window click on Edit.
Then click on Settings Enhanced IM.
Next click on Enhanced IM.
Then click on Audio Video.
The Audio and Video portion has drop downs so you can select the proper audio card and video camera installed in you computer.
The Audi Video drop downs are
Microphone
Speaker
Camera
The audio and camera should function now.
Additional information to use with VIM settings.
Adjust Your Audio and Video Settings:
In order to adjust your audio and video settings, please follow the steps given below:
1. Click the Audio and Video Settings button directly below the My Buddy or My Camera window. If you are currently
Participating in an AOL Live Video IM session, a message will display: You must disconnect the current AOL Live Video IM
Conversation before running setup. Would you like to disconnect now? Click the Yes button.
2. The Audio and Video Tuning Wizard will appear to help you verify that your camera, speakers and microphone are working
Properly. Follow the on-screen prompts.
Notes:
The first time you use AOL Live Video IM, a message will display: Would you like to first check your audio and video settings? Click the Yes button.
The Audio and Video Tuning Wizard will appear to help you verify that your camera, speakers and microphone are working properly.
images in AOL Live Video IM may appear reversed, or as a mirror image (text may appear backwards) when you look at your own camera feed or at the
Picture-in-picture (PIP) display.
After making the settings your ready for a chat and video talk with your Family and Friends.
Hope this helps. Bud
May 15, 2011 | Macally IceCam Personal Web Camera
I just bought an a4tech-pk635E web cam i already install the driver but the pmcap program is ok but the other program pactray i couldn't open it so the web its still blurred its a little bit darker so what...
Follow the instructions below and it will work.
Disconnect the Camera from the USB port and reinstall the CD or Downloaded software program.
When the program asks you to connect the camera to the USB port, do so and it should work.
Then to use it on the Web, do this.
A. Skype Setup:
B. Yahoo Setup:
Microphone
Speaker
Camera
Notes:
Sep 02, 2010 | A4tech PK-635 Webcam
Static and noise
Send this to them so they can properly setup their Audio & Video in the messenger or Skype they are using to chat with you on.
A. Skype Setup:
B. Yahoo Setup:
Microphone
Speaker
Camera
Notes:
Apr 09, 2010 | Microsoft LifeCam VX-3000 Web Camera
The picture has static lines
Web Camera’s have to be setup on the program they are to be used with. Just installing the
properly.
A. Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/) set it up as follows:
1. Go to Tools, then Options, and click on Audio Settings and set the Microphone and
2. Then click on the Video Settings.
3. The camera if Installed Properly will come up and show a video picture.
4. Then, on the bottom of the page click on Save.
see and her to you.
B. Yahoo Setup:
(http://www.soft32.com/download_30.html )
1. Go to Messenger at the top left and click on it.
2. Next go down to Preferences and click on it.
3. Next Calling and Devices on the right and set the Microphone and Speakers to the
4. Next go to the Test Audio section and (in blue writing) click on “Open the call
setup assistant” and follow the instructions on the left window.
1. After you start Windows Live Messenger, expand the view by clicking on the square on
2. Then on the Windows Live messenger window on the right side, click on “ “Show Menus.”
And then click on “Show the Menu Bar”.
3. Next go to the Menu Bar on right side, click on “ “Action.”
4. Go to “TOOLS” and click “Audio and Video Setting” and follow the instructions.
1. On the VIM sign-in window click on Edit.
2. Then click on Settings Enhanced IM.
3. Next click on Enhanced IM.
4. Then click on Audio Video.
5. The Audio and Video portion has drop downs so you can select the proper audio card and
Microphone
Speaker
Camera
If you are currently participating in an AOL Live Video IM session, a message will display:
You must disconnect the current AOL Live Video IM conversation before running setup. Would you
and microphone are working properly. Follow the on-screen prompts.
Notes:
· The first time you use AOL Live Video IM, a message will display: Would you like to
first check your audio and video settings? Click the Yes button. The Audio and Video Tuning
· images in AOL Live Video IM may appear reversed, or as a mirror image (text may
appear backwards) when you look at your own camera feed or at the picture-in-picture (PIP) display.
After you get your camera installed properly, DO NOT unplug it from the USB port as it will
cause the drivers to be corrupt and render the camera unusable till reinstalled it properly.
Feb 27, 2010 | Logitech Webcam
When i skype and use video, the people on the other end hear static. also when i record video, i get a lot static. how do i fix that?
See section A. Skype in the info below to setup the Audio & Video.
Also send this to your family and friends so they have their computer setup properly.
A. Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/ )
B. Yahoo Setup:
After downloading and installing Yahoo Messenger (http://www.soft32.com/download_30.HTML )
Next "Calling and Devices" on the right, set the Microphone and Speakers to the computer Audio Card or headphones/mike.
Next go to the Test Audio section below where you just setup the microphone & speaker and (written in blue) click on "Open the call setup assistant"
and the "Yahoo Call Setup Assistant" window will open to the left and follow the the instructions. Click on FINISH and the audio will be setup.
Next go to "Webcam" and click in the circle "Allways allow the following people to view my webcam.
Next Click on "Super Webcam" snd in the circle click "Start Super Webcam mode automatically".
Then click OK and it should work.
http://www.microsoft.com/downloads/details.aspx?familyid=d78f2ff1-79ea-4066-8ba0-ddbed94864fc&displaylang=en
On the VIM sign-in window, click on Edit.
Microphone
Speaker
Camera
conversation before running setup. Would you like to disconnect now? Click the Yes button.
Notes:
After making the settings your ready for a chat and video talk with your Family and Friends. Hope this helps. Bud
Dec 02, 2009 | HP KQ246AA Deluxe Webcam
I loaded everything, when i test it with video impression software i can nto see anything on video csrene but black static...what's up?
properly.
A. Skype Setup:
see and her to you.
B. Yahoo Setup:
Microphone
Speaker
Oct 24, 2009 | Radio Shack VGA PC Camera Webcam
There is no color transmission at receiving end, how ever i am receiving color transmission.while i am using web cam others are not receiving in color. they are getting in black and white. how ever i am...
A. Skype Setup:
B. Yahoo Setup:
Microphone
Speaker
Camera
Notes:
Oct 20, 2009 | Computers & Internet
In Yahoo IM web cam freezes on receiving end
Normal 0 See section B. Yahoo Messenger in the info below to setup the Audio & Video.
Web Camera’s have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
A. Skype Setup:
  1. Go to Tools, then Options, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
The camera and audio should function properly. Your friends and Family will now be able to see and her to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger (http://www.soft32.com/download_30.html ) set it up as follows:
  3. Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
  4. Next go to the Test Audio section and (in blue writing) click on “Open the call setup assistant” and follow the instructions on the left window.
Jun 14, 2009 | Logitech QuickCam Communicate STX Personal...
Static when using lifecam - vx-6000
Normal 0 Web Camera’s have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
A. Skype Setup:
After downloading and installing Skype set it up as follows:
  1. Go to TOOLS, then OPTIONS, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
  3. The camera if installed properly will come up and show a picture.
  4. Then on the bottom of the page click on Save.
The camera and audio should function properly. Your friends and Family will now see and talk to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger set it up as follows:
Jan 11, 2009 | Microsoft LifeCam VX-6000 (68C-00001)...
No video
Send this to them.
A. Skype Setup:
B. Yahoo Setup:
Oct 16, 2008 | Computers & Internet
Panasonic SA-XR15 Receiver Logo
60 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
blanqui2000
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
