Question about Dell Dimension 4600 PC Desktop
Dell Desktop Plug & Play Configuration and Keyboard Error
You all have helped me before I want to say thanks for all the help and advice.
I have another for you. I transported my desktop to another location and when plugging it in it says ''Plug & Play Configuration Error''. Now I brought it back home, hooked it up and it says the same plus it also says Keyboard Error, even when the keyboard isn't plugged in. Also won't let me go to the bios.
Any suggestions?
Thanks in advance!
Lori
  • agroves0381 Dec 23, 2008
    I have the same problem and my computer also says strike f1 and strike f2 for utility setup
  • itsmelori Dec 30, 2008
    Yeah! Exactly my problem! One of the keyboard pins got broke during the move.
    Once again fixyas excellent support help has come through for me.
    Thank you !~
    Lori
    Master:
  • 461 Answers
My first thought is a damaged port. Check all the ports that were connected for bent pins and straighten if possible, but be careful and be sure the system is off and unplugged from the AC power. Also check for loose cards or cables that may have happened in the transport.
Posted on Dec 17, 2008
Dell inspiron 3521 code error 2000-0333 hearing a
There is a WIKI knowledgebase article on Dell error codes here
Beep Codes and PSA Diagnostic Chart Desktop Wiki Desktop Dell Community
It say this is due to "Graphics test timed out waiting for keyboard response."
Dells advice is to "Remove and reinstall the video card on a Desktop Computer for this error codes."
You can get a solution for the PSA error code at this Dell website.
Dell Technical Support
Oct 01, 2014 | Computers & Internet
Plug play configuration error
What hardware have you added? What is the Configuration error? Why don't you ask a question?
Aug 21, 2013 | Dell Dimension 8200 PC Desktop
restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
you could select the option start at last known configuration that worked this will tell you if and what file has been corrupted or missing then you will know if its a hardware issue
hope this helps
Nov 30, 2011 | Dell Dimension 8200 PC Desktop
Hard disk 0 configuration error post error keyboard error dell dimension 2400 xp
Unfornate motherboard failure. Ran into many with the same problems. The usb ports fail, then the ps2's,etc. Needs a mobo.
Apr 11, 2011 | Dell Dimension 2400 PC Desktop
Plug and play configuration error.I have been told to press F1 key to continue BUT nothing is happening
restart the desktop, hit F2 as soon as it is booting. This will take you into setup.there you can see what is happenning under the plug and play heading, or set it to default and restart the computer.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
Dec 25, 2010 | Dell Dimension 8200 PC Desktop
My computer has a plug and play configuration error on start up, and after it boots the display is distorted
Might be Plug and play option in system BIOS is Disable.So pls Enable from BIOS.For enable press Del. or F2 button continiously untill BIOS screen comes ,then choose a option plug and play and Enable it.
Nov 17, 2009 | Dell Dimension 8200 PC Desktop
reconnect all cables device to cpu .remove usb device if ther eis connect then asfter loading the operting system connect again.
Jan 29, 2009 | Dell Dimension 4500S PC Desktop
Switching mouse and keyboard
It is very easy buy usb keyboard and mouse and use it it is plug and play.
Sep 13, 2017 | Dell 2 Button Mouse 6u226
Keyboard Error
Sounds like intermittent keyboard failure. If it is the old style keyboard connector (small round jack), shut down, remove it completely, and then plug it back in. If it is a USB keyboard, you are probably having USB keyboard support problems. Try moving the keyboard to a different USB port - usually the ones closest to the parallel port or network jack that are sure to be on the motherboard itself.
Hope this helps...
Nov 20, 2007 | Dell Dimension 4600 PC Desktop
Dell Dimension 4600 PC Desktop Logo
512 people viewed this question
Alun Cox
