Question about Cozy Enclosed Front Console Heater 20,000 btuh Natural Gas
Every time the thermostat tries to switch the heater on, the pilot light goes out. Cozy natural gas mod # CDV 335A
  • 59 Answers
Remove the thermostat wires from the gas valve and put a wire accross the outer terminals if unit starts up the stat or stat wire is bad.
Posted on Oct 22, 2010
Cozy gas wall heater won't ignite, pilot light is on
There are two types of igniters, spark-type or glow heater. The glow heaters wear out and crack or break and the spark-type spark gap gets fouled or dirty. Both could have electronics problems that drive the glow heater or spark systems. The Filtrete thermostat is not the issue. While rapping the unit makes the glow igniter come back together to glow again.
Jan 14, 2014 | Cozy Heating & Cooling
I have a Cozy gas heater is there any way of changing the mechanical nob thermostat to a regular wall mount one
need to change the gas valve and add a pilot generator and stat wire and a wall stat. If your unit is natural gas part numbers are gas valve 84085// pilot gen. 70098.
Nov 07, 2010 | Cozy (W352E) Heater
The dang thing wont light
if the pilot will not light and you have natural gas remove pilot tubing and pilot orifice and clean out.
Oct 04, 2010 | Cozy Enclosed Front Console Heater 70,000...
New Cozy Enclosed Front Console 70,000. Pilote goes out, gas stay
its not the valve you have a problem with the heat exchanger a baffle issue have to change.
Feb 13, 2009 | Cozy Enclosed Front Console Heater 70,000...
Cozy heater 35000 btu pilot light goes out every 4 days
The thermocouple needs to get red hot. If the pilot flame is too low or too high or if it is not pointed on the thermocouple well, it won't stay hot enough. If the pilot flame is too low, a draft caused by opening a door could blow it out. If correcting this doesn't fix it, it could be a bad thermocouple or control. The factory assembly on these heaters is not the best.
Feb 02, 2009 | Cozy Enclosed Front Console Heater 70,000...
Cozy natural gas heater Mod # CLV 335A
get someone to check the gas pressure that is poss problem gas company if nat and the lp supplier can do it
Dec 17, 2008 | Cozy Enclosed Front Console Heater 20,000...
Cozy Heater will not turn on from thermostat in the morning
no more than 20 feet of statr wire allowed and make sure the stat you have is for a millivolt system.
Dec 03, 2008 | Cozy Enclosed Front Console Heater 70,000...
Cozy heater
That piece that fell out is probably the pilot orifice. It goes on the end of the pilot gas line when you screw it into the pilot assembly. Don't try to light the heater without the orifice. If your thermocouple is good and the pilot flame is set properly, the control valve could be bad. Be sure to hold the knob down for 60 seconds before releasing it.
Nov 08, 2008 | Cozy Enclosed Front Console Heater 70,000...
Pilot Light Goes Out
The VC701 has a safety switch located on the back of he heater that may be tripping after the call for heat is satisfied. Check that there is a good draft by testing with a match. Make sure the flame is drawn toward the vent system when the unit is off and cooling down. Check it at the draft diverter located below where the vent pipe is attached. It is a box with an open bottom. If the draft is not pulling air toward the vent system, the heat from the cooling heater will trigger the safety switch and shut off the pilot. You may have to raise the vent pipe to establish a draft.
Nov 08, 2006 | Cozy Enclosed Front Console Heater 70,000...
Heating & Cooling Logo
170 people viewed this question
Top Cozy Heating & Cooling Experts
Paul Carew
vance jones
Mack Baxter
Are you a Cozy Heating and Cooling Expert? Answer questions, earn points and help others
