Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
Oil Pressure I just bought a 03 Ultra Classic, when bike is reved or we are riding, the oil pressure gauge is around 32, however when the bike is @ idle it drops way down. What could this be? The gauge, the oil sending unit, or hopefully not the pump? Have you ever run into a situation like this?
  • smylzalot Dec 18, 2008
    I just bought a 08 ultra classic with the same exact symtoms , I took it to the dealer and was told that its normal. I still dont like it though, know what i mean?
    Scholar:
  • 29 Answers
Very common on h-d big twins for the last 75 years or so. These bikes have a dry sump oil system which means you have 2 oil pumps, feed and scavenge. The feed pump is very puny compaired to the scavenge, so at idle (especially when hot) it carries only a couple of pounds of pressure and that is all you need. The scavenge pump has a much greater capacity because if it can't keep up the crancase will start filling up and the crank will start slogging through the oil, killing performance. These bikes are equipped with hydraulic valve lifters which will start clanking loudly if you have a real oil pressure problem. Enjoy your ride and don't sweat it.
Posted on Dec 25, 2008
Low oil pressure and small leak
Oil pressure on these bikes is around 30 PSI at 2500 RPM or higher when fully warmed up. This will take 20 miles or more. At idle on fully warmed engine, pressure can be as low as 7 PSI depending on oil quality. It should however increase to around 30 when reved up. You did not specify where your oil leak is for me to comment on.
Apr 10, 2014 | 2011 Harley Davidson FLHX Street Glide
Oil pressure gauge
You have oil pressure and the gauge is working and no noise
that's great! Only worry if the gauge stops working.
cruise- on! Happy trails!
Jan 15, 2014 | Motorcycles
Cannot find a 2 prong oil pressure sending unit to replace an assumed bad unit on my 1994 Ultra with 40psi Gauge and idiot light. When on but not started Gauge reads zero, and idiot light is on. Start...
Hi Anonymous, start by checking oil level in tank and it is between the add and full mark. With engine at normal operating temperature 180-230 degrees and the use of a 10 micron synthetic media oil filter, oil pressure will be 30-38 psi at 2,000 RPM and 3-5 psi. at idle. The oil pressure light is designed to come on at 2 psi. or less. To accurately test oil pressure remove oil pressure sending unit and install known good oil pressure gauge that reads 0-50, there might possibly be some plumbing required for hard to access points. If you are out in the middle of nowhere and there is no cell phone service and your oil pressure gauge isn't working and your oil pressure light is burned out, despair not, you still have one last line of defense left HYDRAULIC LIFTERS.as long as those tireless workers are quiet, you have oil pressure, maybe not much, but enough to get you down the road at a slow to moderate speed using the least amount of RPMS as nessary. Good luck
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Sep 27, 2013 | 2000 Harley Davidson FLHTCUI Electra Glide...
On a 09 ultra classic what is the proper oil pressure? 10 different people give ten different answers.
Hi Anonymous, start by checking oil level in tank and make sure it is between the add and full mark. With engine at normal operating temperature 180-230 degrees and the use of a 10 micron synthetic media oil filter, oil pressure will be 30-38 psi at 2,000 RPM and 3-5 psi. at idle. The oil pressure light is designed to come on at 2 psi. or less. To accurately test oil pressure remove oil pressure sending unit and install known good oil pressure gauge that reads 0-50, there might possibly be some plumbing required for hard to access points. If you are out in the middle of nowhere and there is no cell phone service and your oil pressure gauge isn't working and your oil pressure light is burned out, despair not, you still have one last line of defense left HYDRAULIC LIFTERS, as long as those tireless workers are quiet, you have oil pressure, maybe not much, but enough to get you down the road at a slow to moderate speed using the least amount of RPMS as necessary. Good luck
Jul 12, 2013 | 2009 Harley Davidson FLHTCU Ultra Classic...
I have a 05 ultra classic and when the engine is cold i have no oil pressure if you rev it to five grand till it warms up the pressure is fine can you explain
Hi James, start by checking oil level in tank and it is between the add and full mark. With engine at normal operating temperature 180-230 degrees and the use of a 10 micron synthetic media oil filter, oil pressure will be 30-38 psi at 2,000 RPM and 3-5 psi. at idle. The oil pressure light is designed to come on at 2 psi. or less. To accurately test oil pressure remove oil pressure sending unit and install known good oil pressure gauge that reads 0-50, there might possibly be some plumbing required for hard to access points. If you are out in the middle of nowhere and there is no cell phone service and your oil pressure gauge isn't working and your oil pressure light is burned out, despair not, you still have one last line of defense left HYDRAULIC LIFTERS.as long as those tireless workers are quiet, you have oil pressure, maybe not much, but enough to get you down the road at a slow to moderate speed using the least amount of RPMS as nessary. Good luck
Nov 06, 2012 | 2005 Harley Davidson FLHTCUI Electra Glide...
2010 FLHTK HARLEY-DAVIDSON I noticed the oil pressure dropped from around 32 to what appeared to be 16. Then it dropped almost to 0. I pulled over and let it cool down for 15 minutes and rode to my de
Hi Tonykoegel, if your oil pressure gauge is acting eratic or your oil pressure light stays on you could have a faulty sending unit, gauge or air in the system or a restricted oil filter, start by checking oil level in tank and make sure it is between the add and full mark. With engine at normal operating temperature 180-230 degrees and the use of a 10 micron synthetic media oil filter, oil pressure will be 30-38 psi at 2,000 RPM and 3-5 psi. at idle. The oil pressure light is designed to come on at 2 psi. or less. To accurately test oil pressure remove oil pressure sending unit and install known good oil pressure gauge that reads 0-50, there might possibly be some plumbing required for hard to access points. If you are out in the middle of nowhere and there is no cell phone service and your oil pressure gauge isn't working and your oil pressure light is burned out, despair not, you still have one last line of defense left HYDRAULIC LIFTERS, as long as those tireless workers are quiet, you have oil pressure, maybe not much, but enough to get you down the road at a slow to moderate speed using the least amount of RPMS as necessary. Good luck and have nice day.
Jul 02, 2012 | 2010 Harley Davidson FLHTK Electra Glide...
How much idle oil pressure does an 2000 FLHTCUI
The oil pressure is fine. It may go lower once the bike is at operating temprature.
Jun 17, 2012 | 2000 Harley Davidson FLHTCUI Electra Glide...
I have a 2002 Ultra Classic with just over 20,000 miles on it. I just wiped it down and took off to ride and noticed the oil pressure gauge was motionless. I turned around and came home- about four miles...
Use an ohm meter to check your sending unit. Disconnect the wire from the front of the sending unit. Put your meter function switch in OHMS, R X 1 range. Put one lead to the stud where the wire came from and the other lead to the engine. You should read zero or very low resistance. Start the engine and you should read a very high resistance. If not, your sending unit, oil pressure switch, is bad. Other wise, you may have a problem with the wiring running from this switch to the gauge.
If your engine has no oil pressure, your tappets would be making a very loud rattling noise. Kinda like a tin can full of rocks. If your engine is running normal and quietly (mechanically) you have oil pressure.
Good Luck
Steve
Aug 24, 2010 | 2000 Harley Davidson FLHTCUI Electra Glide...
Oil pressure
Your Bike is a dry sump system oiling system which simply means that the motor needs to be revved up to get oil to the top of the motor. The readings that you see are actually normal (look closely at the gage and you'll see that you are actually are around 5psi at idle and in the 30psi range while moving). Great Bike!
Also you might want to checkout the free website for harley owners www.hdforums.com for insight on your bike.
Be safe!
Mike
Jul 07, 2009 | Harley Davidson FLHTC - FLHTCI Electra...
Lands Phones Logo
250 people viewed this question
Top Harley Davidson Lands Phones Experts
Gar
Gar
Ronny Bennett Sr.
Ronny Bennett Sr.
ted dux
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
