Question about Polaroid FLM-4201 42 in. LCD Television
The tv powers on it gives a blue screen and thats it
  • drumsmith85 Dec 18, 2008
    When I turn my tv on the screen is back lit (black). Once it's on the only way i can turn it off is by unpluging it.
  • 125 Answers
There is a bad pcb or module you will need a qualify technician to replace it
Posted on Dec 17, 2008
Screen stays blue and wont show the picture
TV may be on the wrong input and that will give you a blue screen. When you turn the TV on and the screen starts lighting up it should show on the screen what input the tv is on. If it is not on correct input change input with the TV remote or buttons on the tv. If it is on the correct input try a power cycle on the cable box, just unplug the cable box power cord for a few seconds and then plug it back in. If neither of these solve the problem describe how the cable box is connected to the tv.
Mar 16, 2014 | Mitsubishi WS-55513 55" Rear Projection...
While we're trying to watch TV, our Panasonic PT-AX200U HD projector will sometimes start alternating from a green screen to a blue screen and then to snow, and finally back to a normal picture. It's
You are experiencing Power Fluxuation. The Power Supply seems to be going out or on the way out... How old is the TV? Is it still under warranty?
Apr 08, 2013 | Audio Players & Recorders
Olevia 242 TV.... No picture or sound!!!
A blue screen usually is present if no signal is connected to the set---hook a DVD up to one of the rear inputs--select that input and see if have picture and sound.
If that works connect cable or antenna to set and select that input
NO signal is like no gas in car---it will not run.
Mar 22, 2012 | Televison & Video
Hi gud noon.just want some advice i have a problem with our tv sanyo flat screen if we try to turn it on it only appears blue screen theres no picture....thats our problem... we try to call already the...
  1. Try changing the input on the TV to see if the Blue screen goes away. Can you access the TV menu on the screen? If so, try running a channel scan until it is complete. Then check if the blue screen is still there.
  2. Disconnect any RCA cables, or other input cables from the back and see if you still have a blue screen.
Here is the link to Sanyo's Support site: http://us.sanyo.com/Customer-Support
E-mail: support@sanyotv.com
Phone: (800) 877-5032
Fax: (870) 630-4223
Feb 25, 2011 | Sanyo DP32648 32 in. LCD TV
Screen fades to blue.
The Blue SCREEN setting is too high. These adjustments are located inside the TV behind the front panel. There are two screws behind covers and then a wooden panel to remove to access the adjustments. The leftmost set are for BLUE, the middle are GREEN, and the right are RED. The top row are FOCUS and the bottom are SCREEN. Focus will focus/unfocus the tube and Screen will adjust the power of that tube (there are 3 tubes, one for each color). If Screen is adjusted too high, horizontal lines will appear (my TV had red lines, but I played around with the knobs and saw that it could happen on any of the colors). Additionally, if SCREEN is set even higher than that, the tube could go so high that it turns the whole screen that color (in your case, blue). If this happens the TV will shut down, probably due to either overheating or overvolting. To fix this issue, turn the appropriate SCREEN dial down until the lines go away. In your case, you want to turn the lower left dial down. Don't turn it too far down, if you turn it more than necessary the TV can give you an AKB error (noted by the STANDBY light flashing a sequence of 5 blinks).
Apr 02, 2009 | Sony KP-57WS500 57" Rear Projection...
The dogs rolled on the remote and the tv went to a blue screen and turned off. Every time you turn the tv on now it is a blue screen and says no signal and turns off after 10 seconds
This sounds as if when the dog rolled on your remote he has pressed the source button so that you are no longer on the TV cahnnel. The TV is looking for a different input eg. AV1/AV2/HDMI etc. This will give you a blue screen & as there is no signal the TV will switch off. Check on the remote for an Input or TV/AV or source button & make sure this is set for the TV signal.
Mar 22, 2009 | Vizio Televison & Video
Syntax olevia lt32hv 32 inch lcd tv. power surge now no picture
The electronics are known to go bad with these TV's, and I'm looking to buy someone's junk TV that has a good screen, rather than have to throw it out.
(So if anyone is out there with a 532-B12 that isn't working, send me a message!)
Yours might be worth fixing - however I know sadly that parts are nearly impossible to get for these TV's, and the manufacturer is virtually impossible to contact.
If you DO manage to contact anyone (manufacturer or otherwise) who can source or supply parts, PLEASE do let me know - it's been nearly impossible for me, and I want to replace my cracked screen in my TV.
If you can't, please let me know - I'll gladly give you a few bucks at least to salvage the screen from your TV, to transplant into mine, rather than turning it into junk on your curb.
Jan 07, 2009 | Syntax Olevia LT32HV 32 in. HD-Ready LCD...
Tv will not turn on
Get a power extension cord to connect your TV power to another (zone)room by using a different outlet and see if that is still does it.
Remember when you unplug the TV,you want to give it 15-20 seconds first .
If it still have the same issue,i hope you have the warranty,you are going to need it for repair.
solutiondoct
Nov 11, 2008 | Hisense Televison & Video
Polaroid FLM-4201 42 in. LCD Television Logo
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
