Question about Whirlpool LER2614JQ Electric Dryer
Problem with my dryer
I recently purchased a new whirlpool dryer. The first time I used it, it threw the braker. All the wiring for the dryer is new. I had the braker replaced, the dryer still threw the braker. I got the dryer replaced, and it is still throwing the braker. I don't know what to do. Any suggestions? Thanks Carol
    President:
  • 1,462 Answers
Unlikely a fault with dryer. try plugging another high consumption item into the socket you use for the dryer ie elec kettle or iron. see if breaker still trips and if so you have fault in socket or house wiring. if you put a plug on the dryer yourself, check you have wired plug correctly
Posted on Mar 26, 2007
SOURCE:
When turning on the dryer noting happens.
Seems your not getting power to the dryer, First check for blown fuse or reset the Braker for the dryer.thats 220 double braker. second make sure no one unpluged the dryer by mistake
If that don't help get back to me Good luck
Feb 20, 2011 | Whirlpool Dryers
Dryer made a cracking noise as wife attempted to turn on, dryer won't work as well as washer stopped at same time. have reset circuit braker no luck.
does the dryer use a 240 volt plug in there are two brakers one for heat and the other to run dryer look for two 60 amp brakers they may be at pannel or located out-side depending how old house is.
Dec 16, 2009 | Maytag Neptune MLE2000A Front Load Stacked...
Brand new dryer threw braker twice, then no heat and timer stopped working. Electrician tightened connections on wires to dryer settings dial, had heat for one load, then same as before. Replacement dryer...
might want to check your dryer outlet. If the terminals are loose in there it could cause you problems. If your dryer plug is a 4 prong you might be loosing one of your 220v legs due to a short . As the dryer runs the wires and connections will heat up and expand , if there is a faulty wire or connection then it may loose connection after a load. could be quite dangerous and a very possible fire risk so i would check it out ASAP . if the outlet is old they sell for about $20 at you local home depot or lowes home improvement. for a 3 prong plug you need to hook up the black and white wires on the brass screws and the copper ground wire to the green screw. in a 4 prong application you hook up the black and red wires to the brass screws, the whit wire t the silver screw and the copper ground wire to the green screw .
If your new dryer is supposed to be a 4 prong plug and you have it with a 3 prong cord then you will run in to issues . The difference being a 4 prong electric dryer is a dual voltage unit where it needs both 220v and 115v to operate correctly, where a 3 prong dryer only has 220v and the earth ground. if your not familiar or comfortable with electricity please call a qualified electrician to come hand handle the work. if not done correctly it can cause fires or possible electrocution
Oct 30, 2009 | Amana NED5500TQ Electric Dryer
Basic whirlpool electric dryer
Remove power source and then remove top panel to expose timer and check for burned or arced wires. Check also your power cord at the connection.
Jul 05, 2009 | Whirlpool LER4634J Electric Dryer
AMANA dryer model ALE643RBW burnt wire
I would think that:
Low voltage. A lack of proper voltage increases the current flow (amps) and can cause overheating, thus, a burnt wire. Remember, the lower the voltage, the higher the amps.
Bad connection. Poor connections can cause small amounts of arcing, thus burning the connection. This adds resistance to the circuit which causes a possible voltage drop and, again overheating due to higher amps.
Since all that equipment is on the same circuit, I would really think it is a voltage drop situation. With everything calling for power at the same time, the breaker trips. In some cases, it may be just enough for the breaker not to trip but still have a low voltage situation.
There is the possibility of an over current, such as a power spike from the power company but it would have to happen more than just a time or two.
And the outside chance that lighting got into the system when it struck something close to you home but it, in almost every case, would destroy something else, usually electronic. (This has happened to me. Trashed my dryer, dishwasher, and answering machine.)
Good luck and hope this helps. Le me know how you come out.
May 11, 2009 | Amana DLE330RAW Electric Dryer
Whirlpool Gas Dryer keeps running on auto dry setting
When you moved the sensor wire on the moisture sensor may have fallen off.
Remove the front panel and locate the wire and the connection. It will be on the right side near the lint filter vent. If it is still connected your timer has gone bad.
Mar 26, 2009 | Whirlpool Dryers
Whirlpool Estate Dryer barely heating
Four wires on the new cord.
Red and Black go to outside screws on the terminal.
White goes to the middle terminal.
Green goes to the cabinet ground screw near the terminal plate cover.
Mar 11, 2009 | Whirlpool GEW9250 Electric Dryer
Dryer started out squeeling and now is making loud sounds?
This is very likely due to bad drum support rollers which is really not a difficult repair on these dryers.
Whirlpool Dryer Repair Manual
www.RepairClinic.com
Feb 02, 2009 | Whirlpool LER4634J Electric Dryer
Whirlpool gas model LGC8858EQ1 dryer works fine except the timer does not move.
ckd for wire from thermostat on rear of blower or high limit might be easier to look at wiring diagram wire is usually orange they have been known to come off voltage is feed to timer motor during auto setting from a thermostat
Jul 30, 2008 | Dryers
Whirlpool LER2614JQ Electric Dryer Logo
64 people viewed this question
Top Whirlpool Dryers Experts
Sal De
Craig Butler
Craig Butler
Marvin
Marvin
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
