Question about Dell Inspiron 2200 Notebook
Blank Black Screen After Windows XP Loading Page
Shut the computer down 3 days ago and it has not booted since. When I press the power button I get a quick DELL page that briefly gives a F2 or F12 option... goes directly to the normal Windows XP page with the loading status bar. That page goes away and you think the thing is going to load and work as usual.... but it doesn't. I have a blank black screen with a white arrow cursor that works. Nothing has happened past that, not even after several minutes of sitting there.
I have looked around in the settings directory that I can access by hitting (I think) F2 and reset everything to default.
I booted the computer from the Drivers and Utilities CD and have ran several (I believe every) test. All say PASSED and it has given me NO Errors.
I need some direction with this problem because I am not by any means a computer whiz
  • 1 more comment
  • istuart19 Dec 18, 2008
    Kaj,
    F8 worked, I was able to boot the computer using "Last Known Good Configuration"
    I am on the computer now and everything seems to be working...
    Will the problem persist? Should I look further into the problem or forget about it?
    Thanks for your help!
    Isaac
  • daveo-1 Dec 31, 2008
    My computer will not boot.  Starts out fine, then goes to black screen with a big curser.  Tried safe mode, and all I get is the words safe mode in all four corners.  Tried reinstalling windows XP service pack 1 disk... it goes through all the motions, setup loads files, initiates, etc., computer restarts, and here I am back with the big black screen!  HELP!!!!  I even went the route of trying the " last known good configuration " with no luck.  I'm on a Mac laptop right now.
  • Kaj Bjorlin
    Kaj Bjorlin May 11, 2010
    Boot your computer up again. This time however, please press the F8 key repeatedly after the "Bios screen" that tells you to  press F2 or F12(or RIGHT BEFORE the Windows XP page).
    This should bring you to a menu with several choices. Please select the "Last Known Good Configuration" and let me know if you're able to get into windows correctly now?
    If that doesn't work - please boot up and press the F8 button again until you get the boot menu and this time choose "SAFE MODE" and let me know if that lets you get into windows.
    Please reply here with your findings.
    Thanks,
    Kaj
    Problem Solver:
  • 14 Answers
No this should hopefully not come back It can be due to lots of different reasons.
Please make sure to press the option on Fixya that shows that I solved this for you! Appreciate it! :)
Thanks!
Posted on Dec 18, 2008
Gx620 boots up, then screen goes blank, reboot gives blank screen with cursor blinking. will boot with cd but still shuts down after a minute or two.
Remove the battery and open the case. Look inside the computer with a flashlight to see if any of the capacitors are busted or leaking from corrosion. The capacitors look like little battery towers, but they are not as tall as the AA or AAA batteries.
If the capacitors are bad, your computer goes bunkers.
Apr 30, 2012 | Computers & Internet
It is not starting up
Good day. I suggest for you to reinstall windows and use the repair options. Usually software encounter errors or some files might get corrupted causing your computer not to boot up properly. The repair option in Windows XP will help you to fix those issue. here are the steps to follow:
1. Rule out hardware issues. Windows Repair will only fix software problems. Hardware issues can also cause boot problems (i.e. bad hard drive, memory, CPU, or power supply).
2. Backup. It's always a good idea to backup your important data before making changes to Windows XP. Relax, if you follow these instructions your data will be perfectly safe.
3. Boot from your Windows XP CD. Insert the Windows XP CD into your computer's CD-ROM or DVD-ROM drive, and then restart your computer. When the "Press any key to boot from CD" message appears on the screen, press a key to start your computer from the Windows XP CD.
4. A blue screen will appear and begin loading Windows XP Setup from the CD.
5. When completed loading files, you will be presented with the following "Windows Setup" screen, and your first option. Select "To set up Windows XP now, press ENTER". DO NOT select Recovery Console.
6. Then press F8 to continue
7. Next, Windows Setup will find existing Windows XP installations. You will be asked to repair an existing XP installation, or install a fresh copy of Windows XP.
8. Then just choose repair option to repair your Windows Xp
9 Then it should work. If iin any case that will not solve the issue, you might try to install fresh copy on Windows Xp
Hope this information will help you resolve your issue. Have a great day.
May 24, 2011 | Microsoft Windows XP Home Edition
I have XP Pro OS and I didn't gracefully shut down when it said Windows shutting down. I pressed the power button to shut off manually because it was taking too long. Now when I turned pressed the power on...
If you're still able to access your start menu:
Start>All Programs>Accessories>System Tools>System Restore
Select "Restore my computer to an earlier time" and click next
Choose an available restore point, one of a time before the incident occurred. Then click next.
I'm not sure how long this will take but it will notify you of a successful restore.
Oct 28, 2010 | Computers & Internet
Random Blank screen at startup. All lights runed on.
shut it down properly from the command line or/and keep power button pressed for 5 sec's or so
Jun 23, 2009 | ASUS Eee PC 901 XP Notebook
Blank screen, computer won't boot up.
i have this problem 2 days ago.. and this works on me... maybe on your's too
you may need to flash your bios. why need to flash the bios.. ? 1. had the black screen of death. or deleted the bios
how to flash the bios:
STEP 1.download the AA1 BIOS from this link:
http://www.acerpanam.com/synapse/data/7117/documents/AS1_BIOS_3309.zip
2. extract the file
3. rename the file 3309.fd to zg5ia32.fd
4. put zg5ia32.fd and FLASHIT.EXE onto the usb drive
now, start the process
STEP 2
A. make sure the power cable is in
B. the laptop is turned OFF
C. Plug the usb stick in!
STEP 3:
Press and HOLD down the FN and ESC key together
then press the power button, while holding the buttons
release the power button and continue holding FN and ESC for about 5 seconds
release the buttons and the power light will start to blink
let the laptop run and DO NOT PRESS anything this can take upto 8 mins
when it's done the laptop will restart.
this works on me... good luck.. and i hope it will help you.....
Jun 13, 2009 | Acer Aspire One PC Notebook
Blank screen on bootup
Make sure that the video output of the laptop isn't set to go to an external screen by plugging one in if possible.
May 21, 2009 | Compaq Computers & Internet
Error loading operating system in dell
You may be right , the harddrive on the system may have gone bad.
You can run a diagnostics on the hardrive,shut down the computer, and then Press the Fn+ power button at the same time , it would initate the diagnostics.
Do post the results back
Thanks
proton
Apr 05, 2009 | Dell INSPIRON 1300 Celeron 1.4GHZ,256MB...
No "press any key to boot from cd" message
ok if it is windows xp and u want to format it then what u can try is that if u have the option for the complete pc restore,then what u need to do is that shut down the computer completely and then all u need to do is that shut down the computer completely from the power button and then press and hold down the "ctrl" button and then press the power button only once and keep tapping the f11 key on the keyboard....and follow the instruction that says complete factory setting and then it will give u some message from symantec and then click on ok and the computer will be format,all u need to do is follow the instruction very carefully.....
or u can try once again,shut down the computer and then press the power button only once and keep tapping f12 key on the keyboard and then highlight the cd drive and then put nthe xp disk in and keep tapping enter and enter and enter untill it will take u to the windows set up screen and then it will give u the option to press R to repair and esc to continue and press esc on the keyboard and then delete all the partition the instructuin will be given just read it carefully and it will be formatted........hope this will work take care...
Jan 27, 2009 | Microsoft Windows XP Professional
the easiest solution would be to re-install windows and hope it is not a hardware problem
Jan 12, 2009 | Dell Dimension 2400 PC Desktop
Dell Inspiron 2200 Notebook Logo
749 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
