Question about Samsung DLP HL-P5663W 56" TV
Changed samsung hlp6163 colorwheel now all the colors are off alot of blue
  • joe5653 Dec 17, 2008
    well no becuase it did not tell me what is wrong.
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
There is a place for a jumper on your DMD (the module that the color wheel plugs in to) If the jumper is there remove it. If there is no jumper install one. On later models the pins are gone but solder pads are still there, solder it. Some wheels have air bearing and others have fluid bearing. You really should buy a service manual for that set. New color wheels sometimes come with CCA values that you must change in the service menu
Good Luck
Posted on Jan 21, 2009
  • 125 Answers
At this point you may need to replace the light engine, very expensive
Posted on Dec 17, 2008
  • Jose Posada
    Jose Posada Dec 17, 2008
    there is only one repair we can do in samsung tvs, [the color wheel ] after that or-- at this point you need to replace the light engine --
    of course you need first to get a qualified technician to come to your home and decide if the engine has to be replaced, it is kind of hard to tell if the engine is bad without checking the tv visually
Color wheel part number. Which one do i need. Model HLP4663WX/XAC Ser 397N3CEX900334D Chas L62B AT46L3
thats the BP96-00674A which is on Nationwide back order. The sub colorwheel is the samsung type 1 colorwheel from www.tvrepairworld.com
Aug 31, 2011 | Samsung HLP4663W 46" Rear Projection HDTV
I replaced the color wheel on my HLP6163, it was broken. The lamp would come on for a second before I replaced the color wheel and now it wont come on at all. Nothing. I hear it start and the lamp and...
Check two things:
First: when you replaced the color wheel examine the orange flat ribbon cable that plugs into it. It is very easy to put it in backwards. contacts on it should face rear of set--this will if placed wrong cause No lamp.
Second: make sure little blue lever switch is engaged(you cannot power set up with back off as the switch prevents set from working if lever is not engaged.
I am here if you need help, I am in California.
SD TECH
Oct 07, 2010 | Samsung HL-P6163W 61" TV
Screen is red instead of blue i just changed the color wheel and now it works but its off color
there is a jumper on the DMD board, the one that the colorwheel plugged into.. there is a small window to pull it out.. if there isn't one, then you have to add one. there was 2 types of colorwheels on this set, jumper tells it which one
it looks like this, its like 1/16 inch, so this is way oversized. sometimes if you can't see it, you have to remove the shield (only saw once, i think it was a manufacturing mistake) let me know if you need further assistance
Jun 25, 2010 | Samsung HLR5067WX 50" Rear Projection HDTV
Samsung HLP4663W I have changed Bulb, Ballast, and Color Wheel, Yes, removed the Jumper and set to CW2 too!(color wheel had no sticker with CCA Values or Actuator or Index Delay Values on it) I set the...
th dmd pcb can somtimes cost as much as a rebuilt light engine that comes with the dmd pcb colorwheel and dlp chip. look into a rebuilt light engine from tri state modules or pts electronics.
Feb 06, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
Is it easy to change a color wheel like the lamp? or i need to take it to a tv specialist?
the colorwheel is not as easy as the lamp to change. you have to remove the light engine from the tv and remove a cover from the lens and a cover from over the colorwheel then two screws that hold the color wheel and two wires. sometimes new codes must be input into the service mode. i suggest letting a professional do it.
Jan 30, 2010 | Samsung HL-R4264W 42" DLP HDTV
Color wheel
wrong color wheel..there are 2 colorwheels.you will need to remove a jumper wire...jumper is inside an opening abut 3/4 inch under label.
Apr 20, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
50 inch samsung model hln5065w
Depending on the version of software in the unit additional service alignments may be required.If the colorwheel was changed and the picture was fine before and now is bad this is the case.Only an authorized Samsung service center will have this information.In the colorwheel box there should have been a little sticker with the new peramaters required to align the new colorwheel to the software version.
Jan 14, 2009 | Samsung HLN5065W 50" Rear Projection...
Poor Quality HD Picture
The lamp would make you picture dark.The colorwheel will affect color quality.If brightness is an issue = lamp.If color is the issue = Colorwheel.
Jan 12, 2009 | Samsung HL-S4666W Television
Color is bad after installing color wheel in samsung dlp tv
Most times color does not to be reset. If you have a very ugly green or blue picture, then you did not pull the jumper on the dm board. This jumper must be removed when a bering type color wheel has be replaced with a new airless bering color wheel.
Mar 31, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung DLP HL-P5663W 56" TV Logo
390 people viewed this question
Jerry Greenberg
Jerry Greenberg
