Question about Canon imageCLASS MF6530 Monochrome Laser Copier/Printer
Canon ImageClass MF 6550 Error Toner Low- Prepare New Toner
I have tried what the Manual says to do Move toner back and forth many times then install back into printer. Next I have tried New Toner Cartridge. Have tried and the Error light still blinks and the LCD Screen Say's Toner Low Prepare New Toner. Printer will print ,scan, and copy. I am just tring to clear the error message so employees dont chang out a new toner evertime. I have tried going through all of the sub menus to find some way to clear. I am having no luck.
Thanks for you help
There are two contact on the right wall off the printer cartridge chamber area. They can get pushed in causing the printer cartridge to not read correctly. Take a small Flathead screwdriver and bend them up so the cartridge ink level can be read.
Posted on Apr 26, 2011
    Scholar:
  • 136 Answers
There's contacts on the toner cartrdige make sure the contacts on the cartridge are cleaned, then t what I would do is look where those contacts ling up make sure the springs that touch the toner contacts are making good contact, If not call a tech so he can adjust those springs to make better contact.
Posted on Jul 24, 2009
Left Print Side IS lighter than right
You may be beginning to run low on toner. Many toner manufacturers have users gently shake or tilt the toner cartridge back and forth prior to installing. This is to help break up any settling of toner between the time of manufacturing and installation. If that step was skipped, toner may not have been evenly distributed within the cartridge itself.
Replacing the cartridge (or possibly removing this one and shaking gently and then reinstalling for a little more life) should solve the problem - unless there is another issue. Make sure you read the installation instructions!
May 02, 2013 | Dell 1320c Laser Printer
Brother HL-2140 laser printer, where is the toner located
The toner cartridge is inside the printer's drum unit. To change the toner, make sure that the printer is on and then open the front cover by pulling it down. Then pull the drum and toner cartridge assembly out of the printer. (Take care not to touch the electrodes on the sides of the drum.) Push down on the green lever (on the left side of the drum unit). Then you can remove the toner cartridge from the drum unit.
Open your new toner cartridge and then shake it gently and remove the protective cover. Put the new cartridge into the drum unit and push down until it clicks (the green lever should come up automatically). Slide the green tab along the corona wire back and forth several times. (Return it to the home position when done).
Then return the drum and toner assembly to the printer and close the front cover. Wait until the Ready light is lit before turning off the printer or reopening the front cover.
For pictures of the HL-2140 drum and toner assembly (and the toner replacement procedure), see page 60 and subsequent pages of the manual here: http://welcome.solutions.brother.com/BSC/public/files/dlf/doc002308/cv_hl2140_usaeng_usr_d.pdf .
I hope this helps.
Dec 26, 2011 | Office Equipment & Supplies
The printer prints every page grey and the print is lighter than normal. the toner light is not on. should I replace the toner cartridge?
Your problem sounds more like a bad drum unit than a toner issue. You should try cleaning the corona wire first which you do by removing the drum/toner unit and looking for the little sliding blue tab. Move this back and forth a couple of times and then reinsert the cartridge and try printing again.
Sep 06, 2011 | Brother HL-2040 Laser Printer
Printing blank page even in test mode. hplaserjet 1200
Checking the toner cartridge
Image formation defects are many times the result of problems in the toner cartridge. If there is any doubt, always replace the toner cartridge before troubleshooting image defects.
Use the following checklist to make sure that the toner cartridge is still operable.
" Make sure that the toner cartridge is seated properly.
" Inspect the toner cartridge for toner level.
" Check the expiration date stamped on the toner cartridge box.
" Check the toner cartridge to see if it has been disassembled or refilled.
" Inspect the toner cartridge to see if toner is leaking through worn seals.
" Check the surface of the photosensitive drum in the cartridge to see if it has been damaged or scratched. Touching the drum contaminates the photosensitive surface and can cause spotting
and image defects.
" Blurred areas on printed pages indicate that the photosensitive drum in the cartridge has been overexposed to light. Because overexposure to light causes permanent damage to the photosensitive drum, the cartridge should be replaced.
Note A toner cartridge weighs approximately 863 grams (30.5 oz) when it is full, approximately 766 grams (27.0 oz) when it first fades, and approximately 742 grams (26.2 oz) when it is empty.
To redistribute toner in the cartridge
Before installing a new cartridge or when toner begins to run low, redistribute the toner by rotating the cartridge back and forth five or six times.
Jul 27, 2011 | HP LaserJet 1200 Printer
HOW TO REMOVE TONER CARTRIDGE TO REPLACE WITH NEW ONE
1. Grasp the front cover of the printer and pull it toward you to open the toner door. Reach into the printer and grab the combined toner cartridge/drum assembly. Lift up slightly and pull it out of the front of the printer.
2. Place the cartridge and drum on a paper towel, spare sheet of paper, rag or other surface that can get dirty. Loose toner particles may spill from the cartridge.
3. Press the blue locking lever on the cartridge/drum unit to unlock the toner cartridge from the drum. Lift the toner cartridge up and away from the drum unit. Dispose of the old toner cartridge in accordance with your local regulations. Seal it in a plastic bag to keep loose toner from spilling.
4. Gently shake your new toner cartridge back and forth a few times to distribute the toner evenly across the width of the cartridge. Remove the plastic protective cover from the bottom of the cartridge.
5. Place the new toner cartridge onto the drum unit and press it down gently until it locks into place. The blue locking lever will automatically click into place. Verify that the toner cartridge is securely connected to the drum.
6. Locate the corona wire cleaner tab at the front of the drum unit. Slide it back and forth several times to improve the print quality of the drum. Set the tab back in the home position when finished.
7. Slide the combined toner cartridge/drum unit back into the printer and close the front cover.
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
Feb 09, 2011 | Brother HL-2040 Laser Printer
How do i change the toner on m my HL 2040 brother printer
How to Change a Toner Cart in a Brother HL 2040
The Brother HL 2040 laser printer has a toner cartridge that supplies toner to the drum assembly so that the printer can print properly. When the LED on the front of the printer indicates you are low on toner, you will need to replace the toner cartridge to maintain good print quality. Fortunately, the toner cartridge can be replaced without any special tools.
Instructions
Things You'll Need:
* Replacement toner cartridge (part number TN350 or TN360)
* Paper towel or scrap paper
Hope it helps...
Dec 02, 2010 | Brother HL-2040 Laser Printer
I replaced the cartridge and now it wont copy anything
If you mean blank copies then you either have installed a bad cartridge or perhaps you did not pull out the toner seal tape from the new cartridge before you installed it. If not then just remove the new cartridge and check one of the 2 ends of the cartridge for a small tape sticking out. Pull that out of the cartridge which will release the toner supply to the developer roller. Then re-install.
If you did this already then test for a bad cartridge by shaking the old toner cartridge back and forth a few times and put it back into the machine. It should work well enough to at least test for blank copies.
Good Luck and Thank You for using Fixya.
Sep 04, 2010 | Canon PC1061 Copier
Replaced toner cartridge - print is very faint
You have to wiggle the toner cassette gently back and forth in a horizontal position like ten cycles before installing the cartridge in the printer. Otherwise the toner will not feed properly.
Also make sure to clean the scanner window and clean the corona wire at every toner change to prevent problems, check out the instruction manual on how to do this.
May 21, 2009 | Samsung CLP 300 Laser Printer
New toner cartridge and paper jam
Does this happen when you install the old toner? Is the NEW toner an OEM or compatible? I have run into this problem before on some other Brother all in one models. There is a sensor flag located just below the toner and drum unit. Remove the toner/drum unit, check that the sensor flag will move to back and forth freely. My customer removed the toner and drum unit and threw the drum unit away, not realizing that the toner seats into the drum unit. When they placed just the toner into the printer, it read paper jam. Because the drum unit is part of the paper path, the sensor was not in the correct position.
Try re-seating the toner into the drum unit and then re-seat the entire unit into the printer. Let me know if this helps.
Oct 20, 2008 | Brother DCP-7020 All-In-One Laser Printer
How to remove drum unit from kyocera fs 1920
Installing the Toner and Drum Cartridges
bullet.gif Installing the Toner Cartridge
bullet.gif Installing the Drum Cartridge
caution.gif CAUTION: Before performing any of the following procedures, read and follow the safety instructions in your Owner's Manual. Installing the Toner Cartridge Install or replace the toner cartridge while the printer is on (if the power is not on, the cartridge carrier will not rotate).
  1. After confirming the Insert Yellow Toner (Y)message, open the front door.
  1. Hold the tape on the protective cover and pull it forward to remove the cover from each cartridge slot.
note.gif NOTE: You need to remove the protective cover only the first time that you install the toner. note.gif NOTE: Dispose of the protective cover after you remove it. note.gif NOTE: The protective cover is attached to each toner cartridge mount. mag_cover_5.gif
  1. Make sure the color of the toner cartridge matches the slot on the toner cartridge carrier. The order is Y, M, C, K. Gently shake the cartridge to distribute the toner evenly.
  1. Lift the tab up 90 degrees and pull the toner seal straight off, keeping it parallel with the toner cartridge.
  1. To insert the toner cartridges, align the arrows on the cartridge with the corresponding arrows on the printer. Guide the cartridge in until it snaps into place and then push down the handhold to lock the cartridge in place.
  1. Close the front door.
note.gif NOTE: Make sure the toner cartridge is installed correctly. Otherwise, the front door cannot close firmly. close_front_cover.gif
  1. The toner cartridge carrier rotates to the next empty slot. When the color of the newly inserted cartridge appears on the display, followed by the Insert message, insert the next toner cartridge.
  2. Repeat steps 1 through 7 when inserting the remaining cartridges.
  1. When the Insert Drum or Insert Drum Cart message appears, open the front door, then lift and push back the top cover.
  1. Remove the protective sheet from the drum cartridge.
  1. To insert the drum cartridge, push up the lever on the right side of the printer. With the lever in the upright position, hold the drum cartridge by the handle, align the arrows on the drum cartridge with the corresponding arrows on the printer and guide the cartridge in until it snaps into place.
  1. Pull down the lever on the right to lock the drum cartridge in place.
  1. Close the top cover, then the front door.
note.gif NOTE: After installing the drum cartridge, the printer makes an adjustment for about one to two minutes. Do not turn off the printer during this time.
Aug 04, 2008 | Office Equipment & Supplies
Canon imageCLASS MF6530 Monochrome Laser Copier/Printer Logo
2,565 people viewed this question
old marine
old marine
