Question about Compaq Computers & Internet
Compaq Presario V3224TU, damaged from electricity problem
I have plugged in my laptop in an outlet (an electric fan is also plugged in another one). Suddenly, it shut off at the same time as the fan. However, my laptop can’t be turned on anymore while the fan was just working again when I turned the switch on. The display light for power status is also broken but the light showing the status of power from the power cord is still working. I guess the power board inside the laptop is broken due to the electricity exceeds the limit. Do you think so? Or do you have any other ideas?
If I just replace the power board, will it become working again?
Does it damage any other parts beside the power board?
Thank you so much!
Jeremy
  • 390 Answers
The most likely problem that you are experiencing is is the power supply has failed. The best way of checking it is with a voltage meter and verifying that the output at the small connector matches or is slightly above what is listed on the power supply block. Usually it is a good sign that the power LED is lit on the power block but it does not always mean that it is working!
Replacing the power board inside the notebook /laptop is not something most users can do so it would then be advisable if the power supply does check out ok to bring it to a repair shop for repair.
Good Luck!
Rich Lilja
Posted on Dec 17, 2008
Sound is distorted and echo's
check the speaker plug/outlets is usually if its a laptop on the side
you will have to open up the computer to check the lead attached to the rear of the input plug make
sure the connection is good with no dust as dust causes static electricity
clean your computer of dust using a fine air blower from a compressor making VERY sure that there is or a can of compressed air
no MOISTURE in the air line specifically around the sound card and the CPU central processing unit
dust causes static to build up in a computer
hope this helps
Jul 29, 2012 | Compaq Presario CQ57-410US 15.6-Inch 320GB...
I, have a Compaq , my power pack had a short and when,I plug it into the wall jack, it short my whole system out and burn the power pack out,I can not get any power to my computer. can you help.
Unfortunately there is no fix for this. it shorted out the system and you will need a new computer. Seeing that a electric shock from a human hand to the motherboad can destroy a computer then the shorting out from an outlet will definitely destroy the computer.
Mar 28, 2011 | Compaq Presario CQ50-139NR PC Notebook
My Laptop when power there fan sound about 1 mins then off no power. Pls advise
two solutions (two Advice):
1- try turning your laptop on with another Adaptor.
maybe your adaptor cannot supply enough electricity for your laptop.
2- electrification center of your laptop is damaged.
so take it to a warranty center quickly.
Jan 11, 2011 | Compaq Presario 700 470024-192 Notebook
I am using COMPAQ CQ60-101 au laptop.my laptop is automatically shutting down with high heat
Try to check if your cpu fans are working. If it is still working. Try buying a decent laptop cooler or you can add an electric fan to further cool the laptop.
Thanks. Cheers!
Apr 21, 2010 | Compaq Presario Notebook
ELECTRICAL POWER DOES NOT SEEM TO WORK EVEN THOUGH PLUGGED IN
Try another outlet in your home. Or if it is plugged into a surge protector remove it for the surge and plug it directly into another outlet
Jun 11, 2009 | HP Compaq nc8000 Notebook
Compaq presario 1200 no power
power supply bad possable fuse blown
Mar 26, 2009 | Compaq Presario 1200 Notebook
Compaq presario 730us won't power on
Sounds like the power converter that is probably on the motherboard, so you may be looking at a new motherboard. Hard to tell without seeing it in person, but you can take it some place locally and they can troubleshoot power issues for you. GL!
Feb 07, 2009 | HP Compaq Presario 730US Notebook
Dead,the cap light does not lite just dead
No fans , No lights, No sound?  Unplug computer and plug something else into outlet to see if the outlet works. If it does the look where the electric cord plugs into the computer , There is a switch . Make sure the switch says 1, not 0. If that doesn't help either have the power supply checked or substitute another one to see if that may be the problem.
Dec 21, 2008 | Compaq Presario 5000 PC Desktop
I have a compaq laptop and it turns on but the screen is black and it doesnt want to charge and i have plugged it in in diffrent electrical outlets and it still doesnt work what can i do?
this motherboard or charging circuit in the laptop has been damaged, with the video problem I would go with a motherboard that is fried, so either replace the motherboard or charging circuit board or buy a new laptop
Jun 19, 2008 | Compaq Computers & Internet
Computers & Internet Logo
44 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
