Question about Sony KP-51HW40 51" Rear Projection Television
Sony kp53hs30 screen is curved at top/bottom when in widescreen
Greetings. Shortly after I bought my kp53hs30 tv, I noticed that when viewing certain direct tv channels, the picture quality, (particularly red, or fleshtones) was pixillated, or would show up in small squares at times, and would look really grainey. I called the service center where I bought the tv, and they sent a tech out. Neither myself nor the tech knew at first that the problem had to do with the compression methods that Direct TV was using at the time. We thought there was something wrong with the tv. The tech made several adjustments. He was able to locate a bulletin describing the compression problem, and how to make adjustments to the tv to compensate for the problem. He fixed that problem, however, in the process, the picture is now curved in slightly at the top and bottom of the screen. I didn't notice this immediately, because at the time, I had always used full screen/480i. Now that I own several wide screen dvd's, and more and more channels now broadcast in widescreen, the curved picture is quite noticeable. It's not horrible, but I would like to correct the problem. Somewhere in the service menu there should be a setting that will adjust the top and bottom curve. What option would it be, and how do I access it? Other than this minor problem, it's been a great tv. THANKS!!!!!
  • Anonymous Jan 17, 2009
    I have the same issue....plus the tv wont stay in convergence
  • 125 Answers
On the sony we have to make the convergence alignments on all the modes, only a qualify tech can do that
Posted on Dec 17, 2008
Picture curved horizontally at both ends of a Sony Trinitron TV
Just about any tube TV is a 4:3 picture shape and most current TV is 16:9. so there is a compromise to get them to work together. Unless you are viewing retro TV shows, you should adjust your Digital converter so that you have a black band top and bottom (yes you are giving up screen). The alternate is to keep 16:9 and give up left and right sides of the program. Or properly recycle the TV and buy a LCD screen. Even used, smaller ones can be had for 20 bucks. I bought a 32" for 30.
In case I have this wrong and this is a new screen problem, make sure there are no magnets anywhere your TV. They distort. Have you tried back adjustment screws? Use a mirror or have a friend help. Look especially for pincushion adjustment.
Mar 08, 2018 | Sony Televison & Video
Diagonal lines at 45 degree angle from left top to right bottom of screen
db:: 4.31::Diagonal lines on tm2 screen? fz - Hivmr
www.hivmr.com/db/fzap9jk8dp87mcjk3cc9jsp7fzxk7pz1
There are faint 45 degree diagonal lines covering my brand new tm2 LCD ... with some static looking diagonal lines going from bottom left to top right. .... DB:3.01:Dv6113 Us - Computer Freezes Showing Diagonal Lines On Screen aj ... Also there arediagonal lines that run across the screen at about a 30 degree angle.
3M Privacy Filter for Laptop diagonal-14.1" viewing screen ...
www.amazon.com/3M...diagonal-14.../B00006B8A9
Amazon.com, Inc.
Rating: 3.8 - ‎1,617 reviews
Amazon.com: 3M Privacy Filter for Laptop diagonal-14.1" viewing screen ... Premium 14.0 Inch Privacy Screen for Widescreen Laptop or Computer Monitor .... 3M™ Privacy Filters create a 30-degree cone of vision so on-screen data is .... You'll also notice a large "3M PF14.1W" printed in the top right hand corner of the filter.
FZ190: Faint Diagonal lines on screen? ' NotebookReview
forum.notebookreview.com > ... > VAIO / Sony
Jan 27, 2016 | Computers & Internet
How do I widen screen
The top and bottom bars are standard widescreen viewing. Your TV should have a zoom feature that you could use to zoom in past the standard 16:9 format. Look for a zoom button on your remote or in the tv setup settings.
Dec 17, 2014 | Polaroid Televison & Video
Top of screen slants on the right and left side horizontally
go in touch with SONY i assume ur set is still under warrenty.....call customer help and support
Mar 12, 2009 | Sony FD Trinitron WEGA KV-36HS420 36" TV
Thin curved lines in sony widescreen
Those sound like what is called "scan lines" and are the result of the way the picture is "drawn" on the face of the screen. Something in the set is allowing too much drive to the screen, as these are usually suppressed during normal operation...accordianman
Nov 11, 2007 | LG 42PX5D 42 in. Plasma HDTV
43H70 picture wobbling
possibly leaky cap in power supply,look for a 1000mfd/16v cap in on near the b+ supply and also cold solder connections.
Aug 06, 2007 | Toshiba 43H70 43" Rear Projection...
Sone TV Picture not aligned.
This looks like Pincushion problem. nothing you can do. Only a Trained technecian can do this adjustment to reproduce a perfectly aligned image. It requires a pattern Generator and other tools. call the company tech.
May 10, 2007 | Sony KV-36FS100 36" TV
Sony FD Trinitron WEGA KV-36HS500 36" TV - Bowed Picture
it sounds like a convergence adjustment problem. If you hava book on the tv still read it, and it will tell you what to do, other wise, look for a convergence button on the front of your tv, and take the remote and push menu to bring up setup, and go convergence adjustment click it and hit the conv. button on the front of the screen. there should be to lines going vertical and horizontal, these are the limes you adjust with your remote, you have to adjust the red and blue, the tv should blink to let you know which color you are on. when you have them lined up right the line will be perfectly white. hope this helps
Jan 31, 2007 | Sony FD Trinitron WEGA KV-36HS500 36" TV
TV Screen Problem
Turned on TV and all that shows up on the screen is horizontal colored lines
Jan 25, 2007 | Daewoo DSC-30W60N 30" TV
Playing back widescreen problem
The TV itself uses the CTC203 chassis and is not capable of switching between normal and widescreen. This is an issue with your DVD player and not a problem with the TV.
Jul 16, 2006 | RCA F27442 27" TV
Sony KP-51HW40 51" Rear Projection Television Logo
153 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
