Question about Brother IntelliFax-2820 Laser Fax
Brother 2820 NEW Main PCB problem
We have changed the main PCB with new one but no action on display. Some thing appears on display and nothing is happened. Actually, we have replaced the main PCB of this machine into a other machine. Now we got new main PCB and fixed in that new machine but problem is same as mentioned above.
2 Suggested Answers
SOURCE: Brother Fax 2820
Brother Intellifax 2820 LCD screen has no display, all other things work fine.
Posted on Jul 26, 2011
Error code e000733-0001
E733
0001 A fault is detected by the main controller PCB in the communication between
the DC controller PCB and the main controller PCB.
Main cause The connector has poor connection. The DC controller PCB is faulty.
Action
1. Connector, DC controller PCB
Is the connection between the connector J1015 on the main controller PCB
and the conductor J316 on the DC controlled PCB normal?
NO: Correct the connection.
YES: Replace the DC controller
Jan 23, 2010 | Canon (6981A002AA) for imagerunner 2200,...
HOW DO YOU TURN OFF DRUM LIGHT ON BROTHER 2820
Open front cover....press 'options', and select 'new drum'
Nov 11, 2009 | Brother IntelliFax-2820 Laser Fax
After I apply the last firmware update in my Brother FAX-2820 the USB stops working. I have connected the machine in many PCs via USB and nothing. I need your help to solve the issue.
first you dont need to update the firmweare of this machine just only apply this update if you change for a new one main Pcb. If you try to update this machine you make damage your main pcb.
Oct 01, 2009 | Brother IntelliFax-2820 Laser Fax
Change toner error brother 2820 mach has new brother toner ctg
with machine on, open front cover, press the "options" button, you should see "replace drum?" press the "start" key then 1 then 0. display should show accepted for a couple of secs. then show cover open. close front cover and message should be gone. if not, you will have to contact Brother.
hth,
razors
Jan 23, 2009 | Brother IntelliFax-2820 Laser Fax
Brother Fax 2850 no dial tone
who changed out the main pcb board and why, may be one of the connectors was left of , there is a connector comming from the phone board called the ncu board. go over your connections, or if a service center did the replacement it should have been checked out before you got it back, good luck
Dec 25, 2008 | Brother IntelliFax-2820 Laser Fax
Brother Fax 2820
sorry to say but the new board needs to be flashed. Only can be done by a authorized service center.
Dec 17, 2008 | Brother IntelliFax-2820 Laser Fax
Brother intellifax 2820
i need printer driver for MFC 2820 laser plain paper fax *** printer
Apr 15, 2008 | Brother IntelliFax-2820 Laser Fax
Brother IntelliFax-2820 Laser Fax Logo
77 people viewed this question
James Cagle
James Cagle
ctnozil
Victorman
Victorman
