Question about Bosch 24 in. SHX99A15UC Stainless Steel Dishwasher
Bosch Dishwasher We just installed a new Bosch Dishwasher and are having trouble with the cycle. It will fill but the spinning jets do not spin and it seems to just skip that part then drain out. Is there a pump or something that makes those spinners go around?
    President:
  • 1,462 Answers
The spray arms are rotated by water coming out of angled jets, this water being forced round by the main circulating pump. suspect it may a fault with this pump
Posted on Mar 24, 2007
Please help! I just moved into a new house where the Frigidaire dishwasher worked great for 2 weeks. Now, it's leaving hard salt-like granules all over my dishes and not rinsing all the food off. ...
Your dishwasher has clogged water ports.
Start the dishwasher with NO dishes in it.
Once it starts the wash cycle,open the door and pour in 1 quart of WHITE vinegar and resume the wash cycle.
That should clear out the residue.
Change your dishwasher soap to the FINISH brand name for happy clean dishes.
Apr 28, 2011 | Frigidaire 24 in. FDB510LC Free-standing...
I have to initate the spinning of the sprayer arm.
uasally it isnt the spinning of the spary arm that does the fill it is controlled or a timed fill then the motor comes on if there isnt enough water in the unit it will not have enough pressure really need more info though
Jun 02, 2010 | Dishwashers
Intermittently Operating With Little or No Water
Most likely the water level detector (the sensor that tells the dishwasher to stop taking more water) is failing. It is giving early signals which confuses the dishwasher and it turns water off. Most of the time these problems are linked to grime collecting in the inside of dishwasher.
You can clean it by using a dishwasher cleaning powder. Follow instructions on satchet. YOu may have to manually fill the dishwasher before starting it. If this cleaning does not fix it, then you may have to call the technician. You may be under warranty on this (hopefully)
Nov 11, 2009 | Bosch 24 in. SGS09L02 Logixx Built-in...
My dishwasher is not draining
have you checked your float valve and float relay switch
Oct 09, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch Dishwasher with very little water pressure or power
It all stems back to your incomming water supply. Either the sieve is dirt or the valve is blocked with sedementation. Some valves are servicable and some are not,if your valve has screws then its revicable. (low water pressure restricts movement on arms.)
Sep 18, 2009 | Bosch 24 in. SHX46B05 Stainless Steel...
Maytag dishwasher.Loud humming noise, wash cyle,at beginning
Is the water filling up and then draining out? Mine did this and a part was broken inside the unit. The part was five dollars and called a lifter. I fixed it myself.
Jan 01, 2009 | Maytag 24 in. MDB3700 Built-in Dishwasher
Bosch dishwasher leaving residue
You either need a water valve, if the dishwasher isn't filling with enough water, or you need to run a dishwasher cleaner through it.
Apr 07, 2008 | Dishwashers
Spinning arms stationary
problem is usually debris in the end angled jet of the spray arm which is used to turn the arms. take them outy and patiently clean. very common problem
Apr 24, 2007 | Neff 24 in. S4443 Built-in Dishwasher
Bosch 24 in. SHX99A15UC Stainless Steel Dishwasher Logo
337 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
