Question about Numark Nuvj DJ Video Mixer
VIDEONICS MIXER MX PRO 3000--CAN NOT GET TO CROMOKEE
UNIT WILL NOT ALLOW ME TO GET TO THE PROGRAM TO ALLOW ME TO USE THE CROMOKEE FUNCTION. THE SPECIAL EFFECTS PART OF THE UNIT WORKS FINE. WE HAD LOST POWER IN THE ROOM. UP UNTIL THEN IT WORKED FINE. AS I SAID THE UNIT POWERS UP AND WORKS FINE EXCEPT FOR THE CROMOKEE FUNCTION.ANY IDEA OR WHO CAN REPAIR THIS UNIT. FOCUS-- THE COMPANY THAT MAKES IT DOES NOT SUPPORT IT ANYMORE. WE DID TRY THE RECOMENDED RESET OF THE UNIT BUT THAT DID NOT WORK. THANK YOU--MARK ROLAND --516-319-6081
No sound coming out on both r and l channel
Oops! Smoke from on of those is not unusual, as behringer is notorious for bad solder joints and BAD Power supplies. Anyhow the amplifiers are "most likely" OK. but your powersupply is shot. My PMH 3000 did the exact same thing. And here is the bad news. Behringer is also notorious for the lack of assistance in case of problems and will advice you to have the unit repaired at an approved service point. If however you are ok with electronics you can have a go yourself, manuals are few and (very) far between. I have some diagrams and stuff, so if you need some sing out. I have 2, MX 3282A mixers, nothing but trouble! Sorry I can't help you any further, Good luck.
Aug 13, 2014 | Behringer Europower Pmp5000 Powered Mixer...
I need a new fx push knob for eurorack ub2442fx pro
This place has a great selection of Behringer parts. You should be able to find your knob here: http://www.dbmproaudio.com/behrparts.html
Jan 10, 2013 | Behringer EURORACK UB2442FX PRO Mixer
HOW TO WIRE GEMINI GRAPHIC EQ 3000 TO behringer djx750 proffessional MIXER
Line level output of the mixer would go into the line level inputs of the EQ, and the EQ line level outpputs to the line level inputs of the amplifier. If you are faced with a mix of unbalanced inputs or outputs, to balanced inputs or outputs it gets a little complicated because you need to matrix the balanced signal to unbalanced load and vice versa. There is no single answer to doing this either.
RCA jacks are unbalanced, 2 conductor 1/4 inch connections are unbalanced most of the time. XLR and 3 conductor 1/4 inch jacks and plugs can be either balanced or unbalanced.If either are wired so left and right are a single ring or tip on the 3 conductor 1/4 inch jack, it is unbalanced and they would share a common ground lead. XLR wired with one pin common with shield and right and left have a single conductor on the plug or jack, that is unbalanced.
Apr 26, 2012 | Behringer Pro Mixer Djx750 Professional 5...
Would I need a mixer or amplifier with this product: Pyle-Pro Rack Mount 8 Channel Wireless Microphone System with 8 Lavalier/Headsets (PDWM8900)
The unit has a built in mixer as well as individual outputs. You would need an amplifier/speaker that could receive from teh mixed output jack of this. Use BALANCED TRS cable.
Aug 20, 2011 | Pyle PRO 19 RACK MOUNT PRO DJ MIXER SFX
Can I use a footswitch for the reverb, to allow me to switch it off when talking ON MY Behringer Xenyx 1202 FX
Sorry, the Xenyx1202FX does not have a footswitch input. I would suggest if this function is needed to use an external FX unit which has a footswitch input.
Apr 26, 2011 | Behringer Xenyx 1202 12-input 2-bus Mixer...
I have the Behringer Eurorack MX 2642A. Over 6 years old. The right main mix output sometimes works great and sometimes gets very quiet and distorted. Is it time for a new mixer or is there possibly a...
It sounds like one of the output devices is going bad, ie., output transistor, capacitor, resistor or maybe just a bad connection on one of the above menitoned items. One other problem which causes this would be the main or sub volume slider or pot is wearing out and needs to be replaced.It would definately be worth your while to have a technician trace down and fix the problem on this board. Hope this helps.
Feb 10, 2011 | Behringer DJx700 5-Channel Pro DJ Mixer...
Power cord get really hot.
If mixer is working properly, check the rating of the adapter versus what the unit requires. Some sites indicate this requires a 12 volt adapter rated at 1.2 amps.
Feb 08, 2011 | Vestax PMC-05PRO IV PMC-05 PRO 4 DJ MIXER
My behringer pmp 3000 has litle power i thing is 3000 or how much power it haveit? I put 2 speaker only ,,,, thankyou
The unit should drive 400 Watts RMS into a 4 ohm load per side.
The amount of sound power you get will VASTLY depend on speaker efficiency. You would likely use at least 15 inch speakers with the unit.
Aug 08, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
I need a fuse and fuse holder for my Behringer pmp 3000 mixer
It sounds like you need just the fuse carrier...
This is as close as I can find:
http://mouser.com/ProductDetail/Schurter/62002300/?qs=sGAEpiMZZMv1TUPJeFpwblxZ%252bgbqW48rbR6t5kzh87o%3d
The only way to get exact is to go through Behringer or get an exact part number and manufacturer.
Disassembling your unit to get at the part would be a lot of work. I have repaired three of these and am familiar with the unit.
May 12, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
LEVEL POT ON A BEHRINGER EURORACK MX 602A-BAD
It appears that both these use a 50K pot in the identical circuit and it is UNLIKELY they re-engineered very much so it is likely they use the same pot.
Behringer parts service should be able to tell you.
Apr 28, 2010 | Behringer DJx700 5-Channel Pro DJ Mixer...
Numark Nuvj DJ Video Mixer Logo
292 people viewed this question
Top Numark Music Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
rhodesworks
tmaree
tmaree
Are you a Numark Music Expert? Answer questions, earn points and help others
