Question about Pioneer DVR-111D (DVR111DBK) DVD RW Dual Layer Burner
Dvd freezes windows when a disk is inserted
I recently added a hard drive to my computer and attached it using the same ribbon cable as what my dvd writer was on then could not get the dvd drive to work so i disconnected the hard drive to solve the problem and the same problem persists. does anybody know what i have done to my dvd drive? has it had its last breath?
  • dan bentley Mar 24, 2007
    i took the hard drive off of the ide cable and tried it that way was recognised by the bios still was the same.
    President:
  • 2,961 Answers
If you have two drives on the same ide cable, one has to be set at master, the other as slave, the hard drive should always be the master. But you should'nt normally put a cd drive on the same ide as a hard drive as this will slow up the read write speed of your hdd. Make sure the ide cable is the correct way around, and that all the drives have been recognised in the bios. To enter the bios press f2 or del on boot up and see if all the drives appear there.
Posted on Mar 23, 2007
Ntldr missing what can i do?
first make sure there are no disks in any of the drives cd floppy and usb Computer is booting from a non-bootable source.
Computer hard disk drive is not properly setup in BIOS.
Corrupt NTLDR and NTDETECT.COM file.
Misconfiguration with the boot.ini file. Attempting to upgrade from a Windows 95, 98, or ME computer that is using FAT32
New hard disk drive being added. Corrupt boot sector / master boot record. Seriously corrupted version of Windows 2000 or Windows XP. Loose or Faulty IDE/EIDE hard disk drive cable
Failing to enable USB keyboard support in the BIOS. Many times this error is caused when the computer is attempting to boot from a non-bootable floppy disk or CDROM First verify that no FLOPPY DISKS or CD is in the computer, unless you are attempting to boot from a diskette
Test all power and data leads that attach to your hard drive including IDE,SATA
if ita flat 40 pin ribbon type it will be the first to fail
the leads from your MOTHERBOARD TO THE HARD DRIVE make sure they have a
secure dust free connections and are not faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections
a computer needs power and data to travel through every working device and continue its cycle and have an end so any faulty leads will end up with a computer error
hope it helps
Jul 12, 2012 | Acer Aspire 5000 5100 (804879236207)
Disk boot failure, insert disk
Test the leads that attach to your (hard drive from the motherboard) make sure they have dust free secure connections or replace all the leads that attach to your hard drive including electrical extensions + IDE SATA and the ones that attach from your (motherboard to hard drive) if its a 40 pin flat ribbon IDE this will be the first to fail
make sure all leads that are attached to your drives dvd\cd and floppy drive have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs continue its cycle power and data to travel through every working device and have an end point so any faulty leads will end up with a computer error
hope this helps you
Apr 27, 2012 | Epson >>> IM800 DARK GRAY 733 MHZ CPU...
I switched my IDE hard drive into another computer that is a little more up to date. computer boots, passes post, shows these options " safe mode, safe mode with networking and command prompt. start...
As the Windows installation is installed on the first computer hardware configuration and now it is moved to another computer hardware configuration, ie another computer. It will not work as Microsoft prohibits moving/changing hardware configurations to the extent of another computer system.
In your case you will have to return the hard drive to your original computer and then backup your files. Then this hard drive needs to be formatted, all data will be lost. Then the hard drive can be install in the better computer and a fresh installation may be performed. However you will need to read the terms and conditions of your Windows License Agreement to see if this is indeed possible.
With regards to the DVD drive, it needs to be connected on the IDE2 port, right at the end of the IDE bus/ribbon. There are 3 positions a longer length and 2 shorter lengths.
Long side plugs into the mainboard, the middle one is left open and the shorter end one is plugged into your DVD Drive.
Ensure that the jumper located between the power and IDE port of the DVD drive is set to the Master Position. The details can be found on the label on top of the DVD drive.
Thumbs up!
Thanking you
damnor01
Mar 15, 2011 | Microsoft Windows XP Home Edition
My computer says that the hard drive is not inserted correctly.what do I do
Open your computer casing and look for the ribbon cable attached to your hard disk drive and motherboard. Unplug the ribbon cable from the motherboard and hard disk drive. Then put it back again the cable and observe, if the problem is still the same. Next part is to unplug the ribbon cable from motherboard and hard disk drive and observe for the sound comes from your hard drive. Try also switching your ribbon cable into another IDE ports.Normal hard disk drive usually have a normal sound but the defective hard disk drive have a mechanical noisy sound. Have a good day.
Dec 02, 2010 | HP Pavilion a1220n (A1220NED904AA) PC...
My maxtor D740X-6l 40GB drive will not boot up. I can hook the drive up to another computer and read the files but it will not even show as a drive on the original computer. The first computer recognizes...
all you have to do is to simply set the jumper at the back of he hard disk, beside where the IDE cable and power enter into the hard disk.
Just keep setting till you put at the right position where the system recognizes it.
There is nothing wrong with your PC and hard drive, just set the jumper of the Hard disk and that should be all.
Take care.
Jan 04, 2010 | Maxtor Hard Drive
Adding old hard disk. 20 GB Quantum Fireball Ict, in Dell 9200 PC
if it's old it's probably IDE also known as PATA. it looks like a wide ribbon. There should be a header on the motherboard that looks exactly like the plug on the back of the hard drive. It will be labeled IDE1 probably if you have it. Old motherboards used to have 2 IDE headers, modern ones have one or none. The ribbon will have three plugs--one for the mobo, and then two spaced closer together for the master and the slave. You need to hook it to the appropriate plug (master if it's the only device on the ribbon) and make sure the jumpers on the HD are set properly to make it self-identify as the master. Good luck!
Nov 09, 2009 | Dell Dimension 9200 PC Desktop
How to format maxtor 80gb hard drive
Insert the drive into the bay and connect power and ribbon cable.
Go to Start > Control Panel > Administrative Tools >
Computer Management > Storage > Disk Management
Right click on the drive, click Mark Partition as Active then Format.
In this day and age, it's always best to format to NTFS file system.
Nov 06, 2009 | Maxtor Hard Drive
Ican't get a self installed floppy disk drive to work with Vista.
Reverse the data ribbon direction in floppy side (data cables pink color side should be plugged opposite to power cables color side)
Sep 25, 2009 | Teac Floppy Drive 235HF Internal Floppy...
Adding a 320g seagate drive to my dell pc
The ribbon-cable to the first hard-drive probably has one connector at each end, and one more connector in the "middle". Look very closely at both hard-drives. Between where the ribbon-cable connects and where the 4-wire power connects is a set of pins. Look for 'MA' or 'CS' or 'SL' annotations above/below each pair of pins. Remove the small jumper from each disk-drive, and put the jumper back into the 'CS' position on each drive. Make sure that the "first" hard-drive is *NOT* connected to the "middle" connector on the ribbon-cable -- connect it *ONLY* to the "end" connector. Restart your computer, and watch the first start-up screen -- it should report that *BOTH* disk-drives have been detected. When Windows starts, open "My Computer" -- both disk-drives should be listed.
Jun 08, 2009 | Maxtor Hard Drive
It will boot up to the windows screen and freezes.
If your computer was able to boot up but unable to load the Windows, the most common cause would be the recently intstalled software or Windows update.
To remove this, follow these steps. Skip Step 1 if it is not relevant.
Step 1: Removing recently added hardware
Use the steps in this section to disconnect any recently added hardware and test for the error.
NOTE: If a new internal device (sound card, hard drive, or other) was added to the computer before the error message started to occur, you have to remove it before continuing.
  1. Turn off the PC and unplug the power cord.
  2. Disconnect the mouse, and any other peripherals attached (Printer, scanner, webcam, zip drive, phone cord, network cable and other devices). Leave only the keyboard and monitor cable attached.
  3. Press and hold the power button on the front of the PC. Release after 10 seconds.
  4. Plug the power cord back in.
  5. Turn on the computer.
  6. The computer displays the We apologize for the inconvenience... message. Allow the timer to count down from 30 to 0.
  7. If the computer successfully starts to the Windows desktop and does not restart to the error message, connect one device and wait until Windows recognizes it.
  8. To find if a device is causing the error, continue connecting the devices, one at a time, restarting the computer each time, until the device that is causing the error is found.
NOTE: If this does not solve the issue try to do a system restore BUT it will delete all your files and programs you install by yourself after the system. You will be able to use the pc as a new pc.
Jan 25, 2009 | HP Compaq Presario SR2011WM PC Desktop
Open Questions:
Pioneer DVR-111D (DVR111DBK) DVD RW Dual Layer Burner Logo
42 people viewed this question
Top Pioneer Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Computer Links
David
David
Are you a Pioneer Computer and Internet Expert? Answer questions, earn points and help others
