Question about La Marzocco FB70
Water at group heads needs be hotter
How do I increase the temperature of the water at my group heads in my LaMarzocco Linea Semi-automatic?
    President:
  • 1,618 Answers
Check the top of the coffee boiler you will find the thermostat for setting the temp, you will probably have to remove the front panel to access it.
Posted on Mar 26, 2009
How do I increase grouphead pressure on la marzocco linea 2 group?
To increase dispense pressure you turn the adjustment screw at the pump. When pulling a shot (use espresso) on one group the bottom needle of the gauge should read 9bars while pulling the shot.
Dec 16, 2010 | La Marzocco Linea Series Group 3 Espresso...
The left group head on my GB5 is not engaging.
Remove the diffuser screw and screen and check the holes in the screws, they might be blocked, press brew button with screen removed to see if you have water flow.
May 06, 2010 | La Marzocco Linea Series Group 3 Espresso...
I believe I have a delta monitor shower faucet. I am wondering why the hot water pressure is less than the cold water pressure. Also, I am wondering what size hex head I need to remove the lever so I can...
It takes a 1/8" allen wrench to remove handle. To increase hot water flow remove plastic dial that sets temperature. It is right behind handle and slides off stem for easy adjustment.
Remove indicator and replace about 1/8 to 1/4 turn counter clock wise to increase to hotter temperature.
Apr 26, 2010 | Delta & Single Handle Shower Faucet
Need to increase the water temperature moen 270/3371
Remove handle, now you should see two white plastic pieces one slid inside the other. The inside piece should look like a gear. If you slide it out and rotate to the left a couple of teeth this will allow for handle to advance farther and in turn give you hotter water.
Jan 30, 2010 | Moen TL3450/3600/3371 Kingsley Handle Tub...
Temperature control on Saeco magic deluxe
No it cannot. I am not sure why you would want the water hotter. It is designed to be at the perect temperature for passing through the brew group for coffee brewing, its kind of a simple science.
If your machine has been producing less hot coffee gradually, that marks an issue. Try descaling the boiler per the manufacturer's inscrutions even if the warning light isnt on. The other option is that the thermal fuse mounted to the boiler is bad and turns off the boiler prematurely, those cost about $15 and are simple to replace. Lastly, the boiler heating element may be 'burnt out' new boiler is $120+
Aug 15, 2009 | Saeco Magic De Luxe Espresso Machine
Grouphead not dispensing water
Remove the shower screen and press button to brew, if water flows the the holes in the screw/diffuser is blocked, if water does not flow then the blockage is at the solenoid or within the group head chamber. This problem I have notice when someone brewed without the shower and screw in place.
Jun 29, 2009 | La Marzocco Linea Series Group 3 Espresso...
Buzzing Espresso Machine
that noice is from your solenoid valve during brewing coffe.
  1. as first you should clean the group with blind filter and special detergent for washing coffe from group. if you didnt do this long time you should repeat the cleaning 3 - 5 times same day.
  2. if you follow the 1st instruction but you have the problem again you should change your solenoid valve.
Mar 18, 2008 | La Marzocco Linea Series Group 3 Espresso...
Unable to programme La Marzocco
hello
you need to check your flor meters. they could be scaled or dirty. you need to dismantle flowmeter that is on the side that is not working and clean it. make sure the water main is off and power is shut off. hope this helps.
Feb 29, 2008 | La Marzocco Linea Series Group 3 Espresso...
Coffee Makers & Espresso Machines Logo
192 people viewed this question
Top La Marzocco Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a La Marzocco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
