Question about Alpine CDA-9884 Car CD/ MP3 Player
NO sound! When I turn on unit all I hear is a click in speakers.
    Sergeant:
  • 233 Answers
Disconnect all 4 speakers, make sure the speaker wires dont touch each other...turn on th stereo and re-connect the speakers one by one.. if you connect one particular speaker and it makes the sound mute, then that is your bad speaker, and / or wiring.
Posted on Dec 19, 2008
Kenwood A722L no sound and volume led blinking
This could be due to a faulty speaker relay (if your unit uses one). Normally, the unit will "wait" a couple of seconds after you turn the unit on. Then you will hear a "click" and the sound will begin coming through the speakers. If the relay is faulty, it would cause the problem you describe.
Aug 01, 2014 | Kenwood Audio Players & Recorders
ITRR-501 NO SOUND DIAGNOSE
I was asked to further clarify problem, but not much to add when there is absolutly no sound it is called silence from the speakers when unit is plugged in, turned on (sounds like speakers engage) one of the five choices is chosen to listen to and no sound comes forth to hear. How can I get inside the unit and check to see the speaker connections?
Sep 30, 2012 | Innovative Technology Elect IT 5-in-1...
Unit powers up, cd and radio seem to be operating properly, but no sound is heard, unit worked fine a few days before, all wires are conected, everything seems unchanged
Well...as you said...the unit powers up...so you don't have a "dead set".I don't know if the speaker can be disconnected from the unit.As a rule of thumb...it is very rare that both channels (left and right )fail at the same time...it is usually one channel while the other speaker still operates.This is what I want you to do...In a quiet room..get really close to the unit...Switch it on and listen for any sound from the speakers...get really close...you should hear a slight hum from the woofers and a high frequency "hiss" from the tweeters....If no sound is heard..switch the unit off..You should hear a "plip" sound...If not...switch it on again...you should hear a slight "bump" sound from the woofers...If you hear no sound from the speakers at all..there is a problem with the output stages of the amplifier section.If you do hear sounds fron the speakers,,Turn up the volume and watch for an increase visually on the display (such as ascending numbers).If there is no indication of a volume increase...The "mute" may be stuck on..Try switching it off and on...please let me know what happens after you do all the tests....Looking to hear from you......PEACE!!!
ok...
Jul 11, 2011 | JVC HX-Z3 CD Shelf System
My rx-6000v acts like every thing is fine but can not get any sound. not even out of earphone jack. got any ideas?
It sounds like this unit is in protect mode. See hte link below for more info on that. One thing to check: turn the unit on paying particular attention to any clicking that you hear. You should hear an initial click as the unit turns on followed a few seconds later by another one. The second click is the speaker protection relay. If you don't hear the second click, then the unit is likely in protect mode. Feel free to post additional questions after review of the link information below.
Dan
Link: http://www.fixya.com/support/r5390728-protector_means
Mar 15, 2011 | JVC Audio Players & Recorders
No audio from input plug? but when I turn the unit on/ off swich I hear the a sound from speaker.
unplugged the input plug from your pc, turn on the power on your speaker, set the volume at about 2 o'clock, touch the tip of the input plug with your bare finger( don't worry you will not be electrocuted, no dangerous voltage is present on these part) you should hear a hum, or better yet plug it on your I-Pod, if you don't hear a sound, chances are the chip inside is busted. Qualified technician required or have the whole unit replaced. hope this helps ;-)
Feb 03, 2011 | Altec Lansing MX5021 Computer Speakers
Clicking sound from Dell Speakers
How "often" does it click?
Internet Explorer does a "click" everytime you access a new web-page -- turn your speakers up/down to increase/decrease the sound.
Apr 25, 2010 | Dell 5650 Computer Speakers
No sound from htr-5840 when switched on. I hear
These units have protection circuits that will prevent the speaker relay from engaging if there is a problem detected. There is also a circuit that causes a delay in the engaging of the relay to allow the amp to "settle in". This prevents the old "thump" that was common in older models when the set was first turned on. In your case, either the RC circuit is faulty causing excessive time to pass before turning on the relay, or there is excessive voltage floating around that the protection circuits are detecting and thus preventing the relay from turning on.
In any case, this will require additional diagnosis using some test equipment. This is not a problem that will be easily resolved remotely. Please bring this unit to a repair shop for an estimate. Once you have that info, we can assist with the actual repair.
Dan
Aug 25, 2009 | Yamaha Audio Players & Recorders
Won't power up; push power button on, hear click in back left of unti, get nothing on front display and no output from speakers; as if unit trying to operate
Disconnect the speakers and see what happens. Carefully examine the speaker cables for unwanted connections (shorts).
Take a clue from when the power problem appeared. Something was moved and made the buzz a (probable) dead short.
May 16, 2009 | Pioneer VSX-305 Receiver
Harmon kardon avr 25 II
hey i also had this problem, i don't know the name of these but they are basically plugs that you have to block output from the front rear and center speakers of the white/red cables... sry for bad description but its on the left side when looking at the back of the receiver, while all of the other speaker wires should be hooked up to the right with the twisting knobs... it took me forever to find this out but yeah it was a simple fix
Oct 28, 2007 | Harman Kardon AVR 25 MKII
Alpine CDA-9884 Car CD/ MP3 Player Logo
116 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
