Question about Dell Inspiron 9400 Notebook
My dell 9400 wont.....
Start when power is pressed. All it will do is run the windows loading screen and then it goes dark gray and thats it.~Its about a year old and out of warranty!~HELP!!!!~
  • 229 Answers
The impoortant thing is if the pc will P.O.S.T.? (This is what its called when the motherboard performs its initial checks) If it is making it past the dell screen and then goes black there is a component that the motherboasrd is getting that just malfunctions and causes the blackout. Most common is a bad hard drive, bad battery, or bad ram
Try switching through thesre and see if that fixes you r issue
Posted on Mar 26, 2009
My dell vosro 1000 screen goes dark but if i shut the lid then it lights up for a few for minutes what could be wrong with it any suggestions
Sounds like a short in the inverter. Remove the bezel around the screen the long thing on the bottom is the inverter if there is a foil heat shelid close by cut some of it away from the inverter
Mar 29, 2013 | Dell Inspiron 9400 Notebook
I have a Dell Studio XPS PC. Recently, my PC monitor screen began to show all sorts of square spots and vertical lines and horizontal lines with a distoration of color and graphics. Now the Windows 7 will...
try starting it in safe mode....you do that by pressing the F5 key before windows starts up.. like right after you turn it on...once your in safe mode do a real good virus scan..i have seen that happen and it was a virus
Aug 15, 2012 | Dell Inspiron 9400 Notebook
Have a Dell Inspiron 9400, when running off the battery the LCD is perfect, as soon as I plug into power the screen goes black. Ive tried multiple power supplies and still the same result?????
you may need to change your power settings. it sounds like when you plug it in it goes into a mode thinking there is another monitor hold the FN key and press a key usually f5 that looks like a computer monitory. anyway plug in the pwoer cable, and hold fn and press the key that looks like a computer monitor maybe twice until the monitor comes back on let me know if that works!
Mar 17, 2011 | Dell Inspiron 9400 Notebook
My dell latitude d620 has gotten the BSOD and wont load up
insert your windows cd, start your computer, press any key to load from cd and there will an option to restore or recover the operating system
Jan 21, 2010 | Dell Computers & Internet
When i start my Dell 9400 up and it takes 10 mins to load to windows XP, , when the windows loading screen comes up the FANS go crazy. I then wait till i'm at the desktop at which point i immediately shut...
Your battery HAS to stay in if its not working which means the OS needs the extra power.
If your fans are going crazy then your laptop is overheating!!!
Contact Dell
Dec 30, 2009 | Dell Inspiron 9400 Notebook
I have a dell Inspirion 9400 and it won't start. When I press the power button, all that happens is the power light and the dvd player light comes on and about 3 seconds it turns off. Does it with and...
It shows no power on your laptop but it shows you the dvd player led comes on then off. I would suggest try the following:
1. Remove laptop battery, optical drive, hard drive and ram. Remove external peripherals as well. 2. Make sure AC Adapter is not yet connected to the laptop. Press and hold on the laptop's power button for 10 seconds to drain the power flea. 3. Connect the AC Adapter to a known good power outlet, check AC Adapter power LED if it is on. Try to sense if AC Adapter is not making a bit of noise when it is plugin to the wall power outlet. 4. Connect now the AC Adapter to the laptop. Check if AC Adapter LED stays on when it is connected to the laptop. If the LED stays on means the AC Adapter is fine. If the AC Adapter LED turned off check the AC Adapter pin that goes to the laptop AC socket if it is loose. 5. If AC Adapter stays on after connecting to the laptop try to power on laptop. If no power LED comes on then this is motherboard problem. 6. Before replacing the motherboard there is one checking needs to do. If you can open your laptop bottom part then good, do this when laptop is not connected to any power source. Try to reseat the laptop CMOS battery then try to power on laptop after, if still fails then replace motherboard. I hope this helps.
Dec 12, 2009 | Dell Inspiron 9400 Notebook
Dell vostro 1500 screen goes dark
Check the power options to verify that the screen is not powered down after to short a time. It is in the control panel under power options or in a Dell management utility
Sep 03, 2009 | Dell Inspiron 9400 Notebook
Dell inspririon 9400 wont start
(before you do anything remove the battery and th ac plug)remove the memory inside small door on the backside that has a "M" on it now once you remove the memory install the battery, power on if you hear a couple of beep tones you are half way there the motherboard is good so the problem is what you took out so there are two memory slot try them in the A slot one at a time.If the problem is memory replace it.
Good luck
Aug 29, 2009 | Dell Inspiron 9400 Notebook
Screen is dark
Hi Yacob
First Run a diags on the dell laptop. You can initiate it by pressing fn+power button together and start the laptop. It will go to the diags screen. Tell me if the diags pass or not and then we will troubleshoot further.
Thank you
Rakesh
Dell Laptop Expert
Jan 06, 2009 | Dell Inspiron 1501 Notebook
E153fp goes dark into power save mode after Windows start up
may be your power saving option have small time .
check in control panel power option check power shemes.set it to 20 minutes.
Nov 27, 2008 | Dell E153FP 15" LCD Monitor
Dell Inspiron 9400 Notebook Logo
95 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
