Question about JVC TD-W354 Single Cassette Deck
NOT RECORDING WHEN USING MICROPHONE
When recording from input device on rear of deck, tape records with no problem. When using microphone, no recording taking place, yet rec light is working and nothing seems wrong.
    Genius:
  • 1,199 Answers
Is the mike turned on///broken? test the mic to make sure its not the problem! it could also be mic jack!
Posted on Dec 17, 2008
    Problem Solver:
  • 5 Answers
You should hit the play/record to record the signal..observe if the tape is moving..
Posted on Jun 07, 2014
How can I use a hand held stereo microphone to record via a Denon F101 tape deck
You really need to include all brand and model number info for this question.
Feb 03, 2015 | Denon Audio Players & Recorders
Reel to reel wont record with microphone
When I put a tape in and press play, the spools will not turn. There is power, but it won't play the tape. It's like the turning spools are stuck .
Feb 28, 2014 | Audio Players & Recorders
Can I use a microphone through a technics rs m216 tapedeck?
The tape deck was designed for stereo recording using two separate mikes, one for left input and one for right input
Jun 28, 2012 | Technics Audio Players & Recorders
Can't record on cassette deck from lapel mike as Pastor preachs service.
Does the deck have an input for a microphone?
If not, buy a microphone pre-amp. Or a recorder that has one built-in.
Jun 04, 2012 | Toshiba Sony TCWE475 Single Dual Cassette...
How do I get it to record a voice?
Many portable 'boombox' recorders do not include a microphone for recording ambient sound, but can only record from one internal source to another, like radio or CD to Cassettte. Some do include an input jack for microphones or other audio sources, but you'll need to check your device's specs/ports to be sure.
May 18, 2011 | Sony CFD-F10 Radio/Cassette/CD Boombox
I have a Technics Double Cassette Deck RS-TR212. On the rear it has Output and Input connections. Output goes off to the Amplifier. Can the Input be used to record or play from a record Turntable? I have...
your receiver has (or should have) input and output connections,, your turntable needs to be hooked to the receiver,, then with the output cables that feed your cassette player you need to go, in to out and out to in ( receiver output to the input of the tape player, and out of the tape player to the in on the receiver, while playing a record if you hit record on the tape player it will record the record, depending on the receiver it will show you the meter readings for either the in or out,, they vary
Apr 11, 2011 | Audio Players & Recorders
Fails to record sound either by microphone or through external recorder tape
goto <START> then <control panel>
<sounds and audio devices>, then <AUDIO>, on there check to make sure under Sound recording, that the correct device is selected... also check on your soundcards mixer program that you have selcted microphone as the input device!
May 17, 2009 | Intel D101GGC Motherboard
Connections for a Grundig reel to reel tape recorder
Grundig TK23
Inputs at rear of machine. From Left to right.
Circle with line underneath. (Micro socket) - microphone, mixer (Grundig 607), telephone adapter.
Square with line on top - Radio input/Output. Record/playback radio. Record records if player is connected to radio for playback via a 3-pole amplifier unit. Re-recording to a second tape recorder. Connection to a Grundig Stereo-Mixer 608.
Reversed Q - Phono Input. Connection to a record player or a second tape recorder. (for re-recording records or tapes)
Squiggly lines - Outputs. - Connection to external speakers. Grundig Stereo Box. Connection to an additional amplifier (Grundig 229) for synchronous recording.
Square with line at right. - Earphones.
Loudspeaker switch - (At bottom) - In the "0" position, the internal speakers are shut off.
Dec 30, 2008 | Audio Players & Recorders
Difficulty with recording
It sounds like you have connected the two correctly. I can only imagine that you need to check that the hifi source selector is switched to that line-in, it may be referred to as AUX. Check that the recording level control is not at zero on the hifi and if there is a volume control for line-out on the tascam. If you are able to listen to the recording on via the hifi then you are halfway there even if it doesn't get to the hifi recorder. If your hifi is a seperates system then you could try plugging the tascam in to the CD input on the amplifier.
Oct 09, 2007 | Tascam Starter Pack for 4-Track Cassette...
JVC TD-W354 Single Cassette Deck Logo
110 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
