Question about Acer 22" X223w LCD Monitor
New install Acer x223w monitor
Is there any reason that I need to attach the VGA cable if I'm using the DVI cable? The manual seems to indicate that both should be connected.
Many Thanks
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Acer Master
  • 848 Answers
New install Acer x223w monitor? This trouble maybe power supply or inverter boards is defective.
first you can test the voltage of the multr,and then check which part is defective.From Wisiny.com can find those parts
if you have any question,please let us know email:service@wisiny.com.thanks,we sincerely hope we can help you!
you can also check this boards whether suit you:
715G2892 2 3 Acer PWTVAC21MQDL Power Supply for X223W
Posted on Nov 30, 2014
    Sergeant:
  • 237 Answers
You would only need that cable if the other end requires a VGA end. Happy Holidays
Posted on Dec 17, 2008
My monitor is shifting to the left and now it won't go back. It is a acer model x223w
test with dvi cable or other vga cable first. sometimes bios may cause this problem.
Jul 30, 2016 | Acer 22" X223w LCD Monitor
I have an Acer Monitor X223w - is it capable of hooking up as a douple monitor to one computer?
Any monitor can be used as the second monitor for a computer. However, your computer's graphics card must have two outputs. Some simpler graphics cards, most on-board video chipsets and all laptops *do not have* two outputs. Please check the back of your computer for two VGA outputs, or one VGA and one DVI output (you can use it by connecting a DVI cable to your monitor, or by plugging in a DVI to VGA adapter).
If your graphics card does not have two outputs, or if your computer uses an on-board video chipset, you can buy another graphics card to replace the one you're using.
Mar 03, 2011 | Acer 22" X223w LCD Monitor
Im not sure if i am supose to plug the dvi-d in cord in and the vga-in cord to
Your video card needs to have DVI output port for you to use the DVI cable, otherwise you can just use the VGA cable.
DVI is supposedly t give better pictures due to all digital signals compared to VGA which is analog.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Dec 21, 2010 | Acer 22" X223w LCD Monitor
My acer x223w lcd monitor is flickering. When I change the resolution to 800 x 600 it stops. I have updated the driver and tried uninstalling and reinstalling.
hi, have you checked running the monitor on all the outputs? dvi? vga? flickering is caused most times by bad connections either in the video cable, or on the video board, or power board inside the monitor. i know those monitors pretty well, i'm willing to bet if you opened up the monitor and looked at the power supply board, you would probably find worn/blown capacitors. this could very well account for the flickering. electrolytic capacitors store power for parts of the circuit that require lots of power to run. when they go bad(overheat) they pop up at the top, sometimes leak a little fluid. they are replaceable, need to be soldered in, and you can find them at most electronic stores abundantly, but you should check everything else first, the video cables(dvi,vga) before opening the monitor.
Apr 28, 2010 | Acer 22" X223w LCD Monitor
I have just installed a Acer LCD #X223W moniter. What do I need to do to get my speakers to work with it? Is there a missing port or do I need a new cable. This moniter has a HDVi cable but the Computer...
Did you give the correct model of the Acer monitor you have?
When I looked up the X223W monitor, I see a monitor with a DVI-D port and VGA port. Only the VGA cable is usually included in the box. If your computer has a VGA port (most older computers that came with only the video chip on the motherboard), you can either use the VGA cable or get a VGA to DVI adapter and use a DVI-D cable (purchase separately). Alternatively, check the specs of your power supply and available card slots and buy a new video card with a DVI port. If you have only a DVI port on your computer, get the DVI cable (the VGA to DVI adapter would work but isn't a good option).
If I read the specs correctly, this monitor doesn't have speakers. You should plug your speakers into the audio out of your computer. If you use the on-board audio you will see at least two jacks (microphone/line in) and audio out (speakers). Many audio cards and some motherboards come with additional jacks for surround sound so check your system information. Audio extension cables are a cheap solution if the speaker cables are too short to reach to your computer.
I hope this helps.
Aug 05, 2009 | Compaq Presario 5000 PC Desktop
My new acer X223W monitor has power and display however it does not recognize the signal coming from the tower. I have tried starting them both at the same time as well as starting the monitor first. I'm...
Try plugging in the USB port as well.
Also, your monitor priority settings may need to be configured so that your CPU and GPU card know where to address their data to.
I presume you've installed the monitor's drivers if XP or earlier?
If 7 or later, your Win drivers and INF files should find a compatible driver in the built-in database library.
I don't have an Acer X223W, so my USB tip is based on my AOC wide-screen LCD, which without the USB is semi-intelligent.
I think VGA supplies the RGB video, while USB sets resolution, sync, etc, and digital addressing.
Nov 20, 2017 | Acer X223WBD Monitor
I HAVE THE SAME QUESTION REGARDING THE acER MONITOR I just bought Is x223W LCD Monitor compaatible with IBM towers. Acer Has one extra cord Andmy Ibm tower has no home for it Please respond
well that Would be a VGA Cord(BLUE COLOUR) which u have connected the other one with the white port will be DVI port.if u want better Display connect ur LCD with DVI port.u will usally find this port on a graphic card.
May 13, 2009 | Acer 22" X223w LCD Monitor
Do you need to hook up both the vga and dvi cables from the monit
No, either cable will work if you have the socket on your computer.
Jan 04, 2009 | Acer 22" X223w LCD Monitor
I can not get the higher resolution on my Acer 22in X223W
Monitors have Max resolution. What you call VGA is not really VGA, the standard for VGA is 640X480, SVGA is 800X600 and XGA is 1024X768. VGA and DVI are capable of different "GAs". Consequently you are not able to go beyond the capabilities of your monitor. Right-Click on a blank area of your Desktop and click on Properties. Then click on the Settings tab. Move the slide all the way to the right and that will be the maximum resolution for your monitor.
Dec 25, 2008 | Acer 22" X223w LCD Monitor
Acer X223W flickers using DVI cable, but ok with VGA!!??
Acer X223W flickers using DVI cable, but ok with VGA!!?? This trouble maybe power supply or inverter boards is defective.
Dec 19, 2008 | Acer 22" X223w LCD Monitor
Acer 22" X223w LCD Monitor Logo
173 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
