Question about Lexmark Wheelwriter 5 Series II Typewriter
/? KEY IS INSERTING RANDOMLY AS I TYPE AND ALSO CAN STICK
/? KEY STICKS AND TYPES "ON ITS OWN" REPEATEDLY, LIKE...
UNTIL I HIT THE RETURN KEY
  • colleens190 Dec 30, 2008
    Thanks for your help, unfortunately there are no repair people within our state and so we will be disposing of the typewriter and replacing it with a printer.
  • Lexmark Master
  • 3,594 Answers
You may be able to make a temp repair by popping the / keytop off and using it that way until you have the keyboard replaced.
DickyO
Posted on Dec 30, 2008
    Scholar:
  • 183 Answers
No easy fix on this one. the keyboard is going bad and will have to be replaced. take it to a repairman
Posted on Dec 18, 2008
When first starting to type the first key sticks and types same letter 7 times.
Open Keyboard in Control Panel
on the speed tab make changes
To adjust the amount of time that elapses before characters repeat when you hold down a key, drag the Repeat delayslider.
o adjust how quickly characters repeat when you hold down a key, drag the Repeat rate slider.
Apr 24, 2013 | Computers & Internet
When I type a letter on keyboard it keeps repeating the letter
The key might be sticking down, which is probably a defect in the product. I tested an ihome keyboard (Bluetooth) and everything except the spacebar was prone to sticking itself down, no pop spill or nothing. So, I recommend to return the keyboard if you still have the receipt and get a Bluetooth Apple keyboard instead, as ihome is good for their docks, but their keyboards suck!
Feb 02, 2013 | iHome Bluetooth Keyboard for iPad 1 & 2,...
Dora 204 SP Olivetti Typewriter I have an intermittent sticking returns key Causes paper to run on. Can I do anything about it, or can you tell me of a Service Centre in Hampshire n UK.
hello
take Q-tip cotton , apply small portion on hammer letter keys and carriage -- moving parts only
dip and smear into vasaline, wipe off excess. apply to the keys sticking or to carriage return key . this is amechanical sticking , so apply to where the part (carriage or moving part) applies. Also, take a plain paper , keep tapping the key and then return key carriage , until sticking stops and until the vasaline dissipates . repeat the typing for about 1-2 mintes until excess vasaline is no longer present on paper after typing.
repeat this process anytime the keys stick
hpe this helps
Nov 14, 2010 | Office Equipment & Supplies
My other laptop keeps repeating the letter I press like when I go to google search and type 'h' it will go hhhhhhhhhhhhhhhhhhhh forever and not let me type anything or delete.
Hi, this is a common problem with sticking keys, caused by a spillage i.e a drink onto the keyboard. The keyboard will need cleaning or replacing.
Aug 07, 2010 | Computers & Internet
Keys on keyboard don't register when I type, also they stick
Well like you said 2 months old only claim the warranty and have it replaced with a new one.
Dec 15, 2009 | Logitech Wireless Access Duo Optical...
I have a memory Stick PRO Duo 4GB
YEAH, YOU MAY NEED A MEMORY CARD READER to read your memory stick. because some compters have not all type of card slots. the card reader will solve your problem.
Feb 10, 2009 | Sony 4GB Memory Stick PRO Duo Memory Card
Booting from a USB Stick
Here you go:
Download the Ubuntu Live ISO (if you dont have it already) and burn it to CD
Restart your computer (booting from the Ubuntu Live CD)
Insert a 1GB or larger USB flash drive
Open a terminal window and type sudo su
Now type fdisk -l to list available drives/partitions (note which device is your flash drive Example: /dev/sdb). Throughout this tutorial, replace all instances of x with your flash drive letter. For example, if your flash drive is sdb, replace x with b.
Type umount /dev/sdx1
Type fdisk /dev/sdx
type p to show the existing partition and d to delete it
type p again to show any remaining partitions (if partitions exist, repeat the previous step)
type n to make a new partition
type p for primary partition
type 1 to make this the first partition
hit enter to use the default 1st cylinder
type +750M to set the partition size
type a to make this partition active
type 1 to select partition 1
type t to change the partition filesystem
type 6 to select the fat16 file system
type n to make another new partition
type 2 to make this the second partition
hit enter to use the default cylinder
hit enter again to use the default last cylinder
type w to write the new partition table
Type umount /dev/sdx1 to unmount the partition
Type mkfs.vfat -F 16 -n usb /dev/sdx1 to format the first partition
"Alternately you can try mkfs.vfat -F 32 -n usb /dev/sdx1 (doesn't always work)"
Type umount /dev/sdx2 to ensure the partition is unmounted
Type mkfs.ext2 -b 4096 -L casper-rw /dev/sdx2 to format the second partition
Remove and Re-insert your flash drive
Back at the terminal, type sudo apt-get install syslinux mtools
Type syslinux -sf /dev/sdx1
Restart your computer, remove the CD and boot back into Windows
Using Windows to prepare and move the files to the USB Stick:
Create a folder named USB on your computer
Download UBconvert.zip using this link - http://www.pendrivelinux.com/downloads/UBconvert.zip
Now, extract the files to the USB folder
Move the Ubuntu  ISO downloaded earlier to the USB folder
Click fixu.bat from the USB folder (follow on screen instructions)
Move all files from the ubuntu directory to your memory stick
Reboot your computer and set your system BIOS to boot from USB-HDD or USB-ZIP. Also set the "Hard Disk Boot Priority" if necessary.
You should now be booting into Ubuntu Linux from your USB drive!
Dec 28, 2008 | Toshiba Satellite R15-829 Tablet PC
Memory card.
Supported Flash Memory Cards: CompactFlash Card type I, CompactFlash Card type II, Memory Stick, Memory Stick PRO, Microdrive, MultiMediaCard, SD Memory Card, Memory Stick Duo, xD-Picture Card, Memory Stick PRO Duo
Your phones card is a RS-MMC type not combatable, wont fit, no eject on printer, card too small for slot, wrong type
Power off carefull tweezer hunt or bluetac on a match, happy hunting
Oct 19, 2007 | Office Equipment & Supplies
Lexmark Wheelwriter 5 Series II Typewriter Logo
51 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
