Question about Panasonic DMR-E55 DVD Recorder
I want to transfer all files on DVD recorder to PC
What is best way to extract files given that there is no USB port, just usual RCA - outs etc??device is Panasonic DMR-EH65
  • 185 Answers
There is no function on the EH65 to back up your files to your computer or an external drive.
The only thing you can do is transfer your cherished files to DVD-R then put them on your computer. Any other way, like playing the file and re-recording on your computer will result in poor reproduction.
Posted on Dec 29, 2008
I want to transfer my video to my computer to burn a DVD. What is the parts number for a USB cable for VL-A110U camcorder?
There are no USB cables for analog camcorders. USB is a digital protocol.
You can get videos from this camera, or any analogue video source, into a computer, but you need more than just a cable. You have to play them into an analogue video interface port. These are available as expansion slot cards for a desktop PC, or as a USB plug-in interface (usable on a laptop). The interface will come with drivers and probably software to digitise the video input and record it to a file. Lots of third party video editing software will also be able to accept the input from this kind of port. You don't need any "driver" related to the camera, it is just a video signal source. The connecting leads will be standard RCA signal plugs, like the ones you use to connect to a TV or VHS recorder. You probably already have a lead for this.
Once you have the video on the computer, you will need DVD "Authoring" and burning software, which will usually come as part of the same package. You can download such software for free from the internet- my first stop would be www.download.com.
Jan 24, 2011 | Sharp Viewcam VL-A110U Camcorder
Is there a way to hook up a usb cable to a Sony Handycam DVD205?
unfortunately,no. the dvd camcorder was designed for easy dvd disc recording w/o usb or computer connectivity (it doesn't have usb port for connection). comparable models that has the usb jack are dcrdvd305 aqnd dcrdvd755 (which cost more). but don't loose hope.other options to transfer videos from cam to pc is by using the dvd disc (make sure you finalize it) and your computer's dvd drive (make sure it has supports 8cm disc and the disc tray in the right orientation to take the disc so it won't fall out). once inside the drive.open or explore the disc and copy and paste video files saved on the usual video_ts folder or the .vob files. if you need to playback the copied files you can simply change the file name to .mpg or use a file conversion software (which you can easily download for free online, use free file conversion as your search phrase) to convert files to a file format you need for editing purposes. another way to go is to use the supplied a/v cable. this type of connection would need a supporting software and hardware installed in your computer. an a/v capture card should be installed and a compatible video capturing application would be needed. hope this helps.thanks:)
Jun 01, 2010 | Sony Handycam DCR-DVD205 DVD Camcorder
Transfer the video from my Mini DV to PC
If you have a dvd recorder, you can hook up the cam to a recorder if it has rca jacks on the end of the cable.
Or if your handycam has a memory card slot, record straight to memory card or transfer memory to memory card, then place it in a computer with an sd memory card slot.
May 17, 2010 | Sony Handycam DCR-PC9E Mini DV Digital...
Hi am wanting to put some footage from panasonic sdr h40 onto computer
Your Panasonic camera has a USB port on it as associated by the accompanying cable that plugs into it and has a USB end on the other cable. Note that if your videos are on the SD card, you can take it out and put in your computer via a SD adaptor to USB. The hard drive files though are a little more tricky... you have to have the camera being fed by the AC adaptor instead of the battery.. (it looks like the battery and plugs into its hole on the bottom with a cable hangiong out that plugs into the battery charger.. You will not be able to transfer the files unless you have this power configuration.. this is to keep the transfer from being disrupted by running out of battery power. The files are MOD files which are MPEG2 files just renemed. You can rename them to MPG instead of MOD once you copy to the computer. The USB connection forces the PC to make a drive letter for the hard drive in the camera. I hope that helps out
Than ks!
STan Skaggs
Oct 29, 2009 | Panasonic SDR-H40 HDD Camcorder
CANNOT TRANSFER AUDIO FILES FROM WS-100 OLYMPUS VOICE RECORDER TO PC (Windows XP)
I wrote this for the Olympus VN-3100PC although it may work with this device as well.
Try this:
This problem can typically be solved by unplugging the device from your computer's USB port and plugging it in to another USB port on the same computer.
Also be sure you have Olympus Digital Wave Player installed and open with your Transfer Options set to Auto Transfer. To do this, follow the steps below:
Open Digital Wave Player > select Transfer from the menu > select Transfer Options > under Auto Transfer, check the box which reads "Transfer all audio files after detecting Recorder."
Mar 04, 2009 | Olympus WS-100 Digital Voice Recorder
Connect DVD recorder to Video player/recorder- transfer VHStodisc
hook the video output from vcr to dvd input at rear, then hook output from dvd to tv input. note; you can not record protected vcr movies you can only record tv shows from sattelite to vcr or dvd recorder. its best to record straight from sattelite to dvd recorder for picture clarity.
Jan 27, 2009 | RCA DRC8300N DVD Recorder/VCR
I can't transfer my files from recorder to pc
Jan 21, 2009 | Olympus VN-3100PC Digital Voice Recorder
Playing DIVX on an LG LH-RH3690 DVD recorder
You can not view from the USB, since the USB port on the DVD player is ver 1.1. The transfer speed is to slow to watch a movie. Alternatively you can copy your movie from your flashdrive to the harddrive and watch from there. You will see what I mean with slow speed when you copy the movie. It takes ages.
Sep 11, 2008 | Yahoo YDP305 DVD Player
Recording a movie that I have on my pc to a disc useing a RCA DRC8335
if you have an s video out as well as audio out on your laptop connect it to svideo and corrasponding audio input on dvd recorder. hook up recorder to a TV to see the movie your transfering then press record on drc that should be good luck
Sep 01, 2007 | RCA DRC8335
Panasonic DMR-E55 DVD Recorder Logo
298 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
