Question about Sony Xplod XM-1652Z Car Audio Amplifier
Can i add a fan to inside of amp?
I have a Xplod XM-1652Z, and it overheats after about 30 min. is it possible to take a small pc fan and put it in the amp?
It may not be able to handle the ohm load the way u have it hooked up. Do u have the subs bridged? If so try unbridging them and see if it still overheats.
Posted on Apr 24, 2007
  • 62 Answers
If theres room...However usually when a amp overheats its a sign of it being over worked. Either your wiring is insufficent causing a voltage drop, and forcing the unit to compinsate for it increasing the reistance inside the unit. Anyways if dont want to change any of that I suggest Moving it to where there is more ventilation is it isnt alread...and just installing a exteral PC fan around it. You can make it look nice by using the Led pc fans you can get now.
Posted on Mar 25, 2007
I have a sony xplod 1652z 1000 watt amp and want to hook up 2 subs and the speakers that are already installed in the truck is that possible?
thats not a good idea because you are running too many speakers off that amp it it could possibly blow a channel or the whole amp. trust me i've done it
Jun 10, 2010 | Sony Xplod XM-1652Z Car Audio Amplifier
My sony 800 w amp dies after a few min. One time it only went on when i gassed the engine
try checking the ground it may be loose and only dissconect when you put pressure on it like gassing your car.
Jun 07, 2010 | Sony Xplod XM-1652Z Car Audio Amplifier
Amp often decides to not work.
HI DUDE ,, TRY CHECKING UR RCA CABLE ,, COZ IT MIGHT B UNPLUGED AT UR PRE AMP OR PLAYER ... OR CHECK UR SUB WOOFER WIRE INSIDE THE BOX ....
Apr 14, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
How to measure watts
You need a Volt Meter and an Ohm Meter. P = VI & I = V/r, so Power = (Volt^2)/Ohms .
You can get the ohms by hooking them up to the subwoofer input wires, and you get the volts by hooking up to the amp output terminals/wires. Although, amps will put out different voltages for different frequences, this should give you ballpark estimates.
Nov 10, 2008 | Sony Xplod XM-1652Z Car Audio Amplifier
Do you know
easy put, it is the adjustable gain level for the amp
Apr 19, 2008 | Sony Xplod XM-1652Z Car Audio Amplifier
Sony Xplod XM-1652Z Car Audio Amplifier cuts out when turned up loud
The best thing to do is to get a amp that is more watts than your subs, not the other way around, speakers are known to handel a lil more power but amps cant produce more power than they are capable of... your ground wire should be thick also, say 6 to 8 mm or so, and its best to put in a cap and an equalizer.
Cheers
Dec 19, 2007 | Sony Xplod XM-1652Z Car Audio Amplifier
Sony Xplod XM-1652Z Car Audio Amplifier Logo
132 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
