Question about Brother Office Equipment & Supplies
Fax doesn't work only states machine is a sleep,doesn't fax or receive fax. Model MFC-7840W does print between laptop and printer. or
  • mcjeff Dec 17, 2008
    I will know the next time I have to fax something.
  • 679 Answers
Are you in power saver mode? is it a wired or wireless machine? you could try running the setup disk, if you are in wireless it should straighten out the problem. Power it up and try reinstalling. Wire it to the laptop and run the setup, it will let you know when you can remove the wire, thanks and good luck,Gym .
Posted on Dec 17, 2008
  • George Bill
    George Bill Dec 18, 2008
    Ok see now it makes sense, go into control panel, than power options and the change the power off and other options so that the computer doesn't go into sleep mode. Always on. you can still have your screen saver go on after 30 minutes or whatever time frame you like. Disable hibernation, and you should be ok, the machine was going to sleep, and not alowing the fax to work.
  • 327 Answers
Its the setting error the printer is not set on fax mode.just make it set and then check out.or either the wires of fax line are loose or gone faulty so this problem.
  • 1,199 Answers
Unplug machine for 5 minutes and this should reset your uniy!
Mfc-7840w /Cc3 205 03031f04
Your fax machine can work independently from your operating system. Print the document and try to manually fax from the fax machine. See if there is an error message on the fax when you try. Then if it doesn't work , post the new error from the fax machine.
May 23, 2014 | Computers & Internet
Brother mfc-7840w won't receive fax
The first thing that I would try multiple people to ask them to fax you.Sometimes the 2 machines don't "sync".This is a toll free fax test number that I always use to check my machines..1-888-473-2963.Just write the words "FAX TEST" in large letters on a blank sheet of paper..fax it to that number...leave the line should get a fax back in about a minute.If you get a fax back...your machine is fine...let me know if this was helpful....thanks.
Dec 14, 2011 | Brother MFC 7840W Printer
I'm not very techie... I just want to ask how to use the fax in this model... is it plug and play? how to operate the fax? can i operate the fax through computer? can i receive fax? will my fax number be...
Here in the link which i have given you could find your printers manual download it and so that you can see about your fax how to use
Mar 11, 2011 | Brother MFC 7840W Printer
MFC-7840w printer, how do i take it off sleep mode?
  • The control panel features a series of buttons as well as an LED "Status" screen.
  • Press the "MENU" button. Go to INITIAL SETUP, select "FAX" select "RECEIVE MODE" change to F/T
  • If you are using the Brother on a line by itself, set it to "Fax." If you are using the Brother on a line that also shares a telephone, set it to "Fax/Telephone." If you are using the Brother IntelliFax along with ananswering machine, set it to "TAD." Once you set your IntelliFax to the appropriate mode, the unit will leave "Sleep" mode and be ready for use.
  • Select "GENERAL SETUP" go to "ECOLOGY" and #2 is SLEEP TIME = adjust to 60 sec. This keeps the machine from becoming idle/sleep mode for a longer period.
    Sep 25, 2010 | Office Equipment & Supplies
    Documents are smudged on brother mfc-7840w
    just clean the toner and try.
    Have a nice day and do not forget to rate please...!
    Feb 03, 2010 | Brother MFC 7840W Printer
    Brother mfc- 665cw, receiving faxes
    From the Brother web site.
    Description of Problem 100000018247
    When I launch PC-Fax Receive Program, I receive an error stating: The Fax Receive program must be started to receive PC faxes. What can I do?pc fax rx
    Description of Solution 200000023257
    You may receive this error if the pc fax application is closed and you have faxes stored in the memory of the machine. To resolve this issue,you will need to print the faxes already stored in the memory of the machine. To print the faxes, please follow these steps:
    1. Press the MENU key.
    2. Press the UP OR DOWN ARROW key to select Fax.
    3. Press the OK key to confirm your choice.
    4. Press the UP OR DOWN ARROW key to select Print Fax.
    5. Press OK.
    6. Press the BLACK START key.
    - Your Brother machine will print the stored faxes.
    7. Press the STOP/EXIT key to exit the menu.
    8. Once the stored faxes have been printed, click WINDOWS/START, (ALL) PROGRAMS, BROTHER, XXX-XXXX (X = MODEL NUMBER), PC-FAX RECEIVING, XXX-XXXX or RECEIVE (depending on your operating system).
    9. The Brother PC-fax receiving icon will now appear in your Windows Task Tray indicating that Brother PC-Fax Receiving is active.
    Jul 03, 2009 | Brother MFC-7820N Printer
    Can send but can't receive faxes on MFC-8460N
    Fax machines are ANALOG devices and will not work reliably on DIGITAL phone lines.
    Feb 09, 2009 | Brother MFC-8460N All-In-One Printer
    MFC 7840W, fax not sending or receiving
    Is your phone line DIGITAL? Fax machines are ANALOG devices.
    Jan 15, 2009 | Brother MFC 7840W Printer
    Brother MFC-7840W fax will not work
    Plug a regular phone into the wall jack and listen for a dial tone.
    Phone cord should be connected to the LINE port of the fax.
    Do you have DSL?
    Unplug power cord for 10 seconds.
    Oct 17, 2008 | Office Equipment & Supplies
    "Receiving Sleep" on Brother Fax 4100
    you might have to change the settings for the switching time into stand-by. plz have a look into the manual which describes these settings (zero seconds are possible)
    Jan 09, 2008 | Brother MFC-5840CN All-In-One InkJet...
    16 people viewed this question
    James Cagle
    James Cagle
    Jim Keysor
