Sherwood receiver rx-4105 fm doesnt pu any frequency (just static) , am does
I have a similar problem. I hear static on AM, on FM at full volume I can faintly here the closest FM station to my house . It worked previously, just stopped working. I have the same FM Antennae I used previously still hooked up. I unhooked the antennae and hooked it back up thinking it wasn't making good connection. No luck. It's a Sherwood RX-4105.
Posted on Aug 25, 2011
  • w0lverine Aug 25, 2011
    It works fine with through Auxiliary, CD,VCR.
    I no longer have the remote. Is it possible the volume was set so low with the remote, that I need another remote to turn it back up remotely? If so why would all the other functions work at proper volume levels?
    Genius:
  • 1,199 Answers
You need to hook an antena to the back of the unit (A peice of speaker will do!) you should see a screw in back of uniGood luck and Thank you for using FixYa.
Posted on Dec 17, 2008
    I have a similar problem. I hear static on AM, on FM at full volume I can faintly here the closest FM station to my house . It worked previously, just stopped working. I have the same FM Antennae I used previously still hooked up. I unhooked the antennae and hooked it back up thinking it wasn't making good connection. No luck. It's a Sherwood RX- 4105. Add a c
I have a Sherwood RX-4109 receiver. The right side channel has low volume and cracks, can it be fixed?
show me a picture so I can tell if it is even worth fixing. you may be better off getting another one.
Aug 13, 2014 | Sherwood RX-4105 Receiver
I have a Sherwood RX-4105 Receiver and I am getting no sound through my speakers and the connection with the wires is good so its not that. Any Idea on whats wrong?
when you turn your computer you should hear a sound of a relay initially and after about two seconds another sound, is the closure of the speaker relay models if you do not hear the sounds, the team has some short audio output.
Sep 07, 2013 | Sherwood RX-4105 Receiver
Antenna is broken
Which are we talking about? AM or FM. Is it the socket where the aerial goes?
Jul 29, 2013 | Sherwood RX-4105 Receiver
I want to hook a amplified antenna to my sherwood receiver what kind of cable or wire should i use?
You can use standard TV cable (RG-59/U) or for a long run the white RG-6/U which has lower signal loss
Feb 18, 2013 | Sherwood RX-4105 2-CHANNEL...
Does the sherwood rx 4105 receiver have analog or digital inputs
Unfortunately the RX-4105 is a stereo only receiver with only analog L/R inputs. You will have to find a stereo output & go in through one of the stereo inputs.
Feb 12, 2013 | Sherwood RX-4105 Receiver
How can I eliminate my high and mid range frequencies going to my 12 inch speakers from my stereo receiver
You cannot do that with this unit. You would need an external crossover connected between it and your speakers to do so.
Mar 08, 2010 | Sherwood RX-4105 Receiver
Can I hook the reciever to mm bose subwoofer and 5
if bose unit has built in amplifier .Then your sherwood would have to have a variable RCA output jacks in order to work with sub.Then bose audio input RCA cable would connect there.If bose unit does not have built in amp .Then you would connect sherwood left/right speaker outputs into bose left/right inputs .Then other bose speakers will connect to bose unit
Jul 30, 2009 | Sherwood RX-4105 Receiver
FM Tuner in Sherwood RX-4105 stopped working
Check your antenna connections. Make sure your FM antenna is hooked up to the FM antenna terminal or jack on your Sherwood receiver. If you have the antenna hooked through the coaxial cable, check your coaxial cable with an ohmmeter for continuity. You can buy a volt-ohm meter as little as $12. Usually bad connection occur between coaxial cable and the the coax cable connectors. If that doesn't solve the problem, then there may be something wrong with your tuner card inside of your Sherwood receiver.
If you receivers display does not change channels or frequencies or AM or FM mode, when you try to change the channel or frequencies, or AM or FM mode, there may be something wrong with the front board of your receiver.
If there is something internally wrong your Sherwood receiver, you need to take it to a qualified technician that can fix it. Do not try to repair it yourself. If you don't know what you're doing, you can do far more damage to that Sherwood receiver to the point that would be very costly to repair.
Before you take your Sherwood receiver to a technician, try to unplug the receiver, and leave it unplugged for several minutes, and then plug it back in. If that doesn't solve the problem, then you need to take your Sherwood to a qualified technician.
Dec 02, 2008 | Sherwood RX-4105 Receiver
Heavy static noise
Sounds like interference getting in caused by your connecting cables. Suggest upgrading to higher quality ones.
Aug 31, 2008 | Sherwood RX-4103 Receiver
Fm connection broke
By the plastic piece, and replace it.
Oct 05, 2007 | Sherwood RX-4105 Receiver
91 people viewed this question
 Grubhead
Grubhead
