Question about Kitchen Appliances - Others
Furnace only stays on for 5 min
Ducane gas furnace
Your limiter switch or timer delay is bad start with that first
Posted on Dec 17, 2008
I have an Armstrong SX Ultra 90 propane gas furnace that the fan motor will not shut off ,the thermostat is on auto.
Hit the side of the furnace. Some times there's a sensor inside that gets locked up from a dirty filter.
Oct 19, 2013 | Emerson Lennox Ducane Armstrong Furnace...
Ducane furnace gas burner runs one minute shuts down
If this has an Hsi Ignition its time to have a tech check it out and replace
Feb 13, 2013 | Honeywell Furnace Gas Valve Sv9501h2409
Installed June 12, 2012 a new Ducane Bottle Gas Furnace. My furnace will run a normal cycle of around 10 to 15 minutes. Then 3 min later it will start again and run for 3 to4 minutes and shut down or
1 do you have a program or mercury buld mercury bulb.is usally a adjustable heat anticipator which a digital is fixed I recommend a digital t stat but also be advised that mercury bulb tstat are really phased out you could also have a issue with your main limit inbetween the heat exchanger wheather it is a cam stat or a normally closed limit but being a new furnace its more likely to be a n/closed limit will open if there is to much heat in supply box above the evap coil.you would need to take your delta temp reading within manufacture specs..or call aca or your local hvac company 770 932 8990 ask for mr.blaine to schedule your appointment today or are office staff thanx.
Jan 24, 2013 | Ducane 30400042 (LP)
Brand New Ducane Furnace with Multiple Error Codes
Check your drain line. It appears that water is not draining and backing up into the furnace. Is there a drain trap? If not or if there is no vent on the drain line there can be a vacuum created when the furnace is running and it actually pulls water back into the furnace and when the inducer shuts off it releases the vacuum allowing the water to drain.
Dec 17, 2012 | Honeywell Furnace Air Pressure Switch...
How to change burners for a ducane meridian 32 inch 5 burner gas grill
Go to Ducane web site http://www.ducane.com/manuals/ and download the manual for your model.
Has Mederian 3 & 5 burners and LP & NG
Also has Stainless 3 & 5 and LP & NG
Need Adobe Acrobate reader that can also be downloaded.
Manual shows step by step in Annual Cleaning section
azrsanford@comcast.net
Apr 04, 2010 | Ducane Meridian 32 Inch 5 Burner Gas Grill...
Burner will not stay lit
try to replace the regulator on the grill
Mar 20, 2010 | Ducane 30400042 (LP)
Furnace flame goes low fan stays on
if the gas pressure is good on inlet and outlet of valve u might wanna chk the burner trays and manifold for flakes, dirt, spider webs ect... once u kno the passages are clear from obstruction you can focus on the mechanical. (sounds like gas valve may be getting weak and not able to open fully)
Mar 21, 2009 | Dayton Gas Furnace Heater
Kitchen Appliances - Others Logo
250 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Marvin
Marvin
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
