Question about Bowflex Treadmill Series 7
The treadmill keeps stopping Freespirit Model 12230520.0
When I turn it on it runs for a short time and then it stops. I pull the power plug and reset the saftey switch, it runs for another feww min and stops again! Help!
  • j_gwright Dec 26, 2008
    Thanks Chris...cleaning did the job. Much appreciated.
    Jim (the Klutz)
  • 827 Answers
Hey there,
If your treadmill has an optical speed sensor and hasn't been cleaned for a while, dust, dirt or lint may be obstructing the infared eye of the speed sensor. Try cleaning the treadmill.
Or maybe you need to replace the upper display, although, you may have a loose wiring harness that would cause the same problems. Open the motor case and verify the wiring harness is plugged into the lower board snugly. Also, remove the upper console and verify the harness is plugged into the back of the console snugly as well.
Definitely, inspect the components and try and isolate the source of the problem yourself first, before contacting a dealer for parts, as they can cost a fortune..
Good Luck!
Chris (ziraffa)
Posted on Dec 26, 2008
Treadmill stops abruptly i have to reset button then go again for a few minutes
Find out what is overheating it. Most likely something jammed into one of the rollers.
Feb 19, 2015 | Free Spirit FreeSpirit Model 30516...
When I turn on says stuck button
reset the treadmill, follow this step and fix it. Merry Christmas
Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
    • 3
Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
    • 4
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.move on to the next step.
    • 2
Locate the reset switch on the underside of the treadmill console. Usually the button
Dec 17, 2013 | Exercise & Fitness
Keeps asking me select user, then it restarts again
Reset it. and follow this steps and fix it. God bless you
1 )Locate the reset switch on the underside of the treadmill console. Usually the button is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill. ·2
·3
Dec 09, 2013 | Horizon T203 Treadmill
Jazfit Running Machine
reset the machine, follow this steps and fix it. God bless you
However RUN the software calibration for easy diagnostic goes under the HOOD motor and follow the steps.
    • 1
    • 3
    • 4
    • 2
Dec 06, 2013 | Exercise & Fitness
When turn it on just beeping noise
reset the treadmill. follow this steps and fix it. God bless you
1.
    • 1
    • 3
    • 4
    • 2
Oct 23, 2013 | Reebok Exercise & Fitness
Rebok i run RE14301, plain blue screen. It was working until my son played with all of the buttons! We have tried turning it on and off and pressing the reset button but this does not seem to have worked
Instructions 1.
    • 1
    • 3
    • 4
    • 2
Oct 15, 2013 | Exercise & Fitness
Norditrack a2550 model stopped working while I was on it. The control panel will beep then light up like a Christmas tree but just goes into a nonperforming demo mode. Treadmill wont work! Help
1.
    • 1
    • 3
    • 4
    • 2
Oct 06, 2013 | Nordic Track NordicTrack Treadmill, A2550
Treadmill keeps inclining and declining . It won't stop!
I have a Proform ZT5 model - had the same incline/decline problem. It needed calibrated.
- unplug, turn off, and take the key out
- plug machine in
- turn switch on
- Pres and hold the STOP and SPEED UP button at the same time, while holding them insert the RED KEY
- let go of both buttons
- press STOP 1 time
- pres INCLINE UP 1 time
- this should reset it.
The tech on the phone mentioned the importance of turning the maching off, taking the key out, and unplugging after each use. Leaving it plugged in there is still an electrical current running and this can cause more seriouc problems that require a new control panel.
May 08, 2011 | Proform ZT5 Treadmill
Bowflex Treadmill Series 7 Logo
1,693 people viewed this question
Top Bowflex Exercise & Fitness Experts
Jerry Greenberg
Jerry Greenberg
ptpumpman
Marvin
Marvin
Are you a Bowflex Exercise and Fitnes Expert? Answer questions, earn points and help others
