Question about HP Photosmart C5180 All-In-One InkJet Printer
HP C5180 "wrong cartridges" error
I have a 2 yr. old HP C5180, it has "wrong cartridges" error on the screen. I can't clear this, it also had a blinking "cancel" light... that I can't clear.
Please Help
  • HP Master
  • 13,433 Answers
Try this semi full reset
Reset the All-in-One to the factory default settings by using these instructions:
1. Unplug the power cable from printer when the printer is powered on and wait for 20 seconds.
2. Then, press and hold # and 6 while plugging in the power cord.
Continue holding until it displays Semi Full Reset message in the front panel of the All-in-One.
Posted on Dec 17, 2008
    Sergeant:
    Novelist:
  • 327 Answers
If its showing wrong cartridge then it could be possible that any of the cartrige in the printer needs replacement.or there is any dust got collected on the circuit of the cartridges just remove the cartridge and clean the circuit and reinsert it again properly.it will work.
HP Photosmart C5180 printer error message Oxc18a0206
Use your machines own programme to clean the ink heads
Feb 20, 2016 | HP PhotoSmart Office Equipment & Supplies
Error ink system failure on photosmart c5180
The "ink system failure is a common error on HP printers, it is caused by air in the ink cartridges or ink feed tubes. YOu will need to do a ink purge routine to clear the error. We have several pages on our web site explaining what causes the problem and how to clear it. The link is: http://www.ccl-la.com/blog/index.php/category/printer-repair/hp-printer-repair/
This should get you up and printing in no time at all.
I hope this helps you, if so please rate our solution.
CCL Tech
Corporate Computer
www.ccl-la.com
Oct 10, 2010 | HP Photosmart C5180 All-In-One InkJet...
Printer said to replace yellow cartridge,replaced yellow cartridge,will notprint at all
If you are not getting an error message, your nozzles may be clogged. If you are using aftermarket or refilled cartridges, insert new OEM cartridges and run deep cleaning a number of times (3x) and the realignment utility. This should clear the nozzles and the cartridge sensors. Secondary market cartridges often do not meet manufacturer's specifications and can clog the printer nozzles. This should clear the problem.
Dec 18, 2009 | HP Photosmart C5180 All-In-One InkJet...
My HP Photosmart C5180 printer keeps coming up with an error message 'Ink System Failure. Does anybody know what is needed to solve the problem.
The "Ink System Failure" error is causes by air in the ink feed tubes. We have a step by step guide purging the air from the feed tubes posted on our web site. Go to our site at: www.ccl-la.com, click on the printer repair link and then the HP link. Follow the steps and you should be back printing in no time at all.
I hope this helps, If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Nov 01, 2009 | HP Photosmart C5180 All-In-One InkJet...
I have a 13 month old HP Photosmart C5180 which is now displaying the following error message, "Ink System has failed. Unable to print.." Error: Oxc18a0506. The help message suggests "turn power off then...
your second set of catridges mush help you,, and also,, it seems that your operating system is corrupted,, its better you reinstall the printdrivers first,, if problem persists,, then try reinstall of windows..
Sep 28, 2009 | HP Photosmart C5180 All-In-One InkJet...
Ink System Failure HP C5180
IssueAn 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The printer cannot copy, receive faxes, or print. Solution
Press the On button to turn the printer off.
Unplug the power cord from the back of the printer.
Remove all the ink cartridges.
Wait two minutes.
Plug the power cord into the back of the printer.
Press the On button to turn the printer on.
Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved.
If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the printer.
Jan 23, 2009 | HP Photosmart C6180 All-In-One InkJet...
HP C5180 yellow cartridge empty
Thanks for everyone for posting there problem with HP C5180 with the yellow ink being empty. With out this I would not figure and made attempt to fix it.
Credit to Longtimemacuser @ http://h30434.www3.hp.com/psg/board/print?board.id=Printing&message.id=525&page=1&format=page
Same here-  I'm running into this problem for the second time in less than 3 weeks on my HP C5150. . Brand new cartridge installed, and it is fine for a day - then 2 days later, after NO color printing - it suddenly shows as completely empty.
Last month when I had the same problem, customer support suggested the following, which seemed to work.
(typos were theirs - I just copied and pasted):
Please try the following step's
Power your C5150 on and remove all 6 cartridges and close the cartridge access door
With your C5150 powered on unplug the power cord directly from the back
Press and hold the OK button and the HELP button down together while you plug the power cord back in
Keep the button's held down until the display screen goes blank then release the button's and power your C5150 back on
When you are prompted on the display screen to install the cartridges install all 6 cartridges and close the cartridge access door
Are you still getting the same message ?
I did the printer reset but I only removed the yellow cartridge. follow the on-screen prompt and this process will take about 3-5 minutes. When everythings done, suggest to clean the printer head
Hope this help
Anthony L.
This should resolve the issue. If you need further assistance, please reply to this message and we will be happy to assist you further.
You may receive an e-mail survey regarding your e-mail support experience. We would appreciate your feedback.
For information on keeping your HP and Compaq products up and running, please visit our Web site
at:
http://www.hp.com/go/totalcare
Nov 21, 2008 | HP Photosmart C5180 All-In-One InkJet...
"Wrong Cartridges" Error HP C5180 now Failed ink system.
Please perform the following steps:
A. - Press and hold the “left arrow” key.
B. - Press the “Setup” key and release both keys.
Display should say “Enter Special Key Combo”
C. - Press and release the “OK” button
Display should say “Support” and display the FW rev (something like R0616R)
Now, perform the following instructions:
1. Press and release the right arrow button until the displaysays “System Configuration Menu” 2. Press and release the “OK” button.3. Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status”,
4. Press and release the “OK” button.5. Display should say “Hardware failure status: Clear. Press OK to clear”.6. Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.7. Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.8. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.9. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer10. Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK. 11. If the printer has already initialized, then go to the next step. If not, the printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
12. To verify printer functionality print a SELF TEST PAGE. If SELF TEST prints, then printer is ready for use or Software Installation.13. If the error is still there, or reoccurs replace the unit.
Jul 13, 2008 | HP Photosmart C5180 All-In-One InkJet...
Cartridge error
remove the cartridge & install the new one cartridge other wise
May 10, 2008 | HP Photosmart C5180 All-In-One InkJet...
HP Photosmart C5180 All-In-One InkJet Printer Logo
1,040 people viewed this question
Clive
Clive
