SOURCE: One way comm only
swap batteries if does not work this unit should need repair or replace, display blinking can be produced for power failure ( battery, contacts, circuits) or can be a controller issue.
SOURCE: motorola mtx 8000 radio
Yes. That is a strong possiblity. Many models of Motorola will emit a tone when not programmed, or by placing the channel selector on an unprogrammed channel.
SOURCE: I have 2 Motorola P110 2 Ch Radios. One powers up
There a a few things which could cause this:
1) You have the radio set to an unprogrammed channel.
2) You have a bad, low or defective battery. (Try switching batteries with the other unit and see if the problem goes away.)
3) Your radio needs repair.
4) Your radio has busy-channel-lock-out activated and you are trying to transmit on a frequency which has activity in your area.
SOURCE: it automatically turn off when press the PTT
This is usually a power problem - if the transmitter cannot draw enough power to operate, it shuts the radio off to prevent circuitry damage. Make sure that you're using fresh, fully charged batteries, and that the contacts on the batteries and inside the radio are clean and free of corrosion.
Bill B
Testimonial: "thank you. but the batteries are loosing power very fast. "
SOURCE: how can i program a motorola mtx 8000 radio ?
visit the below manual, go to chapter/section 3, under Basic Radio Programming tutorial you will learn how t5o program your motorola mtx 8000 radio
http://www.kwnet.net/n7qqu~/eq-manuals/Motorola/MTX9000/68P81074C50-J-MTSX_RSS_manual.pdf
I hope this helps.
Good luck.
