Question about Kenmore Elite 45986 Front Load Washer
Power out when running. showed code F 71 now not working.
I ran washer and went to work. Came home. Clocks in house flashing showing a power outage previously. I tried to restart washer. No luck. I unplugged it for a few hrs. Then i plugged it in and started to wash a load. Looked like it was working. It stopped after less than 2 minutes and Washer showed code F71, flashing. I tried to start it. No luck. There was water in machine. Door locked. I unplugged it again and plugged it in but this time no lights on at all but there is the chime when i push the power button.
frontload, kenmore elite F155/1999 11049962600. Bought april 2007.
  • 8,197 Answers
After power outage that will happen do this to fix.
Select PAUSE/CANCEL twice to cancel the cycle. Select
DRAIN & SPIN if there is excessive water in the washer.
Re-select cycle and press START. If the problem remains, call
for service.
Posted on Dec 17, 2008
Affinity washer flashing EFO
Good Morning Friend,
I understand that your Frigidaire Affinity washer, model# ATF7000E, is flashing an EFO code. I do not show an EFO code for your appliance.
I do show an EF1 code, which means the drain pump is clogged. In this instance you would unclog the drain pump.
I also show an EF2 code, which means too much soap was used. All you would do for this would be to try using less soap.
It could also be a false error code. I suggest resetting your washer, by either unplugging it or shutting the power off at your homes circuit breaker, for 3-5 minutes. When you restore power, start any cycle on your washer. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. Hope this is helpful.
-Best Regards-
WP
May 15, 2014 | Frigidaire Affinity ATF7000E Front Load...
Sony wega KE-42M1 .power lead ok . no power at tv. (no standby or power light showing at on switch). house power went off , when it came on tv wouldn't work
This confirms that the main power supply which is the SMPS is faulty.
The fuse could have failed and must be checked, if the fuse fails the SMPS is confirmed to be faulty due to the power outage.
please check the links below for tips and support:
http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
http://en.wikipedia.org/wiki/Switched-mode_power_supply
Sep 21, 2011 | Sony WEGA KE-42M1 42 in. HD-Ready Plasma...
VCR will not show picture or menu on TV after power outage.
Hate to say this, but when power outages occur, things like vcr's are the first thing to fry. But if you feel that the vcr is fine as far as powering up, then unplug it from the wall socket for 30 minutes or so, plug back in and see results.
Apr 13, 2010 | Televison & Video
Wrong temp. on the thermostat.
sometimes a power outage or a static spark will effect the stat, remove the stat from the wall take out the batteries and walk away from it for at least 10 minutes, then reinstall it
Aug 03, 2009 | Heating & Cooling
My model rs2555sl samsung fridge does not start up after power outage.
Samsung RS2555Sl suddenly stoped working once the power is switched off, If switched on again, only the Ice making sensor light flickers. If both Pwercool and power freeze buttons are pressed for 12 seconds it stars and running normally. Will it automatically start working if I change the Ice making sensor?
Jul 10, 2009 | Samsung RS2578BB Side by Side Refrigerator
No burner/oven heating after house power outage.
try reseting the clock as lots of ovens will not work untill clock is set
Jan 19, 2009 | Amana AER5515QA Electric Kitchen Range
My Bosch washing machine shows error code F37 and beeps
My Bosch washing machine shows error code F57 and beeps
Dec 09, 2008 | Bosch Logixx WFT 2806 Front Load...
KENMORE Elite HE 3T
no but there is a control bd it is probably gone
Jul 30, 2008 | Kenmore Elite 45986 Front Load Washer
Gibberish on the Front Screen
Try unplugging the unit for 30 seconds then plug it back in. The power outage may have been erratic and the MW did not reset properly.
Jun 16, 2008 | GE Advantium 120 Convection/Microwave Oven
Power went off last night and our phone stopped working
I had power outage last night now corder at&t 1855 led's keep flashing keeps telling me about power outage before every new message. How do I get rid of the flashing?
Apr 14, 2007 | Uniden CLX485 Cordless Phone
Kenmore Elite 45986 Front Load Washer Logo
342 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
