Question about HP Photosmart C6180 All-In-One InkJet Printer
Unable to pring 4 x 6 index cards from a Word doc.
I selected the 4 x 6 index card size paper. When I try to print, the image is portrait when it should be landscape. I would really appreciate a solution!
Thanks for trying to help. Meanwhile I went to HP tech chat and went also back and forth on possible setting solutions for the HP c6180 all-in-one printer I was inquiring about. The real problem turned out to be in the Microsoft Word document settings. When I started from scratch with new document setup and selected the correct format for 4x6 index cards, the printer settings with just a couple of resettings worked fine. I was trying to control all the settings from the HP solution center and my printer settings when the real issue was to be sure to set the Word document settings correctly in the first place. thanks again. MLH
Posted on Dec 18, 2008
My Canon mp600 was printing a photo when the error message "paper jammed" came up. I know the paper is in the machine, though I can't find it.What do you suggest?
You can access Canon online support info here. Enter paper jam as a search, then choose #4 to remove the obstruction.
Also see this:
Issue: Paper is jammed inside the printer
Solution: Removing paper jams MP600
Removing Obstructions or Jammed Paper If [Paper output slot - The paper is jammed. Clear the paper and press OK] appears on the LCD, follow this procedure to clear the paper jam Clearing paper jams from the auto sheet feeder (ASF) or paper output slot
Clearing paper jams inside the printer
Clearing credit card-sized or 4" x 6" paper jammed inside the printer
ASF / Paper Output Slot
  1. Turn off the printer.
  2. Remove paper from the ASF.
  3. Gently pull the jammed paper out.
    1. If paper is visible from the ASF, use both hands to pull the paper out slowly.
    2. If paper is visible from the paper output slot, use both hands to pull the paper out slowly.
      The above illustration shows a PIXMA MP500.
  4. If the paper tears and a piece of that remains inside the printer, open the scanning unit (printer cover) and remove the paper from inside the printer.
    Note:
    Be careful not to touch the components inside the printer.
  5. Turn on the printer and confirm that the Alarm light is off.
    (If the jammed paper remains in the printer, the paper may be automatically ejected.)
  6. Load paper back into the ASF.
  7. Press <OK> to clear the message and continue printing. If you are printing from an application software, follow the instructions displayed on your computer.
Top
Paper jams inside the printer
  1. Turn off the printer and disconnect the power cord and USB cable.
  2. Remove the jammed paper slowly using the following procedure.
    1. Open the rear cover to check if the paper is jammed.
    2. Pull out the cassette and check if the paper is jammed inside the cassette area.
    3. Stand the printer with the left side down, holding the document cover.
    4. Press the tabs together and pull the green cover toward you.
    5. Check if the paper is jammed.
      (If you were not doing Duplex printing, you do not have to follow this procedure.)
    6. Close the green cover and place the printer back to a normal position.
  3. Reconnect the power cord and power on the printer. Confirm the Alarm light is off.
  4. Load paper back into the ASF or cassette.
  5. Press <OK> to clear the message and continue printing. If you are printing from an application software, follow the instructions displayed on your computer.
Top
Clearing credit card-sized paper jammed inside the printer
Credit card-sized and 4" x 6" sized paper must be loaded properly. If this media is not loaded properly, it will feed into the printer and will not exit. Credit card-sized paper should only be loaded in the ASF and in portrait orientation. 4" x 6" sized paper can be loaded in the ASF or cassette. But must be loaded portrait orientation.
If credit card-sized paper was loaded in landscape orientation in the ASF and did not eject (exit), please follow this procedure.
  2. Load the same paper type that is jammed inside the printer in portrait orientation.
  3. Power on the printer.
    The paper stock in the ASF will automatically feed the jammed paper from the printer.
  4. To resume printing, load the paper in portrait orientation.
If 4" x 6" sized paper was loaded in landscape orientation in the cassette and did not eject (exit), please follow this procedure.
  2. Open the rear cover.
  3. Fold in four a piece of letter-sized plain paper.
  4. Push in the folded paper until it hits the jammed paper.
  5. If the jammed paper is visible from inside the printer area, pull it out and proceed to step 7.
  6. If the jammed paper cannot be pulled out, push in the folder paper from the rear so the jammed paper is in between the feed rollers.
  7. Pull out the folded paper and close the rear cover.
  8. Power on the printer and confirm that the Alarm light is off.
    The jammed paper should automatically eject.
  9. To resume printing, load the paper in portrait orientation.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks
Nov 17, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Can't remove memory card from printer
hi
  • Ensure the MP970 is connected to a working electrical outlet. Turn the printer on by pressing and releasing the power button located on the upper left hand side of the control panel.
  • Step 2 Select the memory card you wish to use. Insert the memory card into an appropriate adapter if it requires one. Open the Card Slot Cover, located on the right hand side of the printer, by pulling the door out and toward the center of the printer.
  • Step 3 Insert the memory card into the appropriate card slot with the label side facing up. Confirm the Access Lamp is lighted. Close the card slot cover.
  • Step 4 Check the "Select and Print" option on the display screen. Select the "Okay" option.
  • Step 5 Load your preferred print media into the printer. Confirm Paper Source, Paper Size and Media type. Select the "Okay" option. Select the "Next" option. Select the "Okay" option to access the images on your memory card.
  • Step 6 Press the Left or Right Arrow buttons to select the image you wish to print. Press the + or – button to determine the number of copies of this image you wish to print. Select the "Okay" option.
  • Step 7 Confirm your print instructions. Select the Print option to being printing your photos.
  • Jul 06, 2010 | Canon PIXMA MP130 All-In-One InkJet...
    At college we have a w7200, how can we print across the paper rather than down it, for example a panoramic image across the width of the paper and say 20cm high
    Try selecting LANDSCAPE as opposed to PORTRAIT by using the proper print menu in your application rather than the simple print icon from most tool-bars.
    You can usually find it in the FILE menus
    Apr 20, 2010 | Canon imagePROGRAF W7200 InkJet Printer
    Paper goes through tray 1 the image prints landscape on portait
    Try placing the business card sheet in the main paper bin instead of the manual feed or adjusting the print orientation from Portrait to Landscape or vice versa.
    Sep 25, 2009 | Computers & Internet
    Smaller items will only feed crookedly into the printer document
    Check to see if you are feeding the envelopes and 4x6 cards/photo paper correctly.
    Both envelopes and 4x6 cards must be loaded and centered on the paper exit tray (not inside the paper input tray).
    Printing envelopes:
    • Up to 15 envelopes can be loaded at a time.
    • The print side of the envelope faces down.
    • The envelopesare centered on the paper exit tray.
    • You print the envelopes with Landscape orientation.
    Printing cards:
    • Up to 35 greeting cards, index cards, postcards, or photo cardscan be loaded at a time.
    • The print side of the cards faces down.
    • The cards are centered on the paper exit tray.
    • You select Automatic, Normal, or Photo print quality.
    For images on how to correctly load the paper, download your printer user's guide:
    http://support.dell.com/support/edocs/systems/prn946/en/index.htm
    Aug 16, 2009 | Dell 946 All-In-One InkJet Printer
    Canon error code 6000 in mx308
    please help me. i have canon print mx308. the have paper jams. paper has the full out from print. how i can finish the problems?
    Jul 25, 2009 | Canon Pixma MP450 All-In-One InkJet...
    The text of a document will not print. The
    Print From Your Computer : Windows Printing Select Basic Options Click the Main tab on the top of the printer settings window to select your basic print options. 1. Select a Quality Option that matches your document or photo, and the print quality you want. Quality Option settings WebWorks_WriteArrow(WebWorksRootPath, "wwdd1032347", false); WebWorks_WriteDIVOpen("wwdd1032347", false); • Draft: for rough drafts with reduced quality • Text: for documents containing only text • Text & Image: for documents with text and images • Photo: for photos and graphics with good quality and print speed • Best Photo: for photos or graphics with high print quality WebWorks_WriteDIVClose(); 2. Select the paper Type setting that matches the paper you loaded. 3. Select the paper Size setting for the paper you loaded. Paper size settings WebWorks_WriteArrow(WebWorksRootPath, "wwdd1032380", false); WebWorks_WriteDIVOpen("wwdd1032380", false); You can load paper in these sizes and select the size in the printer software. (Wider papers are for use only when reducing large images with the Reduce/Enlarge Document option.) A User Defined option is also available so you can create a custom size. A4 (8.3 × 11.7 inches) A6 (4.1 × 5.8 inches) Letter (8.5 × 11 inches) Legal (8.5 × 14 inches) Half Letter (5.5 × 8.5 inches) 3.5 × 5 inches 4 × 6 inches 5 × 7 inches 8 × 10 inches 16:9 wide (4 × 7.11 inches) Envelope #10 (4 1/8 × 9 1/2 inches) WebWorks_WriteDIVClose(); 4. If you’re printing borderless photos, click the Borderless checkbox. For documents or photos with borders, select Borders. Note:
    For borderless photos, make sure you loaded a compatible borderless paper size and type. 5. Choose Portrait or Landscape orientation for your document or photo. You can also:Select Print Options Select Basic Options Click the Main tab on the top of the printer settings window to select your basic print options. Select graphics & text. USER'S MANUAL EPSON WEBSITE: http://files.support.epson.com/htmldocs/cx44__/cx44__ug/wwhelp/wwhimpl/js/html/wwhelp.htm
    Jul 22, 2009 | Epson Stylus CX4400 All-In-One InkJet...
    Printing on an index card
    something else you might try is taping the card to a full-size sheet of paper, so the printer can push it through with ALL the rollers at the same time. not all printers have a roller all the way across, so index cards get snagged by one side, and they'll walk to the opposite side while they're printing.
    Jun 12, 2009 | Ricoh Office Equipment & Supplies
    Scanned legal doc to email comes out landscape and prints on lett
    select scan mode, then select legal on paper select. If you select paper before loading document into the ADF it should go with the size you enter.
    Jan 07, 2009 | Sharp AR-M550N Copier
    How to print 3 3/4 x 6 3/4 sized paper
    I found the solution myself. 1. Open Canon MP Printer 2. Select "Printing Preference" 3. Click Page setup 4. Click "Custom" 5. Select "Portrait" 6. Select Normal size printing 7. Adjust Paper Holder to fit small sized paper
    Feb 22, 2007 | Canon PIXMA MP780 All-In-One InkJet...
    HP Photosmart C6180 All-In-One InkJet Printer Logo
    438 people viewed this question
    mukhtar21 shaikh
    mukhtar21 shaikh
