Question about Samsung TXR3079 TV
Flashing screen Our power was out for 2 days due to an ice-storm induced power outage. When the power came back on, we turned our Samsung TXR3079 back on, and the screen flashed like a strobe light. After a few hours, it calmed down. Now (a month later) the screen flashes when certain colors, mainly orange or yellow, are present. The problem is getting worse every day, and the TV is almost unwatchable. My manufacturer's warranty expired in January (of course) and I have been in touch with Samsung to try to get some help, without much luck. Should I call a TV repairman, or does this sound like a really big expensive problem that I should try to fight with Samsung about? We originally purchased this model in Nov '05, and had to have a replacement set in Jan '06 when something blew in the back of the TV and it would no longer turn on.
    President:
  • 3,130 Answers
The power compensator IC is bad along with most likley the main board. This is going to be an expensive repair. If the warranty expired in January, and you were in touch with them about then and they did nothing, you should try to fight with them. They may send out a repair person to get your set working again. Another possibility would be, if you have homew owners insurance and a tech can say that the problem was due to a power surge, the insurance will take care of part of the repair bill. Good Luck
Posted on Mar 23, 2007
SOURCE:
We had. n ice storm snow etc. Went thru about 15 times of power outage. The freezer side isnt cooling. Ice maker stopped. I have tried unplugging...plugging back in. Finally got ice maker to turn back on...
you have spent $1395.00 on a machine you hate
most people get rid of it after the first $500.00 bill as new fridges cost around $1000.00 and you get 2 years warranty
smart people with new fangled fridges power them through a quality surge protection device as well
Jan 23, 2018 | Samsung Refrigerators
Samsung Rs2530B frig had power outage, now cubed ice is blinking and water and ice dispensers are not working.
CONTROL BOARD ON REAR PANEL IS MOST LIKELY THE PROBLEM .THIS IS COMMON WITH STORM DAMAGE..
Apr 26, 2017 | Samsung Washing Machines
NEED TO KNOW HOW TO GET ICEMAKER OUT TO EMPTY IT
TURN OFF YOUR CAPS LOCK!!!!
Why on earth do you think the ice is "contaminated"?
The power outage would have to be days long to do something like that. The ice has to melt and the water has to become warm enough to grow bacteria or mold in a freezer full of frozen items.
If you just let it cycle through, it'll push out the "bad" ice cubes and you can just toss them out. The next ones will be made with fresh water.
Sep 07, 2016 | Refrigerators
Westinghouse ice maker quit working
Is it your ice maker, or possible the blades that crush the ice or dispense the cubes? What can happen in the latter case is that during the storm the ice melted and pooled in the cutter mechanism. Then, when power was restored, the blades were frozen solid. To fix, investigate taking out the cutter mechanism and letting it thaw and drain. Then reinstall and use frequently for the first few days to prevent refereezimg.
Feb 26, 2014 | White-Westinghouse White Westinghouse...
Flashing green light on control panel
Samsung refrigerator RS2530bwp
Cause: Power outage
Symptoms:
- One LED light flashing on console (in the Power Freeze section)
- Not running (not cooling, but inside lights work, ice maker not working, ice crusher doesn't work, water wont dispense)
Solution:
Press and hold for at least 10 seconds
Ice type button + Filter Reset button
Console should light up.
This is not documented *anywhere* on the web (until now). Best of luck
Aug 12, 2012 | Samsung RS2530BWP (25 cu ft) Side by Side...
Codes flashing on door screen after power blip
You had a power surge due to the storm, unplug the unit for 5 min's and see if it resets the faults.
Jul 09, 2017 | Samsung 24.6 Cu. Ft. 4-Door Side-by-Side...
Carrier Comfort zone 2 is flashing e1 after a storm/power outage
HEY THERE, DID YOU TRY POER CYCLING THE UNIT? TURN IT OFF AT THE BREAKER THEN BACK ON
SETH
Jun 27, 2009 | Carrier 38CKC060 Air Conditioner
Whirlpool Fridge Freezer not working fridge is
ID THERE FROST BUILDING UP IN THE FREEZER?IKE
Mar 14, 2009 | Whirlpool ET4WSKXS Top Freezer...
Ice Maker not working
Hi!!! your ice maker might have frozen over and gears are stuck..remove your ice maker and unplugg from the frig clean it and all is resolved..
Jan 04, 2009 | Refrigerators
Samsung TXR3079 TV Logo
130 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
