Question about Hitachi UltraVision CineForm 55VG825 55" HDTV
Rear Projection Blinking
My tv appears to be blinking about every 3 seconds. What does this mean?
  • 3,130 Answers
Very common problem with this TV set. One of two probles. First could be that one or more of the picture tubes could have leaked the fluid onto the main board. if the board is not corrodied, it can be cleaned and the picture tubes will need to be resealed with new "o" rings and new fluid. Next, It is a defective DM module inside this TV. You can take off the cover and look for four capacitors that will be together. You will see the tops are swelling. Change these capacitors and you should be set. If this does not correct the problem, the dM module will have to be replaced or rebuilt.
Posted on Mar 23, 2007
TV turns red,shuts off, stand-by light blinking 8Times
Eight blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some projection models of Sony TV sets, this code means that T8005 (flyback transformer), or the associative components in the high voltage circuits are defective on the D board.
Feb 27, 2014 | Sony KP-51HW40 51" Rear Projection...
On my Sony Rear projection LCD TV, the picture just faded and disappeared. BUt the sound is still on. Does this mean that the bulb needs replacement?
Check how many times the lamp light is blinking, if it is blinking 3 times, it is time to replace the light bulb. If the stand by light is blinking 6 times its is the thermal fuse
Apr 13, 2011 | Sony Grand WEGA KF50WE610 50" Rear...
Tv light standby red just keeps blinking after replacing bulb
If red light was not blinking before lamp replacement and after that it start blinking 3 times then pause for three seconds and again blink, check lamp cover that has not been fixed on tv or it is not fixed/ seated correctly there.
Lamp cover is first thing that you removed from tv to replace lamp.
Hope these info will help. If red light is blinking other than 3 times, let me know how many times it is blinking along with tv model number written at rear to provide you helpful info.
Jan 27, 2011 | Sony Grand WEGA KF50WE610 50" Rear...
My Sony KP-46WT500 screen shows the tv image in blue only for a few seconds, then it goes completely blank (as if it were off). Do I need to replace the bulbs?
It is rear projection TV that use 3 picture tubes of red-green-blue to show color picture on tv front screen.
Do you see standby red light blinking when TV shuts off after showing blue image for a while?
If red standby light is blinking, please count it how many times it blinks, there would be 3 seconds pause between blinks so count pause to pause and post it here to find out possible solution.
Dec 22, 2009 | Sony KP-46WT500 46" Rear Projection...
Sony wega kp51 turns on for 3 secs than off w/ blinking red light
The flashes are fault codes. It means your system is faulty. If it is intermittent then it is more than likely a dust issue. Buy an air duster, spray out the back and restart. Should be fine
If it continues to play up then it will be a repair job
Dec 08, 2008 | Sony KP-51WS520 51" Rear Projection...
Sony blinking standby light
That means current overload transistor Q5001 or Q5201 is shorted on the D board and must be changed
Apr 22, 2008 | Sony KP-57WS520 57" Rear Projection...
Ws 55513
The constant blinking green light means that the TV is not booting up. This is a common problem on this set.You need to remove the shield from the DM board (standing upright on the left where the DTV RF connector is)and inside you will see the four leaky capacitors (1000 MFD 16 VOLT)replace them,plug the TV in and wait 70 seconds for the blinking light to stop,then turn on the TV.The hard part will be removing the board from the TV(lots of screws and connectors,takes time)
Sep 22, 2007 | Mitsubishi WS-65613 65" Rear Projection...
Hitachi UltraVision CineForm 55VG825 55" HDTV Logo
46 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
