Question about Olevia LT37HVS 37 in. LCD HDTV
Connection for hd.
How do i connect the various cables for hd? also my remote was inactive for a while and is not working now. i have changed the batteries but to no avail. can i re-code it and if so how do i go about that?
  • 43 Answers
That depends on what your HD source is: cable, antenna, satellite,DVD....please be specific about what you're trying to hook up to your TV.
Remotes don't "die" because the battery died. If you've put in new batteries and it doesn't control your Olevia TV, then the remote is likely broken. Again, be SPECIFIC. What remote are you talking about? The original Olevia remote? A universal remote?
Curmudgeon
Posted on Dec 17, 2008
Elonex xv-s telvision no remote control cant find sourse to connect playstion without it.sky box is picked up automatically when switched on. it on scart connection
37" Elonex Widescreen HD LCD Television (Black) - Aria ...
www.aria.co.uk/.../Televisions/.../37%22+ELX+Widescreen+HD+LCD+T...
Buy 37" Elonex Widescreen HD LCD Television (Black) - HDMI, 1366x768, 1200:1, 8ms Product Name: 37" LCD TV Model No: LT37V1 Main. ... 49~61KHz; FrontControls: Power, Source, Menu, Channel Up, Channel Down, Volume Up, ... Have you tried it with a HDMI connection as I can't seem to get mine to work with my ...Missing: playstion
[PDF]Operator's Manual - SunBriteTV
https://www.sunbritetv.com/media/pdf/...R/3230HD-Op-Manual.pdf
6) Do not install near any heat sources such as radiators, heat registers, stoves, ....Water-Resistant. Wireless Remote. Control. Model 3230HD. TV Installation .... If youcannot achieve that ... to both your DVD player and Composite's S-Video connector ....Connect an HDMI cable to the HDMI output of your Playstation 3.Missing: elonex
Jan 12, 2016 | Televison & Video
How do I change the screen resolution on the TV from "standard 420" to HD?
The screen resolution will automatically change based upon the resolution of the input signal.
Are you using an RCA connector? Perhaps an S-Video connector? NEITHER OF THESE ARE CAPABLE OF PRODUCING HD VIDEO!!!
In order to view HD video, you must use one of the following:
  1. HDMI connector (optimal)
  2. DVI connector (almost as good but requires a separate audio connection)
  3. RGB video connector (also requires a separate audio connection)
If you are using one of the three connection types above, contact your DirecTV representative to find out how to switch your cable box output from SD to HD.
Jul 20, 2014 | Vizio 42"" vw42lhdtv10a 720p widescreen...
We bought a used Philips 42" flatscreen digital TV with no remove and hooked it up to our cable box. It works beautifully but we have not able to reset the screen size using the side buttons and menu...
Yes there is a trick. Usually the cable box and its remote determines the picture's screen size. First off, this television is able to display hd on an hd cable box. Make sure that this cable box is connected with this television the hd way only. It should only be connected to your television with either a component (green,blue,red, white, red) cable OR and hdmi cable. The coax cable should not be used to connect the cable box to the television if you have an hd cable box. Next make sure the television is on the proper input/source to display the cable box in hd.
Now if all of this has already been done, look for the hd zoom # button on your cable remote. It is usually towards the bottom. When you press it you change the screen size. You can buy a philips remote-the original one for your television at http://www.replacementremotes.com if you need the wide/stretch/zoom/viewmode button to further adjust your picture size.
Jul 16, 2011 | Televison & Video
Sony xbr lcd screen going all green on occasion
This is an HDMI compatibility problem. Your cable/SAT box is not playing very nicely with the TV. You can try replacing the cable/SAT box with a different model # or switch your connection type from HDMI to Component (5 wire connection). I hope this was helpful, best wishes.
Apr 17, 2010 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
Why won't the HD channels come in on my lg flat screen monitor? We changed the cable box and everything. Any suggestions?
The first thing you need is the HD tuner. Since you stated that you changed the cable box I will assume that means it's HD ready.
So you have HD signal coming in to the cable box box by-way of a coaxial cable. Now you need to get that HD signal to the monitor. For this connection the standard coaxial cable normally used between the TV and cable box will not do the job. How many connection options you have depends entirely on the what is available on the monitor.
Normally there are three choices. Your monitor could have anyone of these, a combination of them or none if it's not HD ready.
They are Component cable, HDMI and DVI.
Component is a combination of three RCA type (red, blue, and green), connectors. Simply connect the "Component Out" from the cable box to the "Component In" on the monitor.
HDMI cable looks similar to a computer monitor cable but bigger. Same goes for this one. Connect the "HDMI Out" from the cable box to the "HDMI In" on the monitor.
An indirect connection can also be made if your monitor has a "DVI In" jack by using a cable that will allow you to come from the "Out" connection of either the HDMI or Component on the cable box to the "DVI In" on the monitor.
If you are unclear about anything or you have any other questions please just ask and I'll try and help out.
Oct 02, 2009 | LG Computers & Internet
Hd display gateway monitor is working but has no signal
Hi
If this is still under warranty, then Gateway (MPC) can repair this. Probably you homeowners insurance will pay for it. Make sure that the monitor data cable is plugged in correctly. Whenever we have storm my wife unplugs all the cables on the computer. Sometimes when we reconnect they get plugged into an inactive port, thus no pic. If none of these help then please contact me at micromend@live.com and we can discuss a repair plan.
Thanks
Jun 20, 2009 | Computers & Internet
Time Warner Cable won't identify Linksys WRV54G wireless router
If you can connect directly via your modem, then the line up to your house is fine. So no problem with your ISP.
Since you changed from cable to DSL, you might have to re-configure your router.
Open a web browser, type "192.168.1.1" in the address bar and log on to the web based router configuration page. (The default values are "admin" for username and "admin" for password)
Go to "Setup", choose "Basic" and review the entries there. You want to see it configured for "PPPoE".
Some DSL-based ISPs use PPPoE (Point-to-Point Protocol over Ethernet) to establish Internet connections. If you are connected to the Internet through a DSL line, check with your ISP to see if they use PPPoE.
If they do, you will have to enable PPPoE.
User Name and Password: enter the User Name and Password provided by your ISP.
Connect on Demand: Max Idle Time. You can configure the Router to cut the Internet connection after it has been inactive for a specified period of time (Max Idle Time). If your Internet connection has been terminated due to inactivity, Connect on Demand enables the router to automatically re-establish your connection as soon as you attempt to access the Internet again.
If you wish to activate Connect on Demand, click the radio button.
In the Max Idle Time field, enter the number of minutes you want to have elapsed before your Internet connection terminates.
Keep Alive Option: Redial Period. If you select this option, the router will periodically check your Internet connection. If you are disconnected, then the Router will automatically re-establish your connection. To use this option, click the radio button next to Keep Alive.
In the Redial Period field, you specify how often you want the Router to check the Internet connection. The default Redial Period is 30 seconds.
When you have finished making changes to the screen, click the Save Settings button to save the changes, or click the Cancel Changes button to undo your changes.
(This info is from the Linksys manual)
Dec 29, 2008 | Linksys -Cisco Wireless-G VPN Broadband...
HD Video Recorder - CEC connection with HDTV
My first question would be, Is your Panasonic HD recorder CEC compliant? CEC means Consumer Electronics Control. That simply allows for the consumer to have better control over their Home Theater set up through the connection of you HDMI cable from their remote control without programing the remote control for every single device that is connected. If your recorder is CEC compliant the television should have automatically recognize the recorder and control you recorder via remote control (I am assuming that your recorder is an HD Camcorder, since your description was very vague). Once you connect your HD camcorder to your panasonic tv the tv should have turned on switching to the correct input and the same for any other CEC comliant devices. If your Panasonic HD recorder is not CEC compliant the you would have to start viewing your recorder the old fashion way, by using the recorder remote control or if your Toshiba remote is universal punch those codes in so that you can control your devices that way. If that don't work, try a different HDMI input and select the input and make sure your recorder is set to output on you tv. Hope this helps.....before I forget, check out this site to learn more about Consumer Electronics Control (CEC) http://www.videsignline.com/howto/207400325
Nov 23, 2008 | Televison & Video
Celestial HD Digital Television Receiver DVB8800HD
Normally, there are 2 ways to hook these devices up. One is the component cable that has 3 colors, red white and yellow. these color codes match an aux. input on the TV (or vid1 or vid2) You need to change the TV input to whichever you used by the remote or maybe under Ch2 (4,3,2,vid2, vid1, aux,111,110,etc) The other way is to use the round 4-5 pin S-video instead of the yellow jack, that is self explanetory. The 3rd way and this depends on your TV and receiver is to use the HDMI, composite or DVI cable connection. These are only for Hi def players and will be either a large multi-pinned computer type plug, 5 colored/lead "octopus" cable, or a smaller D shaped high density cable with the row of contacts inside the plug. In any case you need to tell the TV which input you are using.
Once you get the TV to show a picture of the receiver, then you autoprogram the receiver with the remote under setup or other menu.
Jul 24, 2008 | Televison & Video
HD cable question
It sounds like you dont have the right HD box. When connecting HD you will use an HDMI cable or a component cable consisting of 5 cable total 3 for video two for audio. Coax cable is not used to connect HD to your TV / Monitor.
Mar 27, 2008 | Televison & Video
Olevia LT37HVS 37 in. LCD HDTV Logo
78 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
