Question about Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White
My oven on the fridgedare PLEF398d will not work, but everything else does.what is the problem?
  • timothyclark Dec 17, 2008
    Please help with an answer. I thought maybe it was the electronic oven control board HELP!!!!!!!
    I don't know if this is it because everything else works. I don't know about a lockout feature. I did not see that. Thanks for your reply.
  • 8,197 Answers
If your oven has a lockout feature, check to see if it's been selected. If so, it will prevent you from using the oven.
Posted on Dec 17, 2008
Have a chef fan forced wall oven model number EOC624W - everything working except there is no heat
Check the house circuit breaker for the oven. If 240 isn't present, everything else will work except the heating element. The circuit breaker will have it's handles joined so if one trips they both trip. Unfortunately, this doesn't always work, Meaning one can trip without tripping the other so only 120 volts is supplied to the oven.
Dec 13, 2016 | Ovens
Timer is ok but oven not working
Nancy,
I understand that you are having trouble with your oven, model# CPLEF398DCE, not working/heating, even though the display screen is showing everything to be working fine. I suggest you give your appliance a hard reset. You will do this by switching the circuit breaker off, that the oven is on, for 3-5 minutes. Once the 3-5 minutes has passed, switch the circuit breaker back on. The first thing you will need to do, is to set the time. You will do this by entering in the time and pressing start. Turn the oven on. If you are still having trouble with the oven not working/heating, I suggest you contact your local authorized technician to come and diagnose the oven, to see why it will not work correctly.
-Best Regards-
Jan 19, 2014 | Frigidaire Ovens
My fridgedare oven as u see almost caught a fire ! Help plz!
The repair would be to make sure the power is off and find out if the component it was attached to is ok if so just cut the wires and put new ends on it
Sep 27, 2012 | Ovens
My daughter canceled the self clean on my Fridgedare Oven Professional series gas stove oven door and now I can't open the lock to use the oven again. How do I reset it. Thanks Erika
Disconnect the power supply cord for several minutes. It should clear the memory and restore it to factory default settings. Also check for a reset button.
Apr 15, 2011 | Ovens
I have a 2 yo fridgedare stove that the oven went out..the stove top is working but now oven isn't? The other day while i was cooking a loud noise like a "boom" happened and now oven not working?...
The noise you heard was probably the oven element short circuiting to earth. If the cooktop and grill are working then the fuses, internal/main must not have blown. If this is the case the oven indicator light should come on when you turn the oven on. If it does the oven element is definitely faulty and needs replacing.
Mar 05, 2011 | Frigidaire Ovens
Lock on oven stuck closed /self cleaning it at the time how to open it please help fridgedare
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
Jan 05, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
Everything works on the oven except the oven , wh...
If you mean that the fan in the oven will not come on check that the clock just needs resetting.
Hope this helps.
May 20, 2010 | Ovens
OVEN WILL NOT HEAT. EVERYTHING ELSE WORKS, BROIL,
look closley at teh bottom bake element possible it has broken, causing this problem
Feb 09, 2010 | Frigidaire FEB27S5A Electric Single Oven
Model MGR5775QDB Everything works except Oven
Searched the internet until I found a service manual, which led me to the right area to look. still working
Jan 12, 2010 | Ovens
Frigidaire Gallery Professional Series - No clock/oven functions
i have an old model of the fridgedare gallery professional series stove. After self cleaning, the ignition sparks for the burners will not come off, they keep clicking and only stops when i pull out the plug. can you help me with this situation?
Nov 01, 2008 | Frigidaire FGB24S5A Gas Single Oven
Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
110 people viewed this question
Top Frigidaire Ovens Experts
Oloyede Monsuru
Craig Butler
Craig Butler
Starnley Johnwells
Starnley Johnwells
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
