Question about Roper RS25AEXLQ Side by Side Refrigerator
Freezer side Allows Ice cream to go soft about 1-3 times a week
Fridge side is fine, freezer is okay most of the time but it intermittently allows items such as ice cream and a muffin e have frozen to get softer. We generally use the muffin to determine how bad off it is. So far it has not thawed completely out but has gotten soft up to about 10% of the total muffin.
    Problem Solver:
  • 9 Answers
THERE IS A HOSE FROM THE BACK TO THE BOTTOM AND CAN GET PLUGED CLEAN OUT OR REPLACE AND CHECK SEALS FOR LEAKS OF AIR. HAVE A GOOD ONE.DAVE
Posted on Jan 03, 2018
4 Suggested Answers
  • 531 Answers
SOURCE: Freezer not freezing
you may have defrost problem or check fan by compressor
Posted on Apr 07, 2009
  • 351 Answers
SOURCE: Loud noise from refrig.
you have a defrost problem, check the termination switch or timer if you need more help let me know whirlpoolpartssurplus.com - mark
Posted on Jun 25, 2009
  • 72 Answers
SOURCE: freezer working fine (no ice buildup), refrigerator warm
make sure your cond under ref is clean allso check your door gaskets if its getting moisture in it i have seen the damper stick from ice from door gasket and when your defrosting evap its clearing damper
Posted on Jul 05, 2009
Model TFH30PRTA NOT KEEPING ICE CREAM FROZEN
Ice cream will get hard when the temperature is closer to - 20 C or -1 F scale. Water becomes Ice at 0 C or 32 F scale.
Ice cream soft means your freezer is not cooling enough.
You were cleaning the coils? Both condenser and evaporator coils? Cleaning coils and then loosing cooling in the fridge is not a good sign or combination. May be there is a freon leak and the seal system is low on freon now.
Call a service tech to check the seal system.
Unfortunately, if it is a leak you may eventually buy a new fridge after spending money on freon fill up, freon system sealant, leak check etc etc... No good news. Sorry
Oct 25, 2017 | GE Profile Performance 29.8 cu. ft....
Hi my freezer is freezing intermittently. For example, it will freeze the ice cream and then the next day the ice crease is soft. it may go two days working fine and then back to the same problem again...
Hi, The defrost timer is sticking on sometimes...replace it..
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Sep 09, 2011 | Whirlpool GD5SHAX Side by Side...
What setting between 1-9 should I set Freezer to prevent freezer burn
Good day,
Freezer burn is due to too cold a temperature in the freezer compartment. Nominal for that machine is 4 to 5.
However only time will tell you what is acceptable, since freezer burn can occur even at a warmer setting, if the product is stored a long time.
1 is warmest and 9 is coldest. I would lean to a slightly warmer setting to start off but that will create a trade off, since it would reduce the speed of ice production, and with especially high quality ice cream, possibly ice cream being too soft.
Patience is your friend here. But what you want is there.
Aug 15, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice Cream In Freezer Is Soft
DON'T BY ICE CREAM! LOL Try putting ur ice cream somewere else
Oct 26, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Freezer is cold but not keeping icecream frozen.
If, the fresh food section is 34- 38 degrees, then the freezer should be cold enough to keep ice cream solid. All of the cooling capability comes from the freezer section. I, personally, would not waste time or money on a ten year old box. Ten years ago it cost $1000, so, the outlay is $100 per year. Dump the old refrigerator and get a new one.
Aug 27, 2009 | Refrigerators
Amana SBD 522VEBONY - fridge freezer is not staying cold -
If your freezer works after regassing...and after sometime the problem occurs again. It seems to me that there is leak on the pipes in which where the gas runs, that is why it runs for sometime after regassing, after some time the gas that was loaded during regassing leaked through the atmosphere and the problem occurs again. It would be better if you replace it with a new fridge.
Hope this idea helps.
Jan 05, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Cuisinart ice cream-frozen yougurt maker& sorbet maker CIM 60 series
I have the same problem, but it seems that it has gotten worse with time. When I first bought this product 6 years ago it worked fine, now the bowl won't freeze entirely and it has been in the freezer for two days (at the lowest freezer setting). I am wondering if the freezer bowl has a life span.
Aug 03, 2008 | Cuisinart ICE-20 Automatic Frozen Yogurt...
Refrigerator not that cold and freezer not freezing well
between the door and freezer is very hot, and the refrigerator is not that cold and the freezing is freezing but not that well, ice cream is soft but meat freeze and ice is not melting. Also behind the fridge at the bottom is very hot.
Jun 05, 2008 | Kenmore 64802 Top Freezer Refrigerator
Roper RS25AEXLQ Side by Side Refrigerator Logo
63 people viewed this question
Top Roper Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Steve Allison
Steve Allison
Are you a Roper Refrigerator Expert? Answer questions, earn points and help others
