Question about Pyramid PWFX107 Car Subwoofer
750x to 2 10" pyramids
How do i hook them up to make them loud but not sound bad and not blow them but they havent blown yet
    President:
  • 3,130 Answers
There sould be an input level control on the main amp that drives these woofers. Adjust the input so that even iof the stereo is tuned up all the way the amp is limiting the amout af input. Before you do this and turn up the stereo, turn down the amp input control all the way then you can slowly bring it up when you turn up the stereo's volume. Good Luck
Posted on Mar 23, 2007
I have # r13 resistor blowed ps52kx pyramid
It was "blowed" eh?
Recommend contacting a local car audio professional or Pyramid customer support directly here:
http://www.pyramidcaraudio.com/ContactUs.aspx
Mar 09, 2014 | Pyramid - PS52KX 40 Amp Power Supply Car...
I have 2 12in kenwoods and a 1200 watt pyrimade amp, how can i hook these up to be the loudest
1st have your subs facing inwards towards the front of the car, not facing out the boot, This creates a better bass.
Wire 1 sub to one channel and the other sub to the other channel.
Turn down your gain as low as possible and then power everything up.
turn volume to desired loudness and then start turning up the gain slowly, if distorts a little turn in back down a notch.
avoid using bass boost, I agree it sounds great but it puts more strain on your amp and shortens its life.
after sorting out your gain, tweak all others until sound is bassy and clear with no distortion.
If you would like to use bass boost, turn on bass boost first, then up your gain etc.
Jan 16, 2013 | Pyramid PB915X 1200 Watts 2 Channel...
Blows fuses
Fuses Blow...
Feb 20, 2012 | Pyramid Car Audio & Video
1600 watt pyramid royal blue 2 channel amp need diagram of amp itself
if i keeps blowing fuses then it means the amp is bad
May 12, 2009 | Car Audio & Video
Amp over heating and cutting off
sounds like the Impedance of the speakers does not match that of the amp, therefore the output stage of the amp is trying to compensate, driving the amps too hard and eventually causing the thermal cut out to activate. Check the ratings on everything are compatible before you start sending it off to be fixed.
Mar 22, 2009 | Pyramid PB736GX Car Audio Amplifier
Pyramid - PS21KX 20 Amp Powersupply overload
The problem I have had with a PS-20 is a blown capacitor. Hooked to a radio, would allow radio to receive fine, but when trying to transmit, amperage would bottom out. Behind the transformer is a large circuit board. UNPLUG POWER SUPPLY, remove cover, Undo the two nuts, flip board over, and gently rock the 4700uf capacitors side to side. If they move more than 1/16th of an inch, chances are they are blown. Remove/replace and should be good to go...
Jan 10, 2008 | Pyramid - PS21KX 20 Amp Power Supply Car...
Rockford 750X
Check your wiring, and if everything is fine you might have a blown or broken channel on your amp
May 22, 2007 | Rockford Fosgate Power 750X Car Audio...
Pwfx107
its hard to tell whats wrong with so little info , but theres alot that you can check , Is your amp putting out the power ? If the amp is a Pro series 750x amp then check your amp inputs they might be too low hence low output. Otherwise i would like to know what size of enclosure you have these spekers on and how they are connected to the amp.
Mar 21, 2007 | Pyramid PWFX107 Car Subwoofer
Pyramid PWFX107 Car Subwoofer Logo
52 people viewed this question
Top Pyramid Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
ALPHANSO TAYLOR
Level 1 Expert
xxxxxx xxx
Are you a Pyramid Car Audio and Video Expert? Answer questions, earn points and help others
