Question about Lenovo 3000 C200 Notebook
Daughter Laptop...says Error USB over current hc/port.. is a Lenove model 0768.. any ideals?? Thanks
  • 57 Answers
Normally that means that she has connected possibly something into a port or 2 that exceeds the limit the windows defines. You cant change this limit however if she was to put it into a different port or to remove one of the devices that does not have its own power supply it will work again. Only thing its saying is that you have too many objects in the port that require power from those ports. In other words... It cant supply enough power to the things plugged into the usb hub [2 usb ports(usually by each other)]
Posted on Dec 17, 2008
Usb over current
Fuse or supply chip has failed. A repair to the mother board is required.
Jul 24, 2013 | Toshiba SATELLITE A100-TA2 LAPTOP LCD...
Cannot connect with webex
"Over current" means you are drawing too much current from that port. If you have several USB devices attached at the same time it may be that you have too many and the system cannot supply the current needed. OR your machine isn't putting out enough current. Try unplugging everything but what you absolutely need.
Jun 23, 2013 | Microsoft Windows XP Home Edition
Experiencing following on boot: Lenovo 3000 C200 PC Notebook Error 0701 usb current hc port. Both USB ports disabled. Any advice on remedy.
Kindly set the BIOS on start up. You may have disabled the USB. If the matter persists then check the drivers in the device manager if they are correctly installed. Or if the problem is your Operating System then have it updated by installing online updates. This would install necessary drivers. If the problem still persists then, look for a computer technician to check your laptop.
Jan 31, 2011 | Lenovo 3000 C200 Notebook
Error 0701: USB Over Current on HC/Port
Error 0701: USB Over Error 0701: USB Over Current On HC/Port - Bus:00H Dev :1DH Fun:01H / Port:00HCurrent On HC/Port - Bus:00H Dev :1DH Fun:01H / Port:00H
Sep 28, 2010 | Lenovo 3000 C200 Notebook
Error 0701 problem in lenovo laptop 3000 c series and N
Try turning on the computer in safe mode and turn on the computer by pressing f8 and see if that works. check in the bios if the cd drive is detected make sure that the disk you put in cd drive is a bootable disk
Jan 09, 2010 | Lenovo 3000 N100 Notebook PC
0701 usb over current on hc/port error
I had the same problem on a toshiba satellite u400.
Usb over current on port ... blabla..
Please press F1 to resume or F12 to install.
F1 just ended up in a screen asking to press F2 or F12 which did nothing.
F12 did nothing.
Rebooting the pc ended in a black screen with a flickering HD symbol.
To be able to boot again on the BIOS I had to remove the battery and disconnect the plug.
Once It restarted booting on the error USB over current.
Si I took a USB mouse and tried to boot with the mouse plugged in on port , then another ... at the third port the PC booted normally with no error :)
Don't have any idea why it became faulty but it's now solved for me.
Mar 12, 2009 | Toshiba Satellite A135-S4527 Notebook
Hardware problem - not booting into windows
One of your usb ports is either damaged or has an object stuck in it causing a short. Unplug all usb devices and look at each port. Note if one looks slightly different from the others. There is a plastic tab that fits into usb plugs. If this tab is bent and touches the side of the port, it can cause the short. If this is the case you may be able to either clean out or bend back the bent tab.
Sep 08, 2008 | Lenovo 3000 N100 0768 - Pentium Dual Core...
tosrisri hello,
If you have a VISTA DVD, please insert it, and use the BIOS to boot through your CD.
Then, when the VISTA installation comes up, press repair. Restart, and try again. Please report back.
Aug 09, 2008 | Lenovo 3000 C200 Notebook
Lenovo 3000 C200 Notebook Logo
77 people viewed this question
Top Lenovo Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
