The computer boots and goes into Windows briefly, then screen goes blue w/squigly lines (off). Please Help!
I have one dell xps m1330 laptop. These are few days my laptop has getting some problems. When I on my laptop it will appear blue screen. I can’t see anything. I had change hard disk and Ram. Some times I have switched on my laptop that time ask press F1 or F2 or F5. When I press F1 it will go to window. What is actual problem? Would you help me?
SOURCE: I am trying to reinstall Windows Vista on Dell
try not to delete partition 0 recovery disc, just delete partition 0 operating system
SOURCE: ran diagnostic on dell inspirion got error code
This message only occurs when you run the diagnostics and did not have a disc in the drive at the time. To confirm, pop a dvd into the drive and re-run the diags.
Hope this helps!
SOURCE: Will pass bios but then will not load windows
step 1. open up the case and locate your hard drive
step 2. carefully remove the cables and power to the hard drive and remove it
step 3. goto your local office depot, staples, walmart or radio shack and buy a nice new hard drive somewhere around 250 gigs should be plenty for you,
step 4. now that yopu have a nice new hard drive put it in the spot where your old hard drive was in the conputer and plug both cables back into the new hard drive, after this is done put your case back on and start the computer up with your windows cd in the cd rom drive and reinstall windows. :) hope this helps
SOURCE: Error codes with internal check
At this point, you need to get your info backed up and then reinstall the operating system of your choice.
