Question about Haier HSL04WNBSS Compact Refrigerator
Overloaded Haier I have been using my Haier AES44 since April 2006 and it has worked fine. The other day I loaded it with more cans than I should have and when I went back the next day I opened it up and it had quit running. The freezer was defrosting and ice had melted inside the unit. I completely unloaded the fridge and turned the knob to off. I dried out the inside and let it set for a couple hours and turned it back on. You can hear a click when it comes on and a slight hum for about 15 seconds, then another click, the hum stops and thats all that happens. I can let it set for awhile and do it again but it does the same thing. I pulled it away from the wall and felt the round thing on the bottom back of the unit and it feels nice and warm. Any suggestions would be appreciated.
  • Anonymous Jan 04, 2009
    Haier AES44B about 4 years old. Stopped running, compressor warm, hear periodic clicking. let compressor cool down overnight, did not solve the problem. Will not start.
    Unable to locate parts diagram or parts list for this model? Any suggestions?
    Tom
  • Anonymous Jan 24, 2009
    HAIER Refrigerator ASE44B Not Working.
    Hums, clicks and does not start.
    Problem seems to be the PTC module or compressor. Cannot find a source for the PTC module (marked P6R8MDOR0503). Don't believe I would replace the compressor.
    www.apwagner.com has a parts list, however this list does not breakdown below "compressor w/accessories" part RF-1750-71 for $162.00. About $50 above the cost of a new refrigerator. This part number would apparently include the PTC module and the overcurrent device which are plugged into the compressor.
    I am about to give up.
    Don't believe I will buy a Haier product in the future
    Tom
  • 1314 Answers
SOURCE: freezer okay, fridge warm
any time the compressor is running the fan in the freezer should be running now you need to empty the freezer do you see a lot of frost on the back wall of the freezer you either have a defrost problem and frost has built up so much its stalling the fan or the fan its self is bad pull the back cover off the freezer wall and tell me what you see please also give me your model number off the serial plate which should be in the fridge section put your freezer stuff in the fridge while we check it out
Posted on Jan 30, 2008
SOURCE: Haier HTQ21JAAWW ISSUES!!!
my refridgerator seems to be workin the freezer is getting cold but not freezing its a top freezer bottom refridgerator the fan in the freezer is also not workin.i had atec come out to check it out. supposedly theres a capasitor that sits next to the compressor that he told me was bad an had to be ordered.its got 2 wires that come off the compressor that plug into this lil box.my question is could this be why my freezer is not freezing an also why the fan inside the freezer is not workin?
Posted on Jul 17, 2008
SOURCE: Haier model# HTQ21J*SS freezer ices up with melted water, not draining
I have the same problem. I pulled off the panel inside the freezer and the motor fan wont move and there is black soot all over like there was a fire and it has a burned up smell inside.
Posted on Sep 22, 2008
MNTECH
  • 1543 Answers
SOURCE: GE refrigerator 12 years old runs continuously, exterior warm
Probably not. Newer (and I mean under 15 years old or so) refrigerators may run more % of the time than older units, but are using far less energy while running, so total energy consumption is actually less. The newest energy star models often use less electricity than a single incandescent light bulb uses if left on 24/7. If your run times are noticeably longer just recently, and there have been no other significant changes to account for it (like more and / or longer door openings or a warmer ambient temp., etc.) then you may have caught a defrost problem or bad door gasket problem early. The warm temp on the outer case near the freezer is to prevent condensation from forming in those areas, and is normal. (as a matter of fact, older refrigs often used low wattage electric heaters for that task, almost all newer units use waste heat from the cooling system to accomplish that task) Please don't bother rating this solution, as anything but a Fix-Ya lowers my overall score. Thanks.
Posted on Feb 16, 2009
  • 72 Answers
SOURCE: Air or gas leaking from freezer in Haier mini fridge
If you go to a refrigeration supply the sell an epoxy to repair the evaporator but you will need to do a sealed system repair
Posted on Jun 07, 2009
Haier dishwasher keeps tripping electricity for the plugs for last few days. Is it a power source issue or a dishwasher problem
You can turn off the breaker that is supplying power to the dishwasher, and pay close attention to whatever else no longer has Power such as light fixtures, plugs, etc. it is quite possible that the circuit may be overloaded (too many devices on that breaker) your problem may only occur when all of the devices are being used at the same time.
Dec 07, 2013 | Dishwashers
My Haier HLP21E top load washer is only one month old, and there is some leaking from under the machine.
Check the hose clamps on the bottom. Sometimes the clamps are not all the way on or tight enough. I saw one that did the same thing.
EDIT: one of the mounting screws on the bottom of the tub will create a "tear" (or another word that rhymes with track) in the tub (Fixya says "The word $@#%^ is considered as profanity on Fixya. Please review your answer and try again").
I used a plastic soldering iron from Harbor Freight and cut a piece of the plastic webbing off the tub to "solder" the hole shut on the tub.
Aug 22, 2012 | Haier HLP21E Top Load Washer
Runs fine then for weeks then trips on high limit
Hi, sometimes high-limit goes bad, but why, check to make sure you're not overloaded with produce, check to make sure freezer has good ventilation, if your days are hot, high limit will switch off, to pretect compressor, could be compressor getting faulty, you should empty freezer, clean and restart empty for an hour, if freezing o/k, put back produce, if when clean and empty, does same thing, maybe your compressor is faulty, called a mechanic, or replace high limit switch. good luck.
Aug 09, 2009 | Haier 7 cu. ft. / 198 liter Chest Freezer...
Re holidays accrued.
Your 28 days holiday is free holidays (assuming you have not including predetermined holidays - i.e public holidays)
28 days divide by 12 months = 2.333 days
Your holiday year cannot be April to April as this is 13 months - so I have assumed it is April to March, or it could be May to April - This will affect how many holidays you have earnt upto August.
Multliply the 2.33 days per month by the number of months until your holiday in August. The calculation your employer is using may take into account you have to earn full days by the end of the month before you take a holiday.
2.33 days X 4 months to end of July = 9 days
2.33 days X 5 months to end of August - 11 days.
You may have to exclude the public holidays if this is included in your annual allowance
Apr 15, 2009 | Microsoft Office Standard for PC
Chevy s10
did you test the distributor?
Jan 20, 2009 | 1997 Chevrolet S-10 Pickup
INSIGNIA NS-PDVD10 Problem
I have a NS-PDVD8 . I purchased DEC 2006. I used it in April 2007 and then again in Jan.2008. When I went TO use March -2008 I received message NO DISCwhen attempting to play DVD.i messed with for an hour by rebooting and and dusting with compressed air.No help
next day I tried a CD and after very long loading time played music.
after I let it run for an hour I attempted DVD but same response.NO DISC
I cleaned the optical lens with a damp soft cloth and dried with soft cloth ( I do not recommend using a cloth but I was fed up and needed the player for flight next day) I believe you can purchase a cleaner kit.
I also ran the lens back and forth 5 or 6 times to make sure it could move fully along track.I heard clicking and wondered if this was ever going to run again.
I tried a CD first and the Cd loaded almost immediately and played
Next I tried a DVD and loaded successfully and played entire movie.
I turnred on and off about 10 times and reloaded movie without any problem.
Jan 23, 2008 | Insignia IS-PDVD10 Portable DVD Player
MRP-M450 puts out no sound to the subs
The amplifier may be overloaded, check to see if it can handle 4 OHM loads and 2 OHM loads. if it turns off at high volume the amp may be overloaded. if so try a 8 OHM load. if it still turns off it may be an internal problem.
Jan 07, 2008 | Alpine MRP-M650 Car Audio Amplifier
Blank screen at any time
is your charger original if not change it.
Jun 15, 2006 | Motorola Mobility V171
Haier HSL04WNBSS Compact Refrigerator Logo
270 people viewed this question
Top Haier Refrigerators Experts
John Tripp
John Tripp
geob91
doggzzz
Level 1 Expert
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
