Question about Dell Inspiron 1501 Notebook
Touch Mouse jumps around randomly and sometimes will not click
2 month old laptop never been dropped or had any problems with but randomly my mouse will jump around and i have no control of it for a few minutes. Any help would be appreciated!
    Problem Solver:
  • 32 Answers
It sounds like you should try re-installing the touch pad driver.
here is a link to it:
http://support.dell.com/support/topics/global.aspx/support/downloads/en/downloads_splash?c=us&l=en&s=gen&~mode=popup&file=160150
Posted on Dec 17, 2008
Unstable, jittery cursor
Lets give this a try: Click the Start button> click Control Panel> click Hardware> and then click Mouse. Click the Pointer Options tab, and then do the following: Uncheck the Hide pointer while typing box. Hope this helps you. Let us know either way. Make it a great day!
Apr 30, 2012 | Compaq Computers & Internet
The touchpad pointer is becoming increasingly erratic. For example it will not point easily where i am trying to locate;it jumps at random around the screen; it highlights without this function being...
Try going into control panel & find the mouse section. See if you can adjust the sensitivty down. You may have a program built in from acer to adjust this too. I reccomend turning off the tap feature on the mouse pad. When they get old they get real touchy. If turning the sensitivity down doesn't work, you can try & see if there's an updated driver or re-install the old one. If all else fails,it's time to head to ebay to find the touch pad.
Mar 17, 2010 | Acer Aspire 5720 Notebook
Cursor jumping, pages scrolling on own
bad mouse action , no other words need be said just that.
NO OP SYS STATED BY YOU< XP?
if the mouse is a wireless mouse, the battery is dead.
if the 1 mouse is wired it is bad.
if there are 2 mice connected , shut one down 2mice not allowed.
if the mouse pad is enabled then that is 2 mice if usb mouse used.
and not ever good to do that,
disable one of the mice. (easy no? rules)
i disable my LT here, , in control panel, device manager , mouse pad synaptic or what ever it is.
RC right click disable, it , I hate mice pads././/
Feb 28, 2017 | Compaq NX9005 (dk993ar) PC Notebook
My mouse touch pad is not working correctly. It
Sounds like your driver is corrupt, go to windows update and after it scans choose custom install, look at available updates and look for the hardware updates, there you should see your touchpad listed. Choose the drivers you would like update and click install. Reboot when finished.
Sep 21, 2009 | Computers & Internet
The cursor moves randomly while I use the trackball
this problem is caused by a defective mouse, replace it.
Sep 09, 2009 | Logitech Marble Mouse Trackball
Hp laptop touchpad mouse problems
IF U HAVE REPLACED THE DRIVERS TO THE MOUSE DEVICE THIS INCLUDES ALL THE PROGRAMS THAT THE SITE HAS TO RUN THEM. THEN ITS A HARDWARE PROBLE IN WHICH THE ACTUAL CONTROL FOR THE MOUSE CAN BE REPLACED.
May 25, 2009 | HP Pavilion DV6700T Notebook
Mouse will randomly double click or have to click several times to work
Please check whether there are any buttons on the side of the mouse you may be clicking these at the same time as you are single clicking.
You could also try going into Control Panel --> Mouse
Try Slowing down the double click speed
If that doesn't work try speeding it up
Another problem with a laser mouse is it jumps around the screen randomly if there is a pattern on your mouse mat or desk, or if either are too shiny or even glass as the laser reflects incorrectly on these type of surfaces.
Oct 18, 2008 | Logitech Cordless Mouse
Cursor jumps around
If your cursor moves erratically on the screen (for example, if it jumps around the screen, moves at varying speeds, or selects items on its own), perform the following steps:
  1. Clean the surface of the touchpad with a dry, soft cloth to remove grease, sweat, moisture, or other liquids.
  2. Adjust the sensitivity of the touch pad:.
    1. Click the Start button and click Control Panel.
    2. Click Printers and Other Hardware.
    3. Click Mouse.
    4. When the Mouse Properties window appears, click the Pointer Options tab. (Figure 1)
      Figure 1: Pointer Speed
    5. Under Select a pointer speed:, click to move the slider bar closer to Slow.
    6. Click OK.
    7. Check to see if the touch pad still behaves erratically.
  3. If the touchpad still caused the cursor to behave erratically, attach an external mouse to your computer and restart your computer. Use the external mouse to see if your cursor still moves erratically.
Aug 14, 2008 | Computers & Internet
How can I stop my curser from jumping around whilst typing ?
Hello
Most probably because your 'Touch Pad Mouse' is touched by your palm (hand or something) while you are typing. Avoid contact with the mouse touch pad while typing.
Option 2:
If you have a centre moveable mouse on your laptop, start using it and disable the 'Touch pad mouse'
Best of luck!
Jul 23, 2008 | Acer Aspire 5100 Notebook
Sensitive touch pad
Hi, click on start and control panel. go to mouse properties. Try to look for a tab that says either touch or touchpad. you can change the sensitivity settings there. however if this doesnt work, this could only mean that this is a physical problem with the toucpad. try to apply pressure on the outer side of the touchpad. if it moves, you're gonna need a replacement palmrest.
Oct 02, 2007 | Dell F3534 Touchpad
Dell Inspiron 1501 Notebook Logo
135 people viewed this question
Alun Cox
