Question about Dell Dimension 4600 PC Desktop
Won't boot up properly
My computer just shut down on me yesterday and now when I try to turn it on a screen comes up that asks me some options like, start windows normally, and return to previously remembered settings. everything I have tried won't work. HELP ME!!!
  • 1 more comment
  • nulphy2192 Dec 17, 2008
    I tried using safe mode and it just brought up a big long list of codes and different things.
  • Charlie Jarman
    Charlie Jarman May 11, 2010
    Choose the SAFE MODE option and let us know the results.
  • Grant May 11, 2010
    what happens if you try to boot in safe mode ?
Hey thanks solution #2, it worked. So when my computer wouIdn't boot up properly i would reset my computer to get into the safe mode menu, then i kept trying to do system restores on my computer but they wouldn't work because I would keep reseting my computer to get to the Safe mode, safe mode with networking, start windows normally screen.
So then i tried to do what you said once i started in safe mode and got the log in screen. I clicked the shut down button and actually safely shut down my computer. Waited about ten seconds to turn on my computer again and it loaded and booted properly. Thanks!!!
Posted on Dec 31, 2008
  • 34 Answers
2 options:
1 - do you have your XP CD.?
(you need the admin password for this if it has one.)
if so boot the pc up with this in the cd drive.
select R - reapair option.
this will take you into recovery consul (dos screen)
select the Operating system you need to fix.
When you get to a dos prompt, do a chkdsk on your boot drive.
This may fix any issues that have arrisen.
then reboot pc when done(remove cd)
if succesful you may have a working pc again.
Option 2
Your going to need a mates PC for this.
do a search on google for hirens bootcd v9.6.
down load it. Create the ISO.
put this CD in your poorly machine and select the
the ERD option (think it's erd 2005 or 6 at the moment)
let it boot up, bypass the network config settings
When fully up it will (hopefully if your drive isn't totaly stuffed) ask you which operating system to use.
Select the one you need (usualy only one displayed)
you will the be able to either do a restore on your PC (do a restart without cd in to see if worked) or, in a dos window prompt do a Chkdsk.
If either of these work then bobs your uncle you have a pc again.
If not I'm sure some of the other guys on here can suggest more options.
Posted on Dec 17, 2008
    Problem Solver:
  • 6 Answers
Try choosing Safe Mode. Then shut down windows properly, file shutdown, then start up again and see if that works for you.
2 Suggested Answers
  • 85 Answers
SOURCE: windows wont load
u have to reinstall xp
Posted on Jun 01, 2008
Computer won't boot
OverheatingWhen the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
Apr 26, 2012 | Computers & Internet
When i start my gateway netbook lt20 a black screen pops up asking to start windows normally or 3 other options.. why?does this happen?
Usually because you didn't shut windows down properly before turning your computer off or completely draining your battery. If that is the case then simply select start windows normally and as long as you follow the correct shut down procedure it shouldn't happen again. If it does there may be a problem with your windows instalation.
Aug 17, 2011 | Gateway LT2021u Netbook
Insert smart card into reader problem
I think its looking for a boot command from the card reader. Which means pressing the DEL or F10 or F2 key repeatedly while booting to get into your bios to change your boot order.
If it wont let you, try booting while pressing the F8 key, with luck it may bring up windows boot options, choose the safe mode. When up, Click on Start - all programmes - accessories - system tools - system restore - choose a date prior to problems. (This is for XP, Vista and Win7 slightly different)
Boot from your windows disk, and choose the repair option.
Or download, UBCD4Win , the ultimate boot cd for windows, This will load a windows shell system with loads of diagnotic and repair tools.
You could download and run Ubuntu without installing, that will give you access to any data files.
If none of this works, the only recourse is to re-install windows. But in
doing this, you will be re-formatting the hard drive which will remove all data on the drive.
If you don't have a copy of windows, you do have Ubuntu. I use it nearly all the time now, even though I have a dual boot system.
Jul 21, 2010 | HP Compaq nc6230 Notebook
I've just bought a new tower, hitched it up to the monitor - when I turn it on, it comes up, Windows begins, and then the monitor says the input signal is wrong, asks to have the resolution chnaged (I've...
The best way to solve this problem is to Boot windows with a reduced resolution of 800x600.
To do this, If you turn the PC off without properly shutting it down the option should be available if you press F8 when windows states "Your computer was not shut down properly"
Otherwise keep tapping F8 from the time you press the power on button and the boot options should appear.
Then select the option "Boot windows with reduced resolution quality "800x600"
Once windows boots up go to the Display properties by right clicking on the desktop and selecting display.
You should be presented with a window which customizes your desktop and allows you to change display resolutions. Open the window which allows you to change resolution and select the advanced option. Then you should be presented with another window which is the display driver properties. In this window select the monitor tab and make sure the box which say's "hide modes which this monitor can not display" is Ticked and this should solve your problem no matter which resolution you chose.
Apr 10, 2010 | HP vs19 19" LCD Monitor
Screen is black. Hear computer trying to boot up.
cpu fan failure try to put a big fan where the comp vents and air flows! and see if its not shutting down!
Jul 01, 2009 | HP Pavilion dv5-1000us Notebook PC
Start up problem
option1:- choose the option called safe mode. the first option. just log in and stay for a while in there and restart your computer.
option2:- choose the option start up windows normally.
Jun 18, 2008 | Compaq Presario 700 470024-192 Notebook
I HAVE A MEMOREX (MMP8640A) AND IT WON'T COME ON.
myn wont even turn on ..it was just like charged half full!
i had it plugged inot the computer ..and it wa turned on so i turned it off ..like usually when i plug it in it makes a noise then it loads and a list of options comes up now nothing ..before when it was connected ..yesterday.. the screen said do not disconnect now nothing is on the screen ..its plugged in right now .. i tried going 2 windows media player to sync some music but it says nothing is connected!!!
good luck
Feb 21, 2008 | Audio Players & Recorders
Dell Dimension 4600 PC Desktop Logo
110 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
