Sony kp53s35 tv blinks on and off when turned on.
Picture blinks on and off when turned on.It is becoming more frequent and lasting longer.
  • jimbabb Dec 18, 2008
    I'm having a similar problem with my Sony WEGA 36".
  • Anonymous Jan 16, 2009
    My Sony KP-53S53 does the same thing - Blinks on and off for about 2 minutes when first turned on then settles down and the picture is perfect.
    Wondering if perhaps a capacitor is failing?
    Deadwood
4 Suggested Answers
Slinteriors
  • 8617 Answers
SOURCE: tv picture blinks on and off
Sounds like a cracked solder joint. I would check the flyback mounts , then the horizontal and verticle deflection ciruit componnents for cracked solder joints.
Posted on Jan 04, 2008
  • 239 Answers
SOURCE: Sony KDS-60A2000 projection TV: power led blinks 4 times
the projector bulb has gone out you need to replace it.
hope this helped
please rate well
If you need further help, reach me via phone at https://www.6ya.com/expert/mark_445a24324be9eb03
Posted on Mar 04, 2009
  • 476 Answers
SOURCE: MY problem with Sony KP-53S35 53 in.
the number of flashes of the red indicator lamp points to the possible cause of the delay of the raster or picture, but usually it's an indicator of an emission unbalance between crt(picture tube) guns. the picture will take longer to show up as the emission on either of the picture tubes goes down.
Posted on Jul 27, 2009
KP53S35 when tv turned on picture was
You TV has a bad CRT, a red CRT by the sounds of it. This TV is rather old, perhaps 11-13 years of age? Your TV has given you many years of service and I do applaud you for the care you have given it and the TV for it’s reliable in your home. The trouble you face with a rear projection CRT set of this age is that you can’t just change 1 CRT tube and expect it to be reliable and produce a good picture. All 3 tubes should be replaced, as they have all aged the same. The lives of these tubes are only about 7 years. A tube is not any easy or inexpensive repair on any RPJ TV. When you are faced with the cost of 3 tubes, which may not even be available in the market place… You should consider retiring this old friend and keep the manufacture in mind as you make a new purchase.
Mar 14, 2010 | Televison & Video
Picture and sound shut off, blinking green standby
MY SONY PROJECTION TV WENT BLANK WITH NO SOUND GREEN LIGHT WAS ON WHATS WRONG
Oct 14, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony Grand Vega green light blinks on and then blinks red
Please intimate exact model of your Sony TV and also mention how many times red light blinks as there would be pause of 3 seconds in blinks so count pause to pause and let me know to find out problem.
How old is this TV and did you replaced its lamp?
Thanks.
Sep 14, 2009 | Sony Grand WEGA KF60WE610 60" Rear...
Tv keeps blinking to black screen and back to normal. (sony trinitron)
Probably the picture tube getting weak, those sets have a circuit called IK Blanking that samples the three colors of the picture tube and if they are not equal the circuit blanks the picture. Another clue is if occurs less frequently the longer the set is on because the picture tube can get a little stronger as it warms up.
Aug 28, 2009 | Televison & Video
Sony 42" KV-32S66: picture blinks off briefly, getting worse
your crt is getting weak you can get around this buy adjusting the screen control ...... the screen control is on the small board on the back of the picture tube . remove back , with picture tube flashing adjust screen control a touch one way will make it worse and the other will stop the flashing . only move it as much as you need to - no more . this will work for a while and you can do it again and again when ever needed . but the picture will not be as good .... as far as the free dead sony , i would get it . changeing a picture tube from doner tv is just plug and play on a sony . so you can have a new tv for free with just a little work ..........if this answer helped please rate it 3 or 4 stars . a high rateing will help keep mein the paid answer department thanks
Apr 04, 2009 | Sony Televison & Video
SONY KV-35S26 Blinking picture
Guess I should have looked throught the next couple of posts... The problem you have there you will not be able to repair yourself but a good shop can fix it temporarily. The CRT (Cathode Ray Tube) or picture tube is shorted, that's what is causing your blinking. You can call around and ask a shop locally if they can rejuvenate it for you using a crt analyser. In the shop here we use a BK467 which would fix the problem for awhile. What they will do is take the back off and hook-up the analyser and remove the short temporarily. That fix could last weeks or even months, in most cases though never more than a year. Turn the RV1791 back down, it has nothing to do with the G2 voltage and you don't want to overdrive the crt anyway. Take it back down until the horz. lines disappear in dark scenes or background. Then take it in and have the picture tube rejuvenated. Then start shopping for a new Tv... You'll need one eventually but this will buy you a little more time.
Bill
William Rayburn, CET
Premium Technologies
PO Box 442
Long Beach, WA. 98631
360-642-4993
premtech@willapabay.org
Nov 02, 2008 | Televison & Video
Sony kp-53hs10
does the timer light blink? how many times pause then blink again?
Dec 07, 2007 | Sony KP-53HS10 TV
2000 27" Sony Wega
Sony has a code for those blinks indicating the problem area. Count the blonks till the pause then google Sony blink codes for the area to fix.
Jul 03, 2007 | Sony FD Trinitron WEGA KV-29LS35 29" TV
Sony KP-53S35 Rear Projection TV
You will need to replace the "HA" board wich is the control panel and remote reciever (wich has failed). Here is a link to the part number and where to purchase from. http://www.partstore.com/Part/Sony/Sony/KP53S35/Sony/Sony/A1372288A/New.aspx
Apr 09, 2007 | Sony KP-53S35 53" Rear Projection...
Tv picture blinks off and on
The on and off conditions is repairable and is not the tube,you should have it check out for loose conections and try not to use it or it will go bad for good and the repair will become expensive,Check power supply,horizontal driver transformer and crt board,If you are not familiar with tv service be safe and call for help.
Sep 24, 2006 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Televison & Video Logo
81 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
