Question about Samsung TXN2745FP 27" TV
Black Screen, but menu shows up
I am having this problem on this tv I just got used, its like it is not getting any a/v input. the screen is just black, no snow, nothing, except the on screen menus seem to work fine. i have tried all a/v (but not component), and cable to no avail. sound gets louder and softer, but is snow only, not what is coming in. i've checked the input (a/v / cable, etc) and channels, they are correct, but nothing. no remote. I own a pawnshop and all my other tv's work from the same input, so thats not it. supposedly my employee that took it in tested it, but who knows. thankfully i've only got $60 into it, but is it worth fixing or calling a repairman? thanks!
  • Kent Pippin Mar 23, 2007
    ...addtionally, there was no warning signs, this is all i've seen it do. it also makes a louder than normal noise at powerup (something i would expect to hear from an older tv). thanks!
    President:
  • 3,130 Answers
If you are sure that it is connected right and tested the audio inputs because to do that you will need an original remote, then you have a bad tuner or input switcher IC and no I am afraid that the TV most likly is not worth fixing. Good Luck
Posted on Mar 23, 2007
  • Larry  Dillon
    Larry Dillon Mar 23, 2007
    that noise when the set starts up is normal. That is the automatic degausing circuit activating
How do I get Amazon Fire TV resolution set so I get more than a blue screen?
Select the input channel for your Fire TV - Turn on your TV and select the input channel for the HDMI port you used to connect your Fire TV. You should then see a loading screen with the Amazon Fire TV logo 4.
Jul 04, 2017 | TV Box Televison & Video
I have a 60" Samsung led TV. Model number UN60EH6003F/type UN60EH6003. The TV turns on but doesn't show a picture. You can see the screen light up but stays a black background. Which board is bad?
well 1st before id go changing any parts I look at weather or not the input is selected correctly over to the input that im providing a known good picture signal with (antenna,cablebox,etc.), you'd be surprised how many times I get a call and I go and use the input select buttons on set itself (NOT REMOTE) and whhoolaaaa! there it is , of course I always hear next I didn't change that !!
a short comings of todays modern TV's if you arnt having any signal into it ,the screen is black and the set-up menu wont display on a black screen
Oct 27, 2015 | Samsung Televison & Video
How can I restore the tv picture to my tv combi
Make sure you haven't selected the wrong input using the input or source button on your remote control. You may have to cycle through several choice until you get to TV or Tuner or something similar. Cycle slowly, some TV's take a few seconds to render the picture one you choose a different input source.
Jan 07, 2015 | Televison & Video
Television comes on for a second and then screen turns black but tv still on
Does the OSD (on screen display) come up when you hit the menu button? If so try changing the input to the one you need.
Apr 04, 2012 | Televison & Video
Lcd screen is on, but screen stays black? what can that be?
Make sure the tv is on the correct input (Input 1 may be dvd player, but if you have it set to a blank input nothing will show up)
Does the TV's menu work?
Feb 28, 2011 | Philips 32PFL3403D/27 32 in. LCD TV
HD50LPW42 screen is black with antenna inputs
It sounds to me like you have a tuner issue, I have seen this before. If you have a good picture from other sources and they have the same antenna input, the tuner is suspect.
I hope that this helps you solve your issue.
Thanks
asnowman
Aug 01, 2009 | RCA HD50LPW42 50" Rear Projection HDTV
Can't get rid of black box
You have your TV in the "Teletext" mode. Go into the TV menu and select the closed-captioning menu and turn off the text function. What you are seeing is the result of the TV's captioning circuit latching onto a false text pilot signal and then throwing up the black box on the screen.
michtech
Feb 17, 2009 | Hitachi 50UX57B 50" Rear Projection...
Mitsubishi tv
Without the code, you must get an original remote and press the "QV" and the "9" buttons together to unlock the TV.
Oct 16, 2007 | Televison & Video
Samsung TXN2745FP 27" TV Logo
54 people viewed this question
Jerry Greenberg
Jerry Greenberg
