Question about Philips 32PT6441/37 32" TV
L01 chassis 21PT2324/71R - B+ ok (122V) but tv won't on
This unit sometimes will get on but will get off  when channel change. anyone have sharp idea is very much apprecited. tnx
2 Suggested Answers
walesarumi
  • 6993 Answers
SOURCE: Magnavox model MS3252S431 (chassis L01-1UAC-7638)
The issue you describe is consistent with a power supply board issue. This is the board where the AC goes to. This problem may have occurred as a result of irregular power supply, or excess power supply or power surge.
The TV is receiving current but cannot circulate or transfer the current to other necessary part of the TV because of the defective power supply board.
I do not think it needs replacement, rather some defective capacitors are causing this issue.
Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes)
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors).
After replacing these capacitor(capacitors) most likely the normal operation will be restored.
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
I hope this helps.
Good luck
Posted on Apr 05, 2011
Sharp LC-37DB5U stuck on one channel. Won't respond to anything. Put in a new motherboard and same problem persists. Sound and picture are fine
I could be wrong, but it sounds like the TV hasn't gone through channel setup. You have to do this in order for the TV to "learn" the channels, assuming you are using cable. If you are using cable run channel search in the setup menu and see if that changes anything. Can you change channels by manually entering in the channel # and hitting enter?
Jan 06, 2013 | Sharp LC-37DB5U 37 in. HDTV LCD Television
I have had a Sharp AQUOS LC-46PD7X for over three years and just a couple of days ago I started getting a problem where I turn the TV on and it either displays a digital channel for a couple of minutes and...
Hi ibrahl,
I too have the same model and vintage and have been experiencing low signal problems for quiet some time now. It only became apparent when we hooked up the ps3 playTV unit and the digital channels we were having problems with on the Aquos was broadcasting fine. Both devices use the same antenna connection so its not an aerial issue.
I tried reset back to factory settings and reloaded the channels via auto but now those digital channels I had problems no longer appear on our channel list so they're gone for now. I was wondering the same thing about firmware updates but havent found anything on the Sharp website. Found this video but this model uses USB for updates">
Jan 02, 2011 | Sharp Televison & Video
Sharp TV-Remote not working correctly
You will need to complete a channel scan from the tvs menu. I assume you have basic cable and that your cable company is still providing analog channels for you to be able to pick up any transmission on this telvision with the digital changeover and all.
May 05, 2010 | Sharp 27C-240 27" TV
Sharp lc-26sh10u intermitent problem
its a motherboard problem. i got one for sale or you can sell me the tv cause mine has a broken screen
Dec 25, 2008 | Sharp LC-26SH10U 26 in. LCD Television
Magnavox MS3252S431
Replace:
Q7461 C33725
O7463 C32725
C2455 47uF@50V
May 23, 2008 | Proton MM2701VT 27" TV
Magnavox MS3252S431
Replace:
Q7461 33725
Q7463 32725
C2455 47uF@50V
May 22, 2008 | Proton MM2701VT 27" TV
One channel fuzzy
Tis is an ongoing problem I seen increase alot over the past few months. From what I can gather, all the channels being broadcast over going from the analog to digital, there's no big suprise to anyone. However, the change from analog to digital is changing at a faster rate, so when you look at the TV some channels will be fine and others will have grey lines, fuzzy picture. The only solution-you need a TV with some kind of digital tuner. On the TV itself if the (TV has one) it will say "SD" or "ED" which stands for standard digital or enhanced digital.
Jan 25, 2008 | GE 27GT277 27" TV
Magnavox 32" tv ms3252s431 shutting off
Usually, the L01-1 chassis most common problem = weak
capacitors, such as C2455.Could be C2425......47mf/25v...
Check all caps around horiz drive xformer = an ESR meter
helps on this one + a skilled, experienced technician......T.
Nov 19, 2007 | Televison & Video
Lost Remote
I personally would get myself a "Universal Remote". These units will operate almost ANY unit that uses Infrared... Ya Punch a "Code" in for your particular TV etc, and thats it... total conrtol...
Sep 22, 2007 | Sharp 32R-S50 32" TV
Sharp tv changing channels
Well, the only thing that seems to be working so far is to plug AV cables into the "input 2" ports (on the front of TV). I plugged in my PS2, without turning it on. It has not switched at random since (about 30 minutes - it had been switching off and on for the past 2 hours). Anyone else have similar success?
Oct 28, 2006 | Sharp 32F540 32" TV
Philips 32PT6441/37 32" TV Logo
59 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
