Question about Nokia 6131 Cellular Phone
Nokia 6131, front/internal screen light up but don't display
The fron and internal lcd screens light up but do not display anything, the powers up, makes sounds etc but just won't display, i have replaced the housing (as it was cracked). i have read that vare needs to be taken with the cable, was wondering if i have damaged the cable (and now need to buy a new LCD) or is something else wrong?
  • 450 Answers
Your display circuit is broken, even if the LCD-panel,
seems to be ok the display is damaged.
This is a very common problem in Nokia phones.
The only way to fix this is to change the display.
You need a T-6 Torx Skrewdriver to do the job.
You can find displays for fair price at :
www.mytrendyphone.com
This is your solution! Please vote!
Posted on May 12, 2010
Nokia 6131 blank screen
this problem occurs probably when there is problem with display
you would probably have to replace your display (LCD screen)
not much costly
this may also occurs when your phone is attacked by virus but this has less probablity in this case
May 02, 2011 | Nokia 6131 Cellular Phone
Dear i have same mobile.. but now a days there is problem on the front screen of mobile dat there is lining is showing.. i cant see main display properly tere is some light lines on the display.. plz ans...
check the flex/ribbon wire of the LCD may be loose or damage. but if try to use a good LCD, your LCD may be damage and need to replace with a good 1...
May 24, 2010 | Nokia 6131 Cellular Phone
Main Display
Hi. Have you tried replacing the LCD screen? You can buy one herehttp://www.formymobile.co.uk/proddetail.php?prod=6131lcd and see thedisassembly section of the following file for fitting https://www.yousendit.com/download/Y2o4WGJEY1NxRTFMWEE9PQ
Nov 14, 2008 | Nokia 6131 Cellular Phone
I have nokia 6131. its main display is not working properly. only welcome screen come & meanwhile main display goes blank.
Hi. Have you tried replacing the LCD screen? You can buy one here http://www.formymobile.co.uk/proddetail.php?prod=6131lcd and see the disassembly section of the following file for fitting https://www.yousendit.com/download/Y2o4WGJEY1NxRTFMWEE9PQ
I CHANGED THE COVER (6131) AND NOW MY SCREEN GET OUT FROM ORDER
your screen dosnt display anything?I am not quite sure what your asking but ill take a crack at it anyway.you changed the housing and when you put the phone back together the lcd stoped working,if this is the case you either disconnected your lcd or you damaged the flex cable to the lcd,either way you need to open your phone back up just the top part where the lcd is,you should beable to see the flex cable coming from the phone to the lcd if it looks connected disconect and reconnect and try it if this does not work you may need a new flex cable wich means that you may have to get a whole new keypad cause the flex cable usually only disconnects from one side,well good luck
Sep 23, 2008 | Nokia 6131 Cellular Phone
Nokia 6131 housing
http://www.eserviceinfo.com/downloadsm/29953/Nokia_6133%206131%206126.html
This link will help you with re-assembly. I had the same snag. A GENTLE adjustment of the speaker contacts fixed the problem with sound. Use the above link to check your display connections.
Aug 15, 2008 | Nokia 6131 Cellular Phone
Main screen not desplaying when I open up my Nokia 6131
Try turning the phone on with the flip screen open. Do it a couple of times if it doesn't work the first time.
Apr 28, 2008 | Nokia 6131 Cellular Phone
NOKIA 6131 PROBLEM
Hi go to ur mobiles setting and select full fectory default its security code is 12345. thanks keep voting.
Apr 04, 2008 | Nokia 6131 Cellular Phone
Nokia 6131
open ur phone menu. go to settings options,scroll it down further and look for display settings. in display settings there will be option to adjust its brightness.
Feb 22, 2008 | Nokia 6131 Cellular Phone
Nokia 6131 Cellular Phone Logo
223 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
