Question about Stoves 1100DFSID Kitchen Range
Fan oven stays warm
I have noticed that the fan oven in our Stoves Range cooker is staying warm all the time. The top and sides of the inside of the oven are warm to touch - sufficiently to make the racks warm (not so hot you can't touch them). Something is obviously not switching off properly despite the oven control being off - can you help please by telling me what is causing this? Many thanks.
  • matduck May 07, 2009
    SAME PROBLEM, REPLACED THE ELEMENT AND NOW IT STAYS WARM EVEN WHEN ALL THE KNOBS ARE OFF, FAN DOES NOT COME ON THOUGH
  • Anonymous Mar 21, 2014
    Top oven warming up, even when no switches are on?
    New Friend:
    Problem Solver:
  • 6 Answers
I assume you mean if the main electrical isolation is switched to on , the oven heats up even though the oven switch is correctly set to off ......if this is the case you require a replacement thermostat for the upper or lower oven
Posted on Jul 10, 2014
    President:
  • 1,462 Answers
Is the fan working when oven is staying warm? possible fault if you don't have an earth trip is a short to earth on the neutral side of the element
Posted on Mar 26, 2007
Overheating
The top cooling fan is not working which cools the electrics above the oven and the control panel at the front. It could be the fan is faulty , the pcb which controls it is faulty - inside back panel on right. There is also a resistor on the power to the fan which burns out. All easy do it yourself fixes if you are electrical competent.
Feb 26, 2013 | Stoves 900DFa Dual Fuel (Electric and Gas)...
Oven doesn't seem to heat up enough
There is a cooling fan In a STOVES 720 to keep the fabric of the oven cool. If this fails the overheat thermostats will cut in and shut the heating elements off. The cooling fan does in fact blow air out of various places in and around the doors. The top oven has a small element and takes a long time to warm up. If you are not confident that the thermostats are working correctly, then I suggest you purchase an oven thermometer from someone like Lakeland and see how that relate to what you are actually setting on the cooker dial. As I said the top oven leave a lot to be desired!
Oct 30, 2011 | Stoves 720EF Electric Double Oven
Have a stoves 720 es main oven fan does not stay on to cool oven after switch off> also the oven will not trun back on when it is still hot or warm ? will
First things first. There are two fans. One in the bottom oven and one to provide background cooling. The background cooling fan turns on when anything is turned on. (Fan oven/top oven/grill). Just operate the top oven for a moment and this should cause the cooling fan to operate. There is a printed circuit board that controls the cooling fan and for how long the fan should stay on once everything has been turned off. (About 7 mins). If this fan is not running then the fan/motor could be faulty, or the circuit board or the resistor on the fan terminal block. The reason the oven will not turn back on is that the residual heat in the oven unit as a whole against the fan oven, is probably too high which causes the overheat device to operate.
You will have to take the oven out of the kitchen carcass, take the top and rear panels off and get an electrician to test and found out which item is not working/failed. Try espares for parts.
Jan 24, 2011 | Stoves 720EF Electric Double Oven
Stoves precision 1100 operators manual
I need to change the bulb in the fan part of my Precision 1100 Stoves oven but I have lost the manual. How do I get access to change the bulb?
Sep 15, 2009 | Stoves 1000DFDLm Gas Kitchen Range
Stoves df 600 sidom
We had ours fitted by a Stoves engineer who said he had the same cooker. He also told us that sometimes the fan will stay on after you have finished using it. The reason is, there will still be heat coming from the cooker or grill after use. For that reason, the fan stays on for a bit afterwards. Its just a safety precaution so that the knobs dont get too hot.
Jul 11, 2008 | Stoves 600SiDOm Gas Kitchen Range
Oven cuts out after about 15 minutes
most common fault is the cooling fan is failing to come on, whreas the fan will be okay ( check windings with ohmn meter ) it will normally have a ceramic 10k resitor in series with the live which goes open circiut
Sep 25, 2007 | Stoves 900DFa Dual Fuel (Electric and Gas)...
The cooker stays warm when mains cooker switch is on.
Either teh grill element or the oven heating element is fault or the thermostat or grill regulator, locate which element is warm, if the grill then it is most likely the regulator, if it is the oven it is the thermostat. Engineer
Jul 20, 2007 | Stoves 800DFDOm Dual Fuel (Electric and...
Newhome electric cooker = problems with oven
problem is 99% sure is the cvircular element round the fan. easy to replace
Jan 07, 2007 | Stoves Newhome ECH600MXa Electric Kitchen...
Stoves 1100DFSID Kitchen Range Logo
496 people viewed this question
Top Stoves Kitchen Ranges Experts
Paul Carew
Oloyede Monsuru
Carmen Mikulic
Are you a Stoves Kitchen Range Expert? Answer questions, earn points and help others
