VCR time counter stops and picture is covered in snow
Unit is Samsung DVD-VR350M VCRandDVD Recorder with Freeview
    President:
  • 624 Answers
Could you please explain your problem a little better with more details.
Thank you
Posted on Dec 17, 2008
Vcr tape counter does not work
Try to remove power from the unit for a while and power back to see if that clears it or not----If a on screen counter display repair will usually cost too much or with this brand parts will not be available.
Dec 09, 2012 | Samsung DVD-V6800 DVD Recorder/VCR
Unable to connect dvd/vhs recorder to record via freeview box
Can you give me the model number of the dvd/vcr and set-top box?
Jan 03, 2009 | Daewoo DVRS04 DVD Recorder/VCR
Go video VR4940 VCR video recording has sound but no picture
You can try cleaning the video tape heads. The vcr has 2 different heads. One for audio which is fixed and a drum head for video with 2 heads on it that rotate. The best way to clean them is to take a lint free cloth ad wrap it tightly around your finger. Put some alcohol on the cloth and place it on the drum. Then rotate the drum as you hold your finger against the drum. DO NOT move your finger up and down as you can brake the head off. The other option is to go buy a head cleaning stick. It's a piece of chamie on a plastic tongue depressor. I've cleaned hundreds of them with my finger though. You can clean the whole tape path with the rag. Good Luck.
Nov 30, 2008 | GoVideo VR4940 DVD Player/VCR
Vcr
sound slike bad head on vcr side samsung makes new dvd vcr in one thats nice 79 on sale at circit city ok
Oct 06, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Connecting a freeview box
Your dvd player should be connected to the TV INPUT under norma conditionsl.What kind of recorder are you using? VCR player ?, Is it also a VCR recorder ( one cannot assume because I happened to own a VHS\vcr PLAYER, not player & recorder)Is Your VCR recorder? Then It must be connected to freeview box with universal scart to RCA converter box.You have "" dvd player in av2, vcr av1"" where? TV? freeview box scart connector ?
You will need scart to RCA converter box for sure.
Aug 08, 2008 | Televison & Video
Go video VR3845
Try unpluging the unit and the plug it back in
Apr 19, 2008 | GoVideo VR3845 DVD Recorder/VCR
Similar problem as you helped me solve before.
OK, I think I see the problem there.
The aerial lead from the DVDR to TV should be removed.
You should have it setup the same as the other Freeview - VCR - TV
Nutshell time:
Main aerial to Freeview input.
Loop aerial from freeview output to DVDR areial input (all this does is allow you to watch freeview, or standard both out of the DVDR)
So..
Scart from Freeview to DVDR input
Scart from DVDR output to TV
Set DVDR to AV input mode.
Set TV to AV (whatever number you need for that..you now won't get anything on screen unless you have the right input selected)
If you can now see the Freeview picture on the TV and change the channels with the Freeview remote then you should be set for recording.
Having the aerial and a scart lead both going to the TV is not needed.
Apr 14, 2008 | Philips VR550 VHS VCR
CNNECTING DMREZ27EB FREEVIEWDVD RECORDER, TO MY TV 2 SCARTS, AND MY PANASONIC VCR VIDEO RECORDER
I CONNECTED SCART TO TV 1 TO DVD FREEVIEW SCART 1, THEN I VCR SCART IN/OUT TODVD FREEVIEW RECORDER SCART 2, THEN RF CABLE FROM FREEVIEW RECORDER OUT TO VCR RF IN ,VCR RF CABLE OUT TO TV RF IN. RF SLOT IN ON FREEVIEW LEFT EMPTY THEN CHANGED TV TO AV 2 WHEN USING TO RECORD /PLAY EITHER VCR OR/ FREEVIEW DVD . I DO HOPE THIS HELPS SOMEONE. IT TOOK ME A WHILE TO SORT OUT REGARDS R. ELLIOTT.
Feb 22, 2008 | Televison & Video
Unfinalized DVDs
What sort of "recognization" is your TV showing? Do you get a blue screen but no AV?...accordianman
Jan 15, 2008 | Samsung DVD-VR320 DVD Recorder/VCR
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
